  • papagno-source
  • papagno-source
19 Apr 2026 09:26
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
Good morning everyone. This is very likely the problem. I've noticed that sometimes the problem occurs on the first reboot. I start LinuxCNC, with automatic startup at system startup. If I restart LinuxCNC with the system running, the problem goes away, but sometimes it doesn't. Tomorrow I'll try to test Grandixximo's latest fix. If it doesn't work, I'll reverse the bus sequence, install the SLA and I/O last, make sure the drives are the first node, and modify HAL.
  • Hakan
  • Hakan
19 Apr 2026 08:50
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
I seems the initial delay is caused by lcec setting a bad initial reference time to the slaves.
Here is a listing of the first five lines, from lcec.write-all.
Data is cycle number, pll-err, reference clock time, application time
0 0 3536553781 142022168
1 0 3536553781 143094900
2 1629533556 2808528640 144063093
3 0 2809491813 2810488578
4 10994 2810477584 2811488510
lcec reads reference time of 3.53 second, and then sets it to 2.80 seconds. (lower 32 bits).
Now, speculating a bit, the clock is not changed right away, instead the clock is slowly changed
and the slave maintains a system time offset register 0x92c. It can then report and accurate
time by using the clock, that is off until in sync, and add the system time offset.
Must say it is speculation this though.
Anyway, the initial time setting in rt_app_main, or possibly the first few rounds in lcec_write should be looked at.
  • andrax
  • andrax's Avatar
19 Apr 2026 08:10
Replied by andrax on topic SIEG SX3.5Z Drivers EtherCAT A6 Steppers
Category: Driver Boards
was sind dort für Spindeln eingebaut Trapezgewinde oder Kugelgewindespindeln?
Wenn Trapezgewinde, dann würde ich Versuchen diese gegen Kugelgewindespindeln zu ersetzen.
Servos:
Da du scheinbar auf Ethercat gehen willst, würde ich hier zu Stepperonline raten.
Die gibt es günstig bei Amazon und sind hier im Forum gut getestet.
Die Glasmaßstäbe kannst du eigentlich ausbauen und gut aufräumen. Die Encoder der Servos sind bei weiten präziser.
  • andrax
  • andrax's Avatar
19 Apr 2026 07:45
  • emresensoy
  • emresensoy
19 Apr 2026 07:21
 CAM232 - 2.5 Axis CAM Software (First 2 Code Free, than 1$ for each)
Category: Show Your Stuff
all done, thanks
While reaching the limit before generating gcode, just had a look at the operation options. Missing essential selection for ucs, and in general a preamble to be set. It seems corner radius is missing for pocket and contour, to have smooth direction change, and desired cornerradius. Stepover as percentage of the cutter diameter is more preferable than fixed value. The contour operations have no rough dimension input? Zig zag facing, is it using stepover? And the drilling operations, eg grid drill have no selection for cycle, retract, clear z (G98)
As i was not able to test for free, this is just from looking at the interface.
  • axemas
  • axemas's Avatar
19 Apr 2026 06:51
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Thank you for testing! Found another Python 3 compatibility bug.
The function that modifies the ini file was still using old Python 2
API (io.BytesIO with str argument).
This will be fixed in the next release (2.0b-2) which I will push
to GitHub shortly.
By the way, there's a separate issue — your config folder has a
space in the name ("MILLING MACHINE"). LinuxCNC works with it, but
it can cause problems with some tools. Consider renaming to
"MILLING_MACHINE" for safety.
github.com/cnc-proton/nativecam-py3-gtk3/releases
Best,
Axemas
  • RotarySMP
  • RotarySMP's Avatar
19 Apr 2026 06:41
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
The main errors:
K0.75 is radius mode while in diameter mode.
I1 is radius mode (X34-X32) while in diameter mode
G96 D2500 ? 2500 m/min surface speed? Cutting steel with carbide  is typically only 1/10 that or less.
Maybe consider G97 S500 just to remove a variable while you are getting used it it?
Assuming a thread major diameter (stock OD) of 32, with you drive line at  X34, I-2. In practice, the major diameter is probably more like P/8 smaller. Somewhere around 31.8mm. Andy has programmed all that into his lathe macros, so you just give it major diameter (32mm) and it takes a first turning path at P/8 smaller before starting threading.
Since this is G7 diameter mode, the final depth K is also in diameter, so that will be 32-30.5 K1.5. Actually it is more likely to be about 30.38, so you will tweak this number to get your thread to fit, if you don't have perfect full profile inserts. Dont be surprised that you need around K1.62 to get the nut to fit.
J0.3 is reasonable. You will need lots of passes. See if you can get the insert to survive at J0.5
The R 1.6 means your cut will get heavier at each pass. I tend to set that at R2 for constant area, of course leading o increased number of passes.
The rest looks good.
G7 G18 G21 G90 G94
G0 X34 Z10
G97 S500 M3 M8
G76 Z-15 P1.5 I-2 K1.5 J0.5 Q29 H2 E0.75 L2
  • spumco
  • spumco
19 Apr 2026 05:05
Replied by spumco on topic REMAP: gang lathe tool orientation
You will need to have different orientations in the CAM tool table and the control tool table, but there is no auto-synching anyway, so that's not a problem.
Not that I can tell.
I set all tools to "turret 104" - i.e. back-tools - in Fusion, and make sure all tools are oriented the same way.  Fusion simulation always shows the tool above the part.  I just have to make sure spindle direction is appropriate for the particular tool.
The tool orientation value isn't passed from Fusion to the post, so the 'flip' only happens in LCNC.
I've not tested Fusion's 'turn below center' setting yet, so that behavior and post output remains to be seen.  I think if you select an OD boring tool and create an ID turning toolpath it will automatically reverse the spindle direction and output negative-X values.  Would be rather user-friendly if it works as advertised...
  • spumco
  • spumco
19 Apr 2026 04:54
Well, that works nicely with only a minor issue remaining.
Backplot display now follows actual tool orientation, according to the orientation value in the tool table.  Had to swap the orientation M-codes; was confused until I remembered I have the configuration set to BACKTOOL in the INI file (X is up/away).
What's a little odd is that rotating the WCS doesn't alter jog direction on the handwheel.  X+ moves the table up/away, and X- moves the table down/towards the operator regardless of the WCS flip.
Remaining Issue: Something is off in the remap or toolchange.ngc, because G43 isn't automatically applied despite being in the .ngc file.  G43 works in the lathe-fanucy sim, but not on mine for some reason.
Down-facing "normal" tool - T5:
Up-facing "back" tool - T2
  • emresensoy
  • emresensoy
19 Apr 2026 00:54
Thank you for your valuable feedback; I will look into each and every one of it.
  • MaHa
  • MaHa
19 Apr 2026 00:41
  • andypugh
  • andypugh's Avatar
18 Apr 2026 23:22
Category: Turning
1) To operate the contactors from a PID you could use a WCOMP HAL component. Use the "over" and "under" pins to drive the contactors and set up the max and min some small distance above and below zero to prevent hunting.
linuxcnc.org/docs/stable/html/man/man9/wcomp.9.html
2) Before looking at the G76 G-code, make sure that spindle.0.revs increases by exactly 1.0 for every rotation of the spindle.
18 Apr 2026 20:29
Had a quick look, seems OK.
  - 2 free G-Codes per day
It says 5 gcodes there, and then 1$ for every gcode.
Displaying 2821 - 2835 out of 13996 results.
Time to create page: 0.318 seconds
