  • andypugh
  • andypugh's Avatar
07 Mar 2025 20:12
CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
Category: Milling Machines
What command and feedback method do the drives and axes require/provide?
You might want to look at the "HD" cards too, such as the 6i24 as those have rather more pins. For example 6i24 + 7i36. The 7i36 can connect one smart-serial board for GPIO, and then you could add a 7i44 if one sserial board isn't enough.
Look at the 7i43 to simplify the control panel wiring too.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 20:03
Advanced Lube pump timing and memory for oil mist spindles
You might want to consider adding this to the "Contributed Components" on wiki.linuxcnc.org
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:59
Replied by andypugh on topic question of Homing
question of Homing
Category: EtherCAT
LinuxCNC expects the encoder counts to be zeroed at the index. (then LinuxCNC uses the small number of remaining counts that accumulate as the axis comes to a stop to calculate the exact index position).
If your ethercat encoder counters don't do this then you will see the behaviour you describe. And, also, your home position will be wildly inconsistent.
If you have good homing switches you may be able to just not use home-to-index. Alternatively some HAL magic might be used to latch the C phase to look like the edge of a switch (and2 with the actual switch).
Reset on index might be a configurable option in the encoder counter.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:53
Replied by andypugh on topic python hal glade
python hal glade
Category: GladeVCP
You may have cut off the most important part of the error chain, the real problem is likely to be near the bottom.
  • andypugh
  • andypugh's Avatar
07 Mar 2025 19:50
Replied by andypugh on topic Devuan, RPi5 & Linuxcnc Image
Category: Installing LinuxCNC
Which libgpiod?
  • royka
  • royka
07 Mar 2025 19:42 - 07 Mar 2025 19:45
Just to let you know, that the SPI connection (generic) also works with the Orange Pi 5 and the TangNano9k.
Great work meister!
By the way I think that supporting Mesa boards would be beneficial for many, since it's much easier to adjust the functions of the pins.
  • ErwinCNC
  • ErwinCNC
07 Mar 2025 19:41 - 07 Mar 2025 19:51
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
Category: Deutsch
Die Mesa Karte ist direkt über ein Netzwerkkabel mit dem PC verbunden. Das Kabel habe ich schon ausgetauscht - keine Änderung.
Die Spannungsversorgung erfolgt über ein 5V Hutschienen Netzteil 5V 3A
Aktuell ist außer der Stromversorgung nichts an der Mesa Karte angeschlossen.
​​​​​​Den Ping Befehl habe ich jetzt noch mit 10 Minuten ausgeführt. Die Werte sind praktisch identisch zur letzten Messung (1 Minute)
Der Fehler tritt zufällig auf. Manchmal nach wenigen Sekunden manchmal erst nach 20 Minuten.
Unabhängig davon ob das gmoccapy Fenster maximiert, klein oder im Hintergrund ist.
  • PCW
  • PCW's Avatar
07 Mar 2025 19:33
Replied by PCW on topic 7i96s Watchdog Ethernet
Category: Deutsch
Not sure what's wrong, that's a 31 ms delay!
  • ErwinCNC
  • ErwinCNC
07 Mar 2025 19:26
Category: Deutsch
Ergänzung
Die Maschinenkonfiguration ist für die Tests ganz einfach gehalten. Erstellt mit PNCCONF XXYZ mit 1280steps/mm keine Endschalter, Spindel oder sonstige Ein / Ausgänge.
Wirklich minimal gehalten. Außer den Verfahrwegen nur Standardeinstellungen.
Die Karte läuft auf dieIP 10.10.10.10 am PC ist noch ein USB W-Lan Stick eingesteckt. Dieses Netzwerk ist 192.168.1.XX
Als Oberfläche habe ich gmoccapy gewählt.
  • stefan63
  • stefan63's Avatar
07 Mar 2025 19:25
Replied by stefan63 on topic Finally 7i76EU!
Finally 7i76EU!
