  • Rykagon
  • Rykagon
03 Aug 2026 09:24 - 03 Aug 2026 10:06
Successful Raspberry Pi 4 Trixie LinuxCNC install.
Category: Installing LinuxCNC
Thanks very much for your knowledge and advice rodw!
I'm taking it to heart and will NOT update for now.
I'm going to continue posting progress and I hope you'll find it entertaining rather than laughable!
  • 5280
  • 5280
03 Aug 2026 09:04
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
Thanks Guys fro trying.
"the realization is " I am "OVER MY HEAD and sinking FAST
Linux / LinuxCnC.
toooo many choices and tooo many variables
in OVER MY HEAD
But thanks for trying
  • karlo.ugrin
  • karlo.ugrin
03 Aug 2026 08:33
APT - Linux CNC Post processor was created by karlo.ugrin
Category: Post Processors
Hello, I am working on a little project.So far I made it only for WinNC Sinumerik, but how usefull could this be once finished?Currently since I have just started the project, it can only do CatiaV5 aptV1.0 but Autodesk has a really good post processor open source code. Also there are some functions missing in Catia, bc I am waiuting for the GPU for my pc to arrive.The idea is to use the free APT output from Catia and translate it to needed G code.Here is the git repo, I am currently yet to finnish my website when done so it will be free to use it on.github.com/karlo-c277/APT-Gcode
  • Becksvill
  • Becksvill
03 Aug 2026 05:20
Replied by Becksvill on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
Hey tux CNC
Thanks for the feed back
This software is still getting worked on. It was just made for me but hoping to help others also.. Thanks for the feedback. And keep adding to it as you test and I'll try fix stuff if that's possible.
About the sizing yes made for axis so it's a nice fit on my screen.
  • andrax
  • andrax's Avatar
03 Aug 2026 04:52
  • Aciera
  • Aciera's Avatar
03 Aug 2026 02:59
Replied by Aciera on topic PUMA 200 Robotarm and some Hal/INI issues
It's going to very difficult to troubleshoot the basic setup by running random gcode files. You need to take a step back and simplify things so you can actually wrap your head around what is going on.
First you need to verify that your home position is really putting the arm in the pose it should be. Which means the pose shown on the drawing you posted earlier. If your flange is not correctly oriented to the base plane (ie parallel or perpendicular to your table) then you need to adjust your HOME, HOME_OFFSET values in the INI.
Once you have verified that the home position is actually correct, you can check your DH parameters by positioning the arm in different simple poses in joint mode, then switch to world mode and check if the cartesian coordinates in the DRO make sense. Simple poses would be those with joint angles like 0°,90°,180°. Make a diagram on paper, calculate the theoretical XYZ position using your robots link lengths and compare that to the XYZ values in the DRO.
Small inaccuracies are to be expected but if you have a rotation direction or a link direction wrong then your values would be way off.
  • NWE
  • NWE's Avatar
03 Aug 2026 01:19
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
hi,
with Pulse and direction top speed and precision calculus are clear  but
But how to calculate the bandwidth on a Ethercat servo drive and precision?
let say leadscrew pitch 0.100inch encoder servo 10000 ppr?
if bus cycle time is 1000000 and refClockSyncCycles=1
how to determine the top speed IPM and minimal resolution in  Inches (minimal cut).
With ethercat servo drive operating in velocity mode, your main limitation will be the servo's rated/max speed. The resolution limitation will be time based, if I'm correct LinuxCNC EtherCAT will have something like a 2mS feedback latency on a 1mS thread, so this will limit your positioning accuracy during very fast moves. I am not aware that a regular machine tool is capable of reaching this speed limit.
Here is a detailed explanation how it is timed.
  • NWE
  • NWE's Avatar
03 Aug 2026 00:50
Dual PID loops and appropriate pins for feedback to the Trajectory Planner et al
When I looked at this and it seems you have both encoders connected to index-enable.
I agree this sounds off. I suspect it will very likely always find the one index first, and I expect that to be the servo index, unless home switch is quite near to scale index. I think ideally you'd want to use only the scale index.
  • automata
  • automata
02 Aug 2026 23:36
Replied by automata on topic LinuxCNC S-Curve Accelerations
Hi all,
Attached please find a pdf describing the math for the proposed jerk limited planner to be added. It is done by AI, and I want to put it up for community comments.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
I would be happy to discuss the approach and incorporate suggestions and make modifications to this plan as the discussion evolves.
-automata
  • cmorley
  • cmorley
02 Aug 2026 19:06
I wanted to add this to our docs some where for a guide to others.
This seems wrong in my head, as it would depend on which encoder index fired first.
Any opinion or insight?
  • mediocre_chloride
  • mediocre_chloride's Avatar
02 Aug 2026 17:53
Replied by mediocre_chloride on topic Denford Orac ATC toolchanger component
Category: HAL Examples
Hi
i recently acquired a Denford lathe and am wondering if the comp is still around?
the wiki download is ending in a error 404.
The only other similar thing I found was this link:
www.machinekit.io/docs/developing/toolchangers/
But I am not sure it is the same thing.
Does anybody have access to the component from the original Wiki willing to share?
kind regards
02 Aug 2026 16:28
Replied by tommylight on topic LinuxCNC Version Question
2.9.10
Thank you for remind us to update the documentation.
02 Aug 2026 16:27
Replied by tommylight on topic DeskProto 8.1
DeskProto 8.1
Category: CAD CAM
I have a lot of questions for you, but no answer.
  • Logthor
  • Logthor
02 Aug 2026 16:14
LinuxCNC Version Question was created by Logthor
Hi all,
I just have a quick question regarding what version I should use for LinuxCNC. In your guide you say that version 2.9.8 should be used, but in the download section you say that 2.9.10 should be used. I just would like clarification on which ISO I should download and use.
Displaying 2176 - 2190 out of 11357 results.
Time to create page: 1.344 seconds
