  • Plasmanfm
  • Plasmanfm
23 Aug 2024 09:11
Replied by Plasmanfm on topic Sheetcam M 190
Sheetcam M 190
Category: Deutsch
Ok…
Verstehe ich das richtig ich habe also nur zwei Optionen im Sheetcam einsetzen oder den G-Code im Qplasmac zu änder ?
Okay...
Do I understand that correctly, so I only have two options to use in the sheetcam or to change the G-code in Qplasmac?
King regarde
Juergen
  • Moutomation
  • Moutomation
23 Aug 2024 09:07
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
thanks a lot great
  • Aciera
  • Aciera's Avatar
23 Aug 2024 08:40 - 23 Aug 2024 08:40
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Here:
  • mighty_mick
  • mighty_mick's Avatar
23 Aug 2024 08:33
What's the Oddest Machine You Have Powered with LinuxCNC
Hi Todd, can you explain what does this machine do? I didnt understand.
Thanks.
  • Moutomation
  • Moutomation
23 Aug 2024 07:57 - 23 Aug 2024 07:58
İnstall glade
Category: Gmoccapy
where is this page (I will put axis calibrations on this page)
  • Tinine
  • Tinine
23 Aug 2024 07:48 - 23 Aug 2024 09:42
Replied by Tinine on topic Retrofitting a small bending machine
Category: CNC Machines
Hi
seem to have stumbled into a little project.
I have already retrofitted my Maho MH500 and a cycle lathe to Linuxcnc
retrofitted, which is why a friend has now asked me to have a look
to have a look at his bending machine.
The press was probably retrofitted to a newer control system.
However, it has now stopped working and when I switch it on I get the error message
"WARNING LOST VIDEO TABLES"
if I google this I only find 3 forum entries, but without any answer or even a solution.
I can't say whether the controller is broken or "just" lost the programming or parameters...
In any case, I now need a replacement.
A simple 3-axis positioning controller.
The controller would only have to control 2 stops and the press stop.
all 3 axes have analog -10/+10V drives
there are probably 3 encoders somewhere for the position feedback
and that's about it.
I don't need cycles and bending programs.
If we get the 3 axes into the desired position via the control system and
then operate the press hydraulically as usual is enough...
If the machine were in my shop, I would say
Linuxcnc Raspberry, small TFT mesa card and I operate the thing via Gcode in MDI.
Maybe there is a simpler standalone solution?
What is your time frame?
This might come across as ridiculous but I can handle the whole thing on a $10 RPi Pico 2 + support devices
This chip has "PIO state machines" and I am reading 4 quadrature encoders with a maximum rate > 5M quadrature counts/sec without using any of the two cores' processing power.
One core of the RP2350 MCU handles the servo PIDs + velocity profilers and the other core handles video. Motor command is 12-bit +-10v
I have been designing/building metal forming controls (up to 21 axes) since 1988 and this is my latest development. Right now I have a bunch of CNC tube-benders to retrofit with this thing (3-axis and 5-axis) and the control development is on-going.
Just thought I'd throw it out there.
Example of one of my tube bender retrofits  Microcontroller motion system and an Android tablet (protected) front-end
  • Aciera
  • Aciera's Avatar
23 Aug 2024 07:40 - 23 Aug 2024 07:43
manual-toolchange-with-tool-length-switch sim fails mill upgraded to 2.9.2
Category: AXIS
The glade panel is outdated, there is a pull request that fixes the issue:
github.com/LinuxCNC/linuxcnc/pull/3078/files
You can also manually replace the content in 'manualtoolchange.ui' with this:
<?xml version="1.0" encoding="UTF-8"?>
<!-- Generated with glade 3.38.2 -->
<interface>
<requires lib="gtk+" version="3.0"/>
<requires lib="gladevcp" version="0.0"/>
<object class="GtkWindow" id="window1">
<property name="can-focus">False</property>
<child>
<object class="GtkVBox" id="vbox1">
<property name="visible">True</property>
<child>
<object class="GtkBox">
<property name="orientation">vertical</property>
<child>
<object class="GtkLabel" id="label2">
<property name="margin-bottom">8</property>
<property name="xpad">0</property>
<property name="ypad">5</property>
<property name="label" translatable="yes">Manual Toolchange
with Probing</property>
<attributes>
<attribute name="font-desc" value="Sans Bold 12"/>
</attributes>
</object>
<packing>
<property name="expand">False</property>
<property name="fill">True</property>
<property name="position">0</property>
</packing>
</child>
<child>
<!-- n-columns=2 n-rows=1 -->
<object class="GtkGrid">
<child>
<object class="HAL_LED" id="change-led">
<property name="margin-left">20</property>
<property name="led-blink-rate">0</property>
<property name="led-shape">2</property>
<property name="off-color">black</property>
<property name="on-color">orange</property>
<property name="pick-color-off">#000000000000</property>
<property name="pick-color-on">#c6c646460000</property>
<signal name="hal-pin-changed" handler="on_led_change" swapped="no"/>
</object>
<packing>
<property name="left-attach">0</property>
<property name="top-attach">0</property>
</packing>
</child>
<child>
<object class="GtkLabel" id="change-text">
<property name="margin-left">10</property>
<property name="xpad">5</property>
</object>
<packing>
<property name="left-attach">1</property>
</packing>
</child>
</object>
<packing>
<property name="position">1</property>
