  • electrosteam
  • electrosteam
16 Dec 2024 08:43
MDI and Keyboard was created by electrosteam
MDI and Keyboard
Category: Gmoccapy
Amateur hobbyist on a 3-axis mill with RPi4 B in a single person shop.
I have just got LC 2.9.1 Gmoccapy working after using AXIS for a couple of years with just mouse and keyboard (on LC 2.8.4).
My interest is to regain MDI queuing and Run-from-Here that were lost in AXIS 2.9.1.
But, on my current system, when on-screen jogging is enabled by selecting "Keyboard Shortcuts" on the Systems Page, I cannot enter MDI commands from the keyboard.
Is it possible to setup Gmoccapy to allow both on-screen jogging and keyboard entry ?
John.
  • meister
  • meister
16 Dec 2024 06:22
now we have modifier's for all pin's:
                "enable": {
                    "name": "enable",
                    "type": "bitout",
                    "pins": {
                        "bit": {
                            "modifier": [
                                    "type": "onerror",
                                    "invert": false
seems more complicated at first glance, but is much more flexible
  • Rkatts
  • Rkatts
16 Dec 2024 04:44
Error getting packages on fresh install on Raspberry Pi 5
Category: QtPyVCP
I have Synaptic Package Manager installed. Looking forward to those files. Thanks for the help.
  • resmond
  • resmond
16 Dec 2024 03:56
Category: QtPyVCP
I just went through this a few days ago with my Pi 5.
I left a post on another thread about consider adding the RaspberryPi.com and Raspian.org entries to the appropriate lists so that the APT infrastructure works out of the box with the prebuilt Debian distributions from LinuxCNC.
I wasn't taking notes so I might have missed a step but you definitely need to add entries to the /etc/apt/sources.list and drop PGP signature files into /usr/share/keyrings.
I updated the files on my Pi but it will be tomorrow until I can get to it on the net. I'll try to upload those files and you can just drop them in. Then I would immediately install either gdebi or synaptic which are both great package managers.
  • vanquang
  • vanquang
16 Dec 2024 02:27
Home position using ethercat servo position (absolute encoder value).
Hi everyone.
Ưhile working with linuxcnc ethercat, I have some questions, hope to receive advice or comments from everyone.
1. Normally, we often use limit switches to determine "home position".
2. My idea is to use the servo motor position in "absolute mode" as "home position". That means, for example, in the xyz robot, I mark a fixed point on each axis, then move the axes to that point (this point will be the "home position"). Next, I read the absolute encoder values ​​from the ethercat servo command on the 3 axes, and get the value of "home position". So how can I implement the above idea?
Thank you very much.
  • fully_defined
  • fully_defined's Avatar
16 Dec 2024 00:41
Replied by fully_defined on topic Rotary Selector Switches & Resistors
Please feel free to correct me if I have gotten anything wrong here. This post is for future me, and whomever else may benefit from it. I will likely edit this if there are corrections.
I put together a circuit on a breadboard, for testing. I still have to set this all up in LinuxCNC, but at least I have a physical thing to work with. The white wire is GND, orange is switch position 1, blue 2, green 3, & red 4. I will use this for selecting axes: Off, X, Y, Z, and a similar thing on another switch to select x1, x0.1, x0.01, x0.001, although microns are probably a pipe dream on this machine.
Orange (1) has no conductivity to bit 0 or bit 1; 0:0
Blue (2) has conductivity to bit 0 and bit 1; 1:1
Green (3) has no conductivity to bit 0, but does to bit 1; 0:1
Red (4) has conductivity to bit 0, but not bit 1; 1:0
Now I have to figure out Mux8 for a mode switch. That's eight inputs for three rotary switches, so that leaves eight inputs left on P2, of which two are going to an MPG. Plus all of the P1 inputs.
  • Hakan
  • Hakan
16 Dec 2024 00:27
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
The thing that updates every millisecond is CommandedPosition, linuxcnc calculates a new position value every millisecond which goes to the MCU on the card. How many steps does the step generator need to make to go to that new position?
