  • grandixximo
  • grandixximo's Avatar
05 Aug 2026 19:25 - 05 Aug 2026 19:27
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Have patch waiting to merge to silence those.
We have been stuck on the feed override for TP2, doing it proper without any jerk spikes, is proving much harder than we thought.
  • dang133
  • dang133
05 Aug 2026 18:34
Probe Basic Cutaway was created by dang133
Probe Basic Cutaway
Category: QtPyVCP
Hi everyone,
I'm new, so go easy on me.  My team is using Probe Basic as a GUI for a 5-axis CNC Mill.  We're trying to create a cutaway button that will show only half of a part at a time.  It will virtually slice the part and show the cutaway.  After some google earching, it looks like this is not a common request.  How should we go about doing this?  What is the best route to take?
Thanks,
Dan
  • hitchhiker
  • hitchhiker
05 Aug 2026 15:41
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
here the zipped config.. hope it help us... thank you for the help and time and headache :)
  • rubes
  • rubes
05 Aug 2026 14:32
Gui message while homing with shared home/limit swiches
Category: Qtvcp
i have a RPI-4 running linuxcnc 2.9.10. using  a 7i96s, the qtdragon GUI, and inductive proximity switches. i have one switch acting as both home and limit.
everything is working perfectly except for a minor annoyance on the status bar. when i home, and the axis move toward the home switch, initially trips the switch, it properly reverses off the switch (search velocity is positive, and latch velocity is negative so the axis is of the switch), then continues on to the final home position. but when it initially hits the switch, the status bar shows "hard limit tripped". the machine doesn't stop, so it is properly ignoring limits while homing. the fault clears itself after several seconds. just curious why this is happening. i thought i read somewhere that it re-enabled limits after the cycle was done, apparently not the case? I assume if it bothers me enough i could learn/write some HAL code to block it in the GUI?? or better yet just use the switch as home, and just rely on the soft limits
  • 3404gerber
  • 3404gerber
05 Aug 2026 13:48
Best bet for a low cost HW assisted Linuxcnc engine....
* I have asked on the Remora part of the forum if the RP2040 based system (which sounds great!) is ready for prime time and I have had no responses since posting it a couple of weeks ago.  Is the impression I am left with which is that it is not ready and the enthusiam for it has died out?
I saw your post on the in the Remora forum a week ago. I think that the port to RP2040 is not as developed as other port; one reason is probably that there are only few 3D printer control boards based on this mcu. As Scotta wrote in the post:
scotta post=344968 userid=24854
"This Remora port was a hotel room project when I was travelling for work."
I played a bit with it, mainly because I had some rp2040 around, but never used it to move physical axis. That's the next thing; if you want to interact with real world, a Pico might not be enough. You'll need some buffer and optocouplers. And this is something you get out of the box with the Mesa card. I guess you could also try the PicoCNC board designed for grblHAL and put Remora on it, but it's not that cheap anymore either.
For the RP2040 there's also a component called stepper-ninja that might interest you. But again, you'll not find the maturity of Mesa cards there. Really depends what you plan to do with it.
And if you go with a RPi, yo can also design a HAT for it with some SPI drivers; I designed one with TMC5160 drivers on the top and wrote a LinuxCNC component to send target velocity over SPI; I probably wouldn't use this as is on a CNC mill, but I have a Galvo Laser engraver that is mounted on a 3 axis system, which are connected to that HAT. It's been a year now and never had issue with it, but I only use it more or less an hour per week.
  • hitchhiker
  • hitchhiker
05 Aug 2026 12:06
I test arround... i will send you later.
I think the singularity is a issue... and dh parameters... possible the alohas are not correct... upside down tcp... i dont know
  • Aciera
  • Aciera's Avatar
05 Aug 2026 12:03
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
an again i wonder that the tcp is upside down..
Looking at those curved jog paths I don't think you are done with your DH-parameters yet.
If you zip up the config folder with the vismach model I'll try to have a look at it.
  • saxa
  • saxa
05 Aug 2026 11:07 - 05 Aug 2026 11:07
Gantry oxyfuel / plasma type machine from scratch
Hi another question from my side is in case I have to replace the servo drives and motors, as it seems that they have lost them, which brand would be the best one to go ? Also in that case would it be worth going directly with EtherCAT type of drives ?
  • emresensoy
  • emresensoy
05 Aug 2026 10:21
LS L7N Servo drives standing INIT state was created by emresensoy
Category: EtherCAT
my DIGAN IO card (ER 12 DIG 4 ANA IO) is working without problem,
but servo drives standing INIT state and generates error,
what is the problem?
[code]emre@debian:~$ ethercat slaves
0  0:0  INIT   E  0x00007595:0x00000000
1  0:1  INIT   E  0x00007595:0x00000000
2  0:2  INIT   E  0x00007595:0x00000000
3  0:3  INIT   E  0x00007595:0x00000000
4  0:4  INIT   E  0x00007595:0x00000000
5  0:5  PREOP  +  ER 12 DIG 4 ANA IO
[/code]
[code][code]emre@debian:~$ sudo dmesg | tail -n 30
[  538.497723] EtherCAT 0-1: Acknowledged state INIT.