</packing>
</child>
</object>
<packing>
<property name="fill">False</property>
</packing>
</child>
<child>
<!-- n-columns=1 n-rows=3 -->
<object class="HAL_Table" id="enable">
<child>
<!-- n-columns=1 n-rows=2 -->
<property name="halign">end</property>
<property name="valign">center</property>
<property name="row-spacing">5</property>
<child>
<object class="HAL_ToggleButton" id="reftool">
<property name="label" translatable="yes">Reference Tool</property>
<property name="can-focus">True</property>
<property name="receives-default">True</property>
<property name="margin-right">25</property>
<property name="image-position">top</property>
<property name="active">True</property>
<property name="draw-indicator">True</property>
</object>
<packing>
</packing>
</child>
<child>
<object class="HAL_Button" id="changed">
<property name="label" translatable="yes">Tool change complete</property>
</object>
<packing>
<property name="top-attach">1</property>
</packing>
</child>
</object>
<packing>
</packing>
</child>
<child>
<object class="GtkFrame">
<property name="margin-left">5</property>
<property name="margin-right">5</property>
<property name="margin-top">5</property>
<property name="margin-bottom">5</property>
<property name="label-xalign">0</property>
<child>
<object class="GtkAlignment">
<property name="left-padding">12</property>
<child>
<!-- n-columns=2 n-rows=3 -->
<child>
<object class="HAL_LED" id="probing-led">
<property name="margin-right">10</property>
<property name="led-blink-rate">5</property>
<property name="pick-color-off"/>
<property name="pick-color-on">#1525ffff4fdc</property>
</object>
<packing>
</packing>
</child>
<child>
<object class="HAL_Button" id="probe-contact">
<property name="label" translatable="yes">Simulate probe contact</property>
</object>
<packing>
</packing>
</child>
<child>
<object class="HAL_Label" id="currlen">
<property name="label" translatable="yes">label</property>
<property name="label-pin-type">1</property>
<property name="text-template">Current Z length: %f</property>
</object>
<packing>
</packing>
</child>
<child>
<object class="HAL_Label" id="reflen">
<property name="text-template">Reference Z length: %f</property>
</object>
<packing>
<property name="top-attach">2</property>
</packing>
</child>
<child>
<placeholder/>
</child>
<child>
<placeholder/>
</child>
</object>
</child>
</object>
</child>
<child type="label">
<object class="GtkLabel">
<property name="xpad">10</property>
<property name="ypad">3</property>
<property name="label" translatable="yes">Tool probe</property>
</object>
</child>
</object>
<packing>
</packing>
</child>
<child>
<placeholder/>
</child>
</object>
<packing>
<property name="padding">3</property>
</packing>
</child>
</object>
</child>
</object>
</interface>
[edit]
With this there is no longer any need to change "hal_widgets.py" or "hal_python.xml"
  • Aciera
  • Aciera's Avatar
23 Aug 2024 07:18
İnstall glade
Category: Gmoccapy
If you mean the 'Calibration' program from the bottom row in the settings page of gmoccapy, that is one of the external programs common to all GUIs. The source code for that can be found in the '/tcl' folder.
  • DPFlex
  • DPFlex
23 Aug 2024 07:03
Category: AXIS
Hello,
Last time with LCNC 2.9.2, it worked.
But now I upgraded to LCNC 2.9.3, it can not work again.
Can "hal_widgets.py" and "hal_python.xml" still be ok ?.
Thank you.
  • seyad
  • seyad
23 Aug 2024 05:28
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Thank you. yeah its working now . But it doesn't contain ethercat in it, is it..?
  • cmorley
  • cmorley
23 Aug 2024 05:09
QTDragon HD spindle incrementally increase/decrease speed
Category: Qtvcp
from the docs:
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_stylesheets
press F12 an editor will show for the style sheet:
press the 'copy to edit tab' and then edit as you please.
apply to test.
Then save for next time. The view tab should show the path/filename of the stylesheet that qtdragon will use.
  • pmchetan
  • pmchetan
23 Aug 2024 03:32
Barfeeder controller upgrade for citizen L32 turning center
Category: Turning
The lathe signals are going to the PLC's I/Os.
Since I'm new to PLCs and have a few mesa card lying around, I thought, linuxcnc was a easy way.
Looks like I need to learn to program a PLC now. If anybody have the firmware for the Arteco PLC (for analog axis control) {Arteco mentions they provide function blocks for analog control or PWM} I shall try to get the existing PLC working or should I just get a new PLC. I have the schematics for the interface between lathe and bar feeder.
  • phillc54
  • phillc54's Avatar
23 Aug 2024 02:56
Replied by phillc54 on topic Sheetcam M 190
Sheetcam M 190
Category: Deutsch
One option would be to have SheetCam to not send a material change and then set the material manually before cutting.
  • Benb
  • Benb's Avatar
23 Aug 2024 01:47
Category: Turning
Quick google shows on eBay a picture of Citizen CM2-PC805-0 it's not a controller it's just a discrete IO card. The interface between your machine controller and the Arteco PLC is done true discrete IO's.
You need the schematic of your machine to be able to wire a new PLC to control the bare feeder. no need for LinuxCNC an overkill for this project.
Displaying 23446 - 23460 out of 24335 results.
Time to create page: 0.854 seconds
