  • rodw
  • rodw's Avatar
11 Aug 2026 07:46
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
The ethercat thread and linuxcnc thread should be the same, On startup, the 2 thread synchronise. If you use the ethercat drivers on the linuxcnc-ethercat github page, this has been improved with changes to linuxcnc and the ethercat master to improve this sync. You probably need master to get these changes.
  • rodw
  • rodw's Avatar
11 Aug 2026 07:35
Gui message while homing with shared home/limit swiches
Category: Qtvcp
that is what everyone gas been telling me (the part about home_ignore_limits). that other line i dont understand because i am not a HAL programmer. but there is probly several ways to accomplish this. if your one line per axis accomplishes the same thing, it is certainly more elegant and efficient.
Personally, I like writing statements on separate lines. I find its easier to understand and maintain
  • rodw
  • rodw's Avatar
11 Aug 2026 07:30
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Is it a Pi5 or 4b? the 4b was always a bit marginal but some say the 5 is flawless for them.
You could try the Respberry way perhaps. Once you get the RT kernel sorted, just compile linuxcnc
forums.raspberrypi.com/viewtopic.php?t=396623
  • meister
  • meister
11 Aug 2026 04:48
new driver plugin: TMC5160 via SPI:
www.youtube.com/shorts/DlIHY1Iy-ZQ
I don’t really like AI, but I do give it a go every now and then.
But this time I have to admit that gpt-5.6-sol-xhigh
did a pretty good job of it; it understood how a Rio plugin is structured and also generated the Verilog code quite neatly.
So this is the first plugin I’ve created with the help of AI.
I’d had the drivers for a while, but I was always too lazy :)
The tricky bit here was realising that, although the drivers use SPI (for configuration), they can’t be controlled via SPI.
To do that, you have to re-solder a tiny resistor on the back – not much fun.
So if you’re going to do this, get a board with the right jumpers for SD mode and SPI mode.
  • Todd Zuercher
  • Todd Zuercher's Avatar
11 Aug 2026 04:43
Replied by Todd Zuercher on topic LinuxCNC S-Curve Accelerations
Wow, ambitious, looking forward to seeing your results.
Thankyou for your contributions.
  • grandixximo
  • grandixximo's Avatar
11 Aug 2026 02:41
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
New TP2 shall have 9 axis look ahead, we are working on a different base source, i can't share a work in progress, I will be porting later, still working out feed override spikes at the moment, and thinking about remaking the TP base completely.
For multiaxis, I started also on porting and improving G12.1 (switchkins from rushabhGH), and I'm juggling with an idea to have tool length be something adjacent to a virtual axis, and if those are in place, have the proper axis limits be derived from joints + current kins + current tool
Time will tell...
  • NWE
  • NWE's Avatar
10 Aug 2026 18:45
Replied by NWE on topic Ver 10 NEW install
Ver 10 NEW install
sounds like graphics drivers likely loaded just fine
Have you made any edits to the file /etc/lightdm/lightdm.conf yet?
Something I think to try, before running startx:
sudo systemctl status display-manager --no-pager -l
and
systemctl status lightdm --no-pager -l
If you can, snap a good photo of each command's result and post here that will save you lots of typing.
  • 5280
  • 5280
10 Aug 2026 15:42
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
right .... oops
10 Aug 2026 15:26
Replied by tommylight on topic Ver 10 NEW install
Ver 10 NEW install
Kernel driver in use 1915
Kernel modules: 1915
I think got it all typed right.
Almost, it is i915.
  • 5280
  • 5280
10 Aug 2026 14:24
Ver 10 NEW install
The 2nd reply from the program in terminal is the same.
  • 5280
  • 5280
10 Aug 2026 14:14
Ver 10 NEW install
the reply is :
00:02:0 VGA compatible controller (0300): Intel Corporation Haswell-ULT Integrated Graphics Controller (8086:0a16) (rev 09)
Subsystem: Dell Device (1028:05ec)
Again THANK YOU for all the help.
  • scsmith1451
  • scsmith1451's Avatar
10 Aug 2026 11:02
GladeVCP panel fails to launch intermittently
Category: GladeVCP
My GladeVCP panel fails to launch intermittently. The only errors that are found in the report are:
GladeVCP.QTVCP.QT_ISTAT][^[[33mWARNING^[[0m]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
**** GLADE VCP ERROR:    With xml file: crosshair_panel.glade : 'gi.repository.Gtk' object has no attribute 'glade'
and:
crosshair_panel.hal:7: Pin 'crosshair_panel.crosshair-ctl-active' does not exist
The second error is thrown because the panel fails to launch.  The reference to the pin is in my postgui_hal file.
How do I diagnose and repair this issue.
Regards,
  • NWE
  • NWE's Avatar
10 Aug 2026 10:41
Ver 10 NEW install
Ok, graphical.target is correct. This tells me it is configured to start to graphical, but apparently something is breaking it.
Lets try:
(run this before startx, then let me know what it answered:)
sudo lspci -nnk | grep -A 3 -i vga
maybe also run it again in a terminal after you ran startx and see if anything changed.
  • COFHAL
  • COFHAL
10 Aug 2026 10:15 - 10 Aug 2026 11:47
Replied by COFHAL on topic gearchange
gearchange
  I'm automating a parallel lathe with a 9-speed gearbox selected manually using two levers, each with 3 positions: lever 1 has positions A, B, and C, and lever 2 has positions D, E, and F. The possible combinations are as follows:   Direction changes are achieved by activating two electromagnetic clutches.This gives me the following truth table: I'm using the gearchange component for up to 32 speeds created by Andy Pugh, which can be used in this case. The first problem I encountered was creating the logic to detect these combinations, as I needed to detect the positions of the 6 switches I'm going to install to control the lever positions. Of the 6 bits, two will always be true. The component I found and was able to use was LUT5, but the problem is that it's only valid for 5 bits, and there are 3 combinations where bit 5 is one. Therefore, for these 3 combinations, in addition to LUT5, I had to use an additional AND2 gate to detect them.I read on the forum that for some automatic gear shifters, like the Maho MH400E, they created a component with an array that detects each gear by the switch positions.I also used the generic mux component to identify which gear was selected using a number between 1 and 9. Since it's 9 bits, it gave me a combination of 512, of which I only used 9 so that the mux output was a number between 1 and 9.I don't know if there's another way to detect the switch combination for the two levers.I've attached my HAL file to detect each lever position so I can send the correct speed to the VFD.
  • zz912
  • zz912's Avatar
10 Aug 2026 10:01
Replied by zz912 on topic Xenomai 4 Poll
Xenomai 4 Poll
Hi Bari,
I came across your February discussion about Xenomai 4 and LinuxCNC and just wanted to provide a quick update, especially regarding Mesa.
In the meantime, Hannes has implemented Xenomai 4 / EVL support in LinuxCNC, as well as OOB networking for Mesa HostMot2. PR #4199 was merged into master on August 5, 2026.
More information here:
forum.linuxcnc.org/38-general-linuxcnc-q...core?start=10#348629
So the question of Mesa support that you mentioned back then seems to have been resolved now.
Displaying 1951 - 1965 out of 11357 results.
Time to create page: 0.254 seconds