[  538.497724] EtherCAT 0-2: Acknowledged state INIT.
[  538.497726] EtherCAT 0-3: Acknowledged state INIT.
[  538.497727] EtherCAT 0-4: Acknowledged state INIT.
[  538.499581] EtherCAT 0: Domain 0: Working counter changed to 2/18.
[  538.529813] EtherCAT 0: Slave states on main device: INIT, OP.
[  539.503585] EtherCAT 0: Domain 0: Working counter changed to 3/18.
[  549.453683] EtherCAT 0: Master thread exited.
[  549.453704] EtherCAT 0: Starting EtherCAT-IDLE thread (build-marker: lib-refclk-quiet-v16).
[  549.453762] EtherCAT 0: Releasing master...
[  549.453764] EtherCAT 0: Released.
[  549.486309] EtherCAT 0: Slave states on main device: INIT, PREOP + ERROR.
[  549.486318] EtherCAT ERROR 0-0: Failed to set PREOP state, slave refused state change (INIT + ERROR).
[  549.486321] EtherCAT ERROR 0-1: Failed to set PREOP state, slave refused state change (INIT + ERROR).
[  549.486322] EtherCAT ERROR 0-2: Failed to set PREOP state, slave refused state change (INIT + ERROR).
[  549.486324] EtherCAT ERROR 0-3: Failed to set PREOP state, slave refused state change (INIT + ERROR).
[  549.486326] EtherCAT ERROR 0-4: Failed to set PREOP state, slave refused state change (INIT + ERROR).
[  549.490488] EtherCAT ERROR 0-0: AL status message 0x0016: "Invalid mailbox configuration".
[  549.490493] EtherCAT ERROR 0-1: AL status message 0x0016: "Invalid mailbox configuration".
[  549.490495] EtherCAT ERROR 0-2: AL status message 0x0016: "Invalid mailbox configuration".
[  549.490497] EtherCAT ERROR 0-3: AL status message 0x0016: "Invalid mailbox configuration".
[  549.490499] EtherCAT ERROR 0-4: AL status message 0x0016: "Invalid mailbox configuration".
[  549.498600] EtherCAT 0-0: Acknowledged state INIT.
[  549.498605] EtherCAT 0-1: Acknowledged state INIT.
[  549.498606] EtherCAT 0-2: Acknowledged state INIT.
[  549.498608] EtherCAT 0-3: Acknowledged state INIT.
[  549.498609] EtherCAT 0-4: Acknowledged state INIT.
[  549.517994] EtherCAT 0: Slave states on main device: INIT, PREOP.
[  622.701268] warning: `Socket Thread' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[  809.225497] perf: interrupt took too long (3952 > 3950), lowering kernel.perf_event_max_sample_rate to 50500
[/code]
[/code]
emre@debian:~$ ethercat xml
<?xml version="1.0" ?>
<EtherCATInfoList>
  <EtherCATInfo>
    <!-- Slave 0 -->
    <Vendor>
      <Id>30101</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
          <Type ProductCode="#x00000000" RevisionNo="#x00000002"></Type>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  <EtherCATInfo>
    <!-- Slave 1 -->
    <Vendor>
      <Id>30101</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  <EtherCATInfo>
    <!-- Slave 2 -->
    <Vendor>
      <Id>30101</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  <EtherCATInfo>
    <!-- Slave 3 -->
    <Vendor>
      <Id>30101</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  <EtherCATInfo>
    <!-- Slave 4 -->
    <Vendor>
      <Id>30101</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
  <EtherCATInfo>
    <!-- Slave 5 -->
    <Vendor>
      <Id>1640067</Id>
    </Vendor>
    <Descriptions>
      <Devices>
        <Device>
          <Type ProductCode="#x00000002" RevisionNo="#x00000002">ER 12 DIG 4 ANA IO </Type>
          <Name><![CDATA[ER 12 DIG 4 ANA IO ]]></Name>
          <Sm Enable="1" StartAddress="#x1000" ControlByte="#x64" DefaultSize="0" />
          <Sm Enable="1" StartAddress="#x1200" ControlByte="#x20" DefaultSize="0" />
          <RxPdo Sm="0" Fixed="1" Mandatory="1">
            <Index>#x1600</Index>
            <Name>Outputs</Name>
            <Entry>
              <Index>#x0005</Index>
              <SubIndex>1</SubIndex>
              <BitLen>32</BitLen>
              <Name>DAC1</Name>
              <DataType>UINT32</DataType>
            </Entry>
            <Entry>
              <SubIndex>2</SubIndex>
              <BitLen>32</BitLen>
              <Name>DAC2</Name>
            </Entry>
            <Entry>
              <SubIndex>3</SubIndex>
              <BitLen>32</BitLen>
              <Name>DAC3</Name>
            </Entry>
            <Entry>
              <SubIndex>4</SubIndex>
              <BitLen>32</BitLen>
              <Name>DAC4</Name>
            </Entry>
            <Entry>
              <SubIndex>5</SubIndex>
              <BitLen>16</BitLen>
              <Name>Output</Name>
              <DataType>UINT16</DataType>
            </Entry>
          </RxPdo>
          <TxPdo Sm="1" Fixed="1" Mandatory="1">
            <Index>#x1a00</Index>
            <Name>Inputs</Name>
            <Entry>
              <Index>#x0006</Index>
              <BitLen>32</BitLen>
              <Name>V1</Name>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
              <Name>V2</Name>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
              <Name>V3</Name>
            </Entry>
            <Entry>
              <BitLen>32</BitLen>
              <Name>V4</Name>
            </Entry>
            <Entry>
              <BitLen>16</BitLen>
              <Name>Input</Name>
            </Entry>
          </TxPdo>
        </Device>
      </Devices>
    </Descriptions>
  </EtherCATInfo>
</EtherCATInfoList>
[code]
[/code]
  • hitchhiker
  • hitchhiker
05 Aug 2026 08:52 - 05 Aug 2026 08:57
i read this yes but i dont think about the a to c axis.. joint 4 to joint 6 issue...
