  • cakeslob
  • cakeslob
21 Dec 2024 02:06
Some new Linux CNC board by Bigtreetech looks cool still trying to get more info
Yeah, it is. I told them we were too far apart to make it work at the moment, but some of the older stuff still said linuxcnc.The other part was, it uses onboard TMC2160 drivers with SPI config, but it includes headers to use external drivers. They said something about their software engineers but they didnt reach out to me further. They included an SPI + UART connector for us, and we can use the Wifi connector as well with my w5500 adapter.
I can send you one if you want, but its basically an SKR3 mixed with a flexihal. So aside from the TMC drivers it should probably work with some minor tweaks.
  • PCW
  • PCW's Avatar
21 Dec 2024 01:43
Replied by PCW on topic Fast Hole EDM from Hacked Parts
setp hm2_7i96s.0.ssr.00.out-00 true
Doesn't make much sense here as the output is controlled by
edm-pump-output
  • epineh
  • epineh
21 Dec 2024 00:26
Hi all, thanks for the help trying to solve my compile issues, in the end I used the docker method, definitely recommend this for people like myself, not too bright but can lift heavy things :)
  • Lcvette
  • Lcvette's Avatar
20 Dec 2024 23:37
Replied by Lcvette on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
did you edit the ui?
  • IronManDylan
  • IronManDylan
20 Dec 2024 22:50
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
Okay, it sounds like the info I was putting in the .ini folder was unnecessary so I removed it.
I got my mcode into the right location, for anyone struggling with this in the future it needs to be in the location that is given by 'PROGRAM_PREFIX' in the .hal file.
So now when I put m101 into MDI absolutely nothing is happening. This is what I have in the .hal:
net edm-pump-output <= motion.digital-out-00
net edm-pump-output => hm2_7i96s.0.ssr.00.out-00
And this is what I have in the M101 file:
#!/bin/bash
halcmd setp motion.digital-out-00 1
#chmod +x M101
exit 0
Notice chmod +x M101 is commented out.
Does anyone know why this is not working? Thank you.
  • mjones@welfab.ca
  • mjones@welfab.ca
20 Dec 2024 22:39
Replied by mjones@welfab.ca on topic Min Max limit error on only one axis
Ok so I took Andy's advise, and looked at the kinematics tutorial and sure enough axis a,b,c are designated for rotary axis and u,v,w are other linear, so to see if it would make a difference I changed my a axis to u, then when I tried opening linuxcnc it came up with an error saying that pin pid.u.pgain didn't exist. I looked through everything and changed in the ini axis.U to axis.u. then it came up similar to previouse the min max needs to be1e99 +- so then I changed to joint for u to 6 from 3 because the manual says that axis u is joint 6 then it went back to pin pid.u.pgain didn't exist.
I am now wandering if I have to plug that axis into the axis 6 output on the 7i76 board and change all the stepgens to stepgen 6 as well.
Has any one had this problem that can steer me the right way? Forgive my paraphrasing the errors, I am at home now not at work near the machine, and on a windows machine not linux.
  • Tntmold
  • Tntmold
20 Dec 2024 22:07
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I am very new to Linux and this is obviously an ignorance problem. Why can't I run the script?
