  • Thayloreing
  • Thayloreing
16 Dec 2024 14:30
Replied by Thayloreing on topic Position Logger
Position Logger
Good morning, I'm a little curious, I didn't quite understand what you meant in this topic, could you explain it to me better?
  • COFHAL
  • COFHAL
16 Dec 2024 14:27
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I'm still lost. I'm used to using STEP SCALE in the ini to adjust the number of steps needed to move one mm. but now I don't know how to do it. For example if I need 320 steps/mm, how do I adjust the value lcec.0.D1.stepspermm?
  • spicer
  • spicer's Avatar
16 Dec 2024 14:13
Replied by spicer on topic Linux CNC auf Virtualbox Simulation
Category: Deutsch
Setze mal in der ini bei allen Joints HOME_SEQUENCE auf 0.
HOME_SEQUENCE = 0
  • onceloved
  • onceloved's Avatar
16 Dec 2024 13:54
Home position using ethercat servo position (absolute encoder value).
There is a setting in the driver to set the current position as the origin. It can be operated through the panel. I don't know what brand of driver you are using.
  • spumco
  • spumco
16 Dec 2024 13:53 - 16 Dec 2024 13:54
Replied by spumco on topic Rotary Selector Switches & Resistors
ARRGH!
Had a nice response, forum editor kicked me in the fork.  I'll try again shortly.
  • Ricoch3T
  • Ricoch3T
16 Dec 2024 13:52
Replied by Ricoch3T on topic Encoder belt
Encoder belt
Category: CNC Machines
I'm glad you were having a hard time also. I searched for a couple days before I finally decided someone here has seen these before. I had no idea what to really search for honestly.
Thanks for the link, I'm pretty sure if I can figure out the sizing these will work
  • kjlty
  • kjlty
16 Dec 2024 13:37
Replied by kjlty on topic Large File Memory
Large File Memory
Category: Other User Interfaces
I don't think plotter is a must-have feature, and if you can optimize the responsiveness of the Flex GUI to large files, then it's perfect. Thank you!
  • horcsab
  • horcsab
16 Dec 2024 13:34
Hal connection was created by horcsab
Hal connection
Category: Basic Configuration
Hi All,
Please help me!
I have promblem and I don't understand hal net command.
I always get an error in the lubrication section.
# LUBRICATION
# Oil level check
net oil_level_ok FUW400-5A-75E.gpio.26.in-not => and2.0.in1
net oil_low_warn FUW400-5A-75E.gpio.26.in-not => not.0.in
net oil_low FUW400-5A-75E.gpio.26.in-not => msg.trig
I get this error in second line: Pin 'FUW400-5A-75E.gpio.26-not'  was already linked signal 'oil_level_ok'.
If I try this:
net oil_level_ok FUW400-5A-75E.gpio.26-not
net oil_level_ok  => and2.0.in1
net oil_low_warn oil_level_ok => not.0.in
net oil_low oil_level_ok => msg.trig
I get this error message in second line: Pin 'oil_level_ok' does not exist
How do I fix it to make it work?
Thanks!
  • meister
  • meister
16 Dec 2024 13:24
that's exactly the problem, the 'high Z mode',
this is not a defined state and is susceptible to malfunctions of all kinds.
at best, you can listen to the radio on the stepper ;)
  • kjlty
  • kjlty
16 Dec 2024 13:16
Large File Memory
Deleting the plot page in QT-Designer has no effect.
  • PatJac
  • PatJac
16 Dec 2024 13:07
Replied by PatJac on topic Real-Time Kernel with Orange Pi 4 LTS
Despite all my efforts, I was unable to successfully build a real-time version of Armbian.
Same here , mainly focusing on kernel 6.12 .
Armbian forum could be a better choice as where to ask for compiling help .
opi4's should be some ok sbc to get decent latency , as some geeks & nerds do it
on less powerful sbc !!
Compiling , for me , often been a kind of hit-and-miss intimidating affair , despite it seems so obvious to some .
  • MirkoCNC
  • MirkoCNC
16 Dec 2024 13:02 - 16 Dec 2024 13:02
@ meister
Understood, but it is not the FPGA itself as it keeps the pins in high Z mode during power up and flashing until the programmed logic takes over.
Another way than just having on all pins the resistors could be just one pull-down resistor on the OE pin of the voltage translaters. It is set high / enabled by one FPGA output pin after the logic has taken over.
  • csurimilan
  • csurimilan
16 Dec 2024 12:51
Stepper motor Speed was created by csurimilan
Stepper motor Speed
Hello,
I have a question about the speed. Im using LCNC and its working good, but i want to ask someone who has more knowledge about the speed settings. Im using a Nema23 (200step/rev) with 1/32 microstepps. Motor driver is a DM556. Leadscrew pitch is 5mm. Board is a EC500 with remora software.
My Scale factor should be 1280, if im not wong.
Im trying to speed up my machine but its not that fast how i thought it will be. until 1800mm/min (70inch/min) working good but if i want to speed up to 1900mm/s or 2000mm/s (above 1800mm/s) i got an error. "Joint must be unhomed, jogged into limits,rehomed". i didnt reached any limit and if i go with a lower speed, im not getting any error.
i would be thankful if someone could light me up.
  • ABurkD
  • ABurkD
16 Dec 2024 12:26
Stefconf: Wizard stellt immer auf Simulator, wie änder ich das?
Category: Deutsch
Ah danke.
Es scheint ja fast so als ob die Beschriftung bei der deutschsprachigen Übersetzung von Stepconf schon etwas verwirrend ist.
Denn dort steht bei der untersten Checkbox nichts von simulation.
Aber es hat schon etwas bewirkt, denn nun keißt es zumindest nichts mehr von Simulator am Ende. Ich denke, dass ich noch die entsprechenden Parameter per Stepconf anpassen muss.
Displaying 21646 - 21660 out of 21928 results.
Time to create page: 0.397 seconds