i homed all again to x0y0z0a0b0c0  and then jog ti a1 and b0.5 still flipping......
i checked again that all the movements in joint mode are correct ( encoder and motor to degree translation ) the scales are all correct.
05 Aug 2026 08:20
@Tommy: What do you mean with "China is running a misinformation campaign?", do you refer to some spam we see occasionally here?
Nope, the naming everything related to cnc as "mach3", so beginners think it only works with Mach3, besides the usb cards that only work with mach3.
  • Aciera
  • Aciera's Avatar
05 Aug 2026 07:51
i made a vismach model... i update it to the home position i want.. its 1:1 after homing th real arm.
Nice!
i dont know if this explain some wrong dh parameters?! but in some positions the A axis.. joint 4 on the arm starts flipping
Have you read the stuff I wrote and linked to regarding singularities?
Move joint_4 away from the zero position and try again.
  • timo
  • timo
05 Aug 2026 06:16 - 05 Aug 2026 06:17
@mars: Does, "I also understand that the Mesa card is solid but the price is less than desirable.", mean you wish it was more expensive so that more people would become motivated to follow up with other options?
  • Aciera
  • Aciera's Avatar
05 Aug 2026 03:40
M19 orientation drift with external encoder and orient component (LinuxCNC 2.9.4
You might want to try 's_orient.comp', this modified version of 'orient.comp' provides an input that is to be connected to your encoder-index signal and will look for the index before orienting the spindle.
forum.linuxcnc.org/media/kunena/attachme...ient_2025-03-18.comp
- download the file and rename to 's_orient.comp'
- to install you need the 'halcompile' tool (you might need to install the 'linuxcnc-dev' package if your are on a package installation of linuxcnc)
- $ halcompile --install {your-path-to-the-file-here}/s_orient.comp
(you will need to use 'sudo' to execute this command on a package installation)
The output should look something like this:
Compiling realtime s_orient.c
Linking s_orient.so
cp s_orient.so /home/user/git/mylinuxcnc-master/rtlib/
- in your hal file change 'loadrt orient {...}' to 'loadrt s_orient {...}' and connect your encoder index signal to the orient component (you might have to modify your pin names to 's_orient')
  • aydinsen
  • aydinsen
05 Aug 2026 03:31
BF20L ,linuxCNC, touch probe and install
Category: Milling Machines
Hello from Turkey! Need beginner-friendly guidance on BF20L CNC Touch Probe setup
Hello everyone,
Sending my warmest regards to all forum members! I have been following this community for a while now and have gained a lot of valuable information. I would like to thank everyone who has contributed and shared their knowledge here.
First of all, I have an optimum BF20L mill that has been converted to a CNC. For the controller board, I will leave the link below. Although I have a background in electronics, I am very new to the CNC world and want to make sure I am on the right track.
I want to install a touch probe, but I have a few questions about what to expect:
  1. Once configured, can I use this probe to automatically set my workpiece zeros (X, Y, and Z axes)? Is that the main expectation?
  2. Could you please explain how to configure and wire this setup step-by-step, as if you were explaining it to a complete beginner (or "explain like I'm five")?
  3. Since I live in Turkey, I am not sure which probe model to buy. Can you recommend a budget-friendly, price-to-performance touch probe available here?
I would truly appreciate your help with the choice of probe and the configuration process. Thanks in advance!
www.google.com/imgres?imgurl=https://cdn...spwouoe,sh/x/im/m1/3
Displaying 2116 - 2130 out of 11357 results.
Time to create page: 1.506 seconds