There is the scaling parameter 320 steps/mm. Say it needs to go 0.1 mm in one millisecond which is awfully fast but just an example. 0.1 *320 = 32 steps to make during that millisecond.
Another way could be to calculate number of steps to move in hal, in linuxcnc. It is not done that way. The new position, commanded positition, in machine units, is fed to the stepper driver, be it Ethercat, parallel port or Mesa card.
If you change the microstep setting on the driver itself you need to change stepspermm accordingly.
  • aikiaviator
  • aikiaviator
15 Dec 2024 23:57
To Probe Basic from Gmoccapy was created by aikiaviator
Category: QtPyVCP
Firstly just want to state, Probe-Basic looks fantastic. Credit to you guys. Way over my head, but looking forwards to getting is working.
I am slowly going through the process of building up a CNC from a mill and started my journey on Gmoccapy. I have MESA 7i96S, 7i85S and a 7i73. It took me quite a while to get it configured to run and now making progress, however, I feel Probe-Basic is on the charge and wanted to shift across to this.
I will be using xyz at this point. Have installed Debian from the Linux install iso.
My question as a newby, is what is the best approach to move across and make sure that the config that I have been able to develop is retained at east in a way that can be realistically used to help configure Probe Basic. I am happy to blow away the environment and recommence, just don't want to loos e something that can help resolve a future problem from a current working solution. What is the best approach to this.
NOTE: I did try to just process through he install, but errors occurred in the get apt code so I stopped there. I think it may be to do with root security.
  • COFHAL
  • COFHAL
15 Dec 2024 22:56
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
I still don't understand, what do I use the lcec.0.D1.stepspermm pins for?
15 Dec 2024 21:45
Replied by tommylight on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
Do you have
home_sequence = -2
for both Y joints set in the ini file?
Or -1 or -3....
  • PCW
  • PCW's Avatar
15 Dec 2024 21:42 - 15 Dec 2024 21:59
Replied by PCW on topic 7i95T convert all step/dir to PWM?
Category: Driver Boards
I'm not sure how MesaCT determines card resources.
Is this PWM setup for interfacing with PWM motor drives
and using encoder feedback?
If so, a 7I97T configuration would be close
(with perhaps some PWM frequency/mode changes)
  • Rkatts
  • Rkatts
15 Dec 2024 21:37
Category: QtPyVCP
I'm running the LinuxCNC OS provided on the LinuxCNC Downloads page:  Downloads I used rpi-imager to burn the OS onto the micro SD card for my Raspberry Pi 5.  So far the OS is working fine.  I just can't get probe basic to install.
  • CNC_ANDI
  • CNC_ANDI
15 Dec 2024 21:33
Replied by CNC_ANDI on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
yes but why? when i try ref all... it works fine...
i think probe basic ref y do only ref my y1 axis and not my y2...
i have 2 homing sensors for y
  • heathmanc
  • heathmanc
15 Dec 2024 21:32
Replied by heathmanc on topic 7i95T convert all step/dir to PWM?
Thanks for the feedback. Any tips on creating a pin file for the 7i95t firmware you sent to use in mesaCT?
  • jyeomans
  • jyeomans
15 Dec 2024 21:30
Replied by jyeomans on topic qtdragon additonal buttons
Category: Qtvcp
I wanted to make my own user tab for them. But I’m unclear how to do that, and I’m unsure whether you can use a user tab well while the machine is running in auto. I haven’t tried yet.
I was going to add them to the user buttons. But I’ve used up most of them at this point.
Down the road, I also want to learn some other things. I’m adding pneumatics to my CNC to run some hold-downs, as well as an air blast.
I had the idea to add a pressure gauge to the system so I could set the machine to pause if there was a loss in air pressure, assuming that would cause me to lose a hold-down.
Displaying 21676 - 21690 out of 21928 results.
Time to create page: 0.353 seconds