Category: User Exchange
Any plan to bring those in?
store.mesanet.com/index.php?route=produc...69_70&product_id=116
Kind regards/Stefan
  • Lcvette
  • Lcvette's Avatar
07 Mar 2025 19:23
Replied by Lcvette on topic Problems with vcp-template
Category: QtPyVCP
your best bet is to use this installation method:
github.com/Lcvette/qtpyvcp-bookworm-installer
  • stefan63
  • stefan63's Avatar
07 Mar 2025 19:18
Replied by stefan63 on topic panelui
panelui
Category: LinuxCNC Documents
Thank you!
I finally found it will deep dive in to this later if I need to.
I gues it kind of ancient by now as not much development have been made for a century.
/Stefan
  • ErwinCNC
  • ErwinCNC
07 Mar 2025 19:17
Category: Deutsch
Es sind 2 Fehlermeldungen
hm2/hm2_7i96s.0: Wachdog has bit! (set the .has bit pin to False to resume)
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session. Run the Latency Test and resolve before continuing.
Die Ursache scheint wieder im Bereich read.tmax zu liegen.
cnc@cnc:~$ halcmd show param *.tmax
Parameters:
Owner   Type  Dir         Value  Name
    36  s32   RW              0  hm2_7i96s.0.read-request.tmax
    36  s32   RW       96523036  hm2_7i96s.0.read.tmax
    36  s32   RW         390944  hm2_7i96s.0.write.tmax
    29  s32   RW          65448  motion-command-handler.tmax
    29  s32   RW         138712  motion-controller.tmax
    39  s32   RW           6464  pid.s.do-pid-calcs.tmax
    39  s32   RW           6196  pid.x.do-pid-calcs.tmax
    39  s32   RW           4464  pid.x2.do-pid-calcs.tmax
    39  s32   RW           6624  pid.y.do-pid-calcs.tmax
    39  s32   RW           6464  pid.z.do-pid-calcs.tmax
    30  s32   RW       96637576  servo-thread.tmax
Vielen Dank
Grüße Erwin
  • timo
  • timo
07 Mar 2025 19:14 - 07 Mar 2025 19:38
Ist Linuxcnc kompatibel mit anderen CNC-Sprachen?
Category: Deutsch
Was ist denn der Hintergrund der Frage?
Disclaimer: (ich bin nur Hobbyfummler und "kenne" nur Mach3, Linux, Fanuc, Marlin und GRBL ) vermute aber, dass Haidenhain und Siemens keine Ausreißer sind.)
Ich programmiere nichts per Hand, es sei denn es ist wirklich irgendein Quatsch, wie 4 Löcher bohren, oder eine Kante fräsen.
Im Prinzip "macht es wohl (was eigenes)" bzw. alle anderen machen "was eigenes".
Was es macht, kann man hier nachlesen. linuxcnc.org/docs/html/gcode/g-code.html
Einen für Fanuc erzeugten G-code auf Linux CNC "loszulassen" würde ich mit Vorsicht genießen. (kann man aber mit dem Finger auf dem NotAus riskieren)
Linux CNC g-code läuft nicht so ohne weiteres auf dem Fanuc controller. (dont ask)
Der meckert z.B. bei Sonderzeichen und will gewisse Formatierungen anders haben.
z.b. G0x2y4z5 (fährt bei Linucx auf x 2mm, y 4 mm z 5 mm)
Der Fanuc fährt auf x 2 micrometer, y 4 micrometer und z 5 micrometer. ;-)
Wenn man aber jetzt G0x2.0y4.0z5.0 eingibt, machen beide das gleiche (weil der Fanuc immer seinen Punkt (Komma) haben muss und Linux alles ohne Punkt als mm nimmt )
Das kracht, wenn man nicht aufpasst.
Wenn es darum geht, ob man manuelles Programmieren mit Linux CNC üben kann? Das ist ähnlich genug, um einfach mit Linux anzufangen und wenn man dann später was anderes machen möchte, sind es nur Details, die man beachten muss.
Im CAM Programm kann ich einfach zwischen den Dialekten (ist glaube ich ein passenderes Wort, als Sprache) umschalten.
Gruß Timo
Displaying 18016 - 18030 out of 18589 results.
Time to create page: 0.546 seconds