phil@SodickA:~/Downloads$ . ./ecat.sh
requires sudo to run eg: sudo ./ecat.sh
removing ethercat repository file\n
rm: remove write-protected regular file '/etc/apt/sources.list.d/ighvh.sources'? y
rm: cannot remove '/etc/apt/sources.list.d/ighvh.sources': Permission denied
Install ethercat repository
dd: failed to open '/etc/apt/trusted.gpg.d/science_EtherLab.gpg': Permission denied
--2024-12-20 15:55:08-- build.opensuse.org/projects/science:Ethe...ys/download?kind=gpg
Resolving build.opensuse.org (build.opensuse.org)... 195.135.223.221, 2a07:de40:b250:131:10:151:131:20
Connecting to build.opensuse.org (build.opensuse.org)|195.135.223.221|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘STDOUT’
- [ <=> ] 1.08K --.-KB/s in 0s
2024-12-20 15:55:09 (47.0 MB/s) - written to stdout [1109]
gpg: [stdout]: write error: Broken pipe
gpg: filter_flush failed on close: Broken pipe
tee: /etc/apt/sources.list.d/ighvh.sources: Permission denied
phil@SodickA:~/Downloads$ sudo .ecat.sh
sudo: .ecat.sh: command not found
  • IronManDylan
  • IronManDylan
20 Dec 2024 21:57
Okay so the config successfully boots with the following code in .hal:
net edm-pump-output => hm2_7i96s.0.ssr.00.out-00 true
So if motion.digital-out-00 is set to true (which is what I am trying to do with the M101) the pumps should turn on.  This makes sense to me now. However I am not sure if motion.digital-out-00 is the correct 'thing' to use here.
I also believe that I need to do something in the .ini file.  What I was trying was:
REMAP=M101 modalgroup=6 python=none
REMAP=M102 modalgroup=6 python=none
I take it that this sets up the user defined mcode.  But I get an error when I try to post it of: 'none' is not a python callable func. I will mess more with this and also try taking out 'chmod +x M101' and will report back. But if you have any suggestions please let me know.
Best,
-Dylan
  • IronManDylan
  • IronManDylan
20 Dec 2024 21:48
Okay, okay, I see now.  Theses are not really outputs, they are really a switch (which is controlled by an output). So I'll order a buck converter to drop the 48Vs I already have installed down to the 12v I am going to use to drive things.
The naming convention on the pin is setp hm2_7i96s.0.ssr.00.out-00 0 (00 is the pin num and the lagging 0 turns the pin off).
I am going to try to get the software to boot with the proper hal code and will report back.
  • IronManDylan
  • IronManDylan
20 Dec 2024 21:03
PCW,
SSR! That worked! Thank you! Well it worked to the extent that the LED is coming on but has not turned the relay on and I am still reading 0 voltage.  I was looking through the manual, do these pins need there own power supply? If so, does it get input through one of these pins or somewhere else??
Best,
-Dylan
  • scotta
  • scotta's Avatar
20 Dec 2024 20:58
I's suspicious this is the board that Cakeslob mentioned that BTT was interesting in Remora support. STMH7x support is oh so close, just working on a updated DMA SPI logic.
  • scotta
  • scotta's Avatar
20 Dec 2024 20:52
Similarly I've had no success with any purchased CMSIS-DAP probes. I'm still using the STLink converted with the firmware in the repo. I use this for all my debugging work in MCUXpresso.
I've also had good success with PyOCD and a Pico Probe.
What errors does PyOCD give with the converted ST-Link?
  • PCW
  • PCW's Avatar
20 Dec 2024 20:02 - 20 Dec 2024 20:45
To list all mesa hardware pins:
Run LinuxCNC
Then in a a terminal type:
halcmd show all hm2
On a 7I96S the outputs 0..3 are SSRs and the outputs 4,5 are OUTMs
Note that if you created a hal/ini file set with one of the  the GUI configurators,
They "know" the output names:
  • IronManDylan
  • IronManDylan
20 Dec 2024 19:43 - 20 Dec 2024 19:43
Aciera,
Okay, I just messed with the machine for over an hour and I am more confused now than at the beginning.  I assume you are trying to get me to find the correct pin using the hal configuration tool.  Well.  I could not find the pin.  The only place that seemed reasonable was under GPIO.  I set all these pins to high using hal configuration.  Nothing I did turned my pump relay on (I was also checking with a multimeter). Btw, I got to hal configuration from the GUI, not from terminal, I assume this wouldn't change anything.. It is frustrating that there is not a document somewhere that shows the names of the pins as LinuxCNC has them named...
I am not surprised that my mcode does not make sense, are you saying that I need to remove "chmod x M101"?
Thank you.
Best,
-Dylan
Displaying 21481 - 21495 out of 21851 results.
Time to create page: 0.466 seconds
