  • kkuehn
  • kkuehn's Avatar
22 Oct 2026 00:10
Mesa 7i76 and 7i92 was created by kkuehn
Mesa 7i76 and 7i92
Category: User Exchange
Selling Mesa 7i76 and 7i92, good condition.
www.ebay.com/itm/327407051979
  • retrofitcenter
  • retrofitcenter
21 Oct 2026 20:09
New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
Category: Show Your Stuff
Hi all,
a quick update from the multichannel LinuxCNC project I posted about earlier (looking for testers with real machines). Everything now lives on our new site: www.cnc.gmbh
What you'll find there:
Try it online – a live test environment where you can run the multichannel system in your browser, load programs for several channels and see how the synchronisation (wait marks, channel coordination, Sinumerik-style syntax) behaves, no install needed.
Download - the current .deb packages for Debian [12/13] (amd64, [arm64]) plus the full source code. Build instructions are included.
Config generation offer, since the most common question is "how do I get my machine running with it", we're offering, for a limited time, to generate the complete LinuxCNC configuration (INI/HAL, channels, axes, spindles, I/O) for your retrofit, works for existing LinuxCNC setups you want to migrate as well as brand-new retrofits. Send us your machine data and drive/IO hardware via the form on the site, and you get a ready-to-run multichannel config.
Feedback, bug reports and especially reports from real machines are very welcome, either here in this thread or via the site.
Thanks,
Daniel
  • Todd Zuercher
  • Todd Zuercher's Avatar
21 Oct 2026 14:07 - 21 Oct 2026 14:07
Replied by Todd Zuercher on topic Jogging a 2nd Spindle
Category: AXIS
Right now I don't think there is any form of "active" spindle. There is the primary spindle which responds to commands with no spindle designation or $0 commands. And all spindle commands intended for spindles other than the primary one must be appended with with $n, where n=the spindle's designation number.
Before the addition of multiple spindle support, one of the main work arounds was to create custom M-codes to designate "active" spindles that would then receive the standard spindle commands. But that isn't how the current multi-spindle support works. In some ways I think that is almost a better way to make it work. And It still can be done this way, but it does make for a much more complicated hal configuration.
  • PCW
  • PCW's Avatar
21 Oct 2026 12:21
Replied by PCW on topic Sudden lost of Y2 slave control
Category: Driver Boards
One way to debug this might be to do a halscope plot of the homing sequence.
That is, plot the home switch states and Y +Y1 motion during a home
move.
  • scsmith1451
  • scsmith1451's Avatar
21 Oct 2026 11:34
Replied by scsmith1451 on topic GladeVCP panel fails to launch intermittently
Category: GladeVCP
Hi HansU,
I'm not sure the files are the issue since nothing has changed since the panel last functioned properly. However, I've attached both files.
Thanks for working with me.
Kind Regards,
  • scsmith1451
21 Oct 2026 11:26
Replied by scsmith1451 on topic Sudden lost of Y2 slave control
Hi PCW;
I reinstalled the boards and then verified with halshow that all of the field input switches were functioning correctly. With the spindle located in the middle of the table I started the homing sequence. Z and X both homed properly, however, when Y started the homing process a, "joint.1 failed to unhome" message was presented 3 times then joint.1 began to home while joint2. failed to move.
The machine is configured with both the Y and the Y2 axes (joint.1 and joint.2) set up with "both limits and home" switches using a single input for each axis. Thus, neither axis home switch was triggered yet LINUXCNC could not logically unhome one of the two axes.
What is the next step to resolve this issue?
Kind Regards,
  • psprindys
  • psprindys
21 Oct 2026 10:48
7i97T: isolated output LEDs glow dimly with all outputs off
Good to know. Thank you very much for taking the time to respond.
  • PCW
  • PCW's Avatar
21 Oct 2026 09:24
This is normal for the 7I97T, newer cards have had the LED indicator
circuit changed to prevent this dim glow but, the 7I97T has not had a
board revision to fix this yet, but It's just a cosmetic issue.
  • dberegovoy
  • dberegovoy
21 Oct 2026 07:43
Lathe Spindle Encoder: What are the options for EtherCAT?
Category: EtherCAT
Thanks for the advice.
What are your thoughts on using a LAN9252 + STM32F407 combination for this task?
Specifically, running the open-source SOES (Simple Open EtherCAT Slave)  repository to stream the hardware encoder count over SPI to the LAN9252.
I don't have a tight deadline or an urgent problem to fix; I am mostly interested in learning and getting hands-on experience with the EtherCAT architecture. Is this a viable and stable solution for a lathe spindle encoder under LinuxCNC, or is it not worth the hassle?
  • psprindys
  • psprindys
21 Oct 2026 07:11
Hello,
On our 7i97T, five of the six isolated-output LEDs (OUT0–OUT5, next to TB5) glow dimly whenever LinuxCNC is running, although every output is off. The brightness differs from channel to channel, and the OUT0 LED stays dark. Photo attached (LinuxCNC running, all outputs off).
Setup
  • 7i97T, firmware 7i97t_7i74d.bin; a 7i74 on P2 with a 7i70 and a 7i71 on smart serial
  • LinuxCNC 2.9.10 (uspace), hm2_eth; ssr.00.rate at the default 1000000, all invert-NN 0, all out-NN 0
  • 5 V from a Mean Well MDR-40-5 on P3: 4.99 V measured at P3
  • OUT0–OUT2 switch the logic inputs of a VFD (Control Techniques Commander CD, about 14 V open circuit, about 1 mA), with OUT+ toward the drive. OUT0 and OUT1 pass through safety-relay contacts. Nothing is connected to OUT3–OUT5.
Measurements (ohmmeter, red on OUTn+, black on OUTn−; VFD unpowered, safety-relay contacts open)
  • All outputs off: OUT0, OUT1, OUT3, OUT4 and OUT5 read O.L. That holds both while the LEDs glow and with ssr.00.rate set to 0, when the LEDs go dark.
  • OUT3 commanded on: 0.3 Ω (the meter leads), LED fully bright. Off again: O.L, back to the dim glow.
  • The LEDs are dark before LinuxCNC starts, and go dark when it exits or the watchdog bites.
  • Two days ago, with the VFD powered and the outputs off, its inputs on OUT0–OUT2 read their full open-circuit voltage.
Questions
  1. Is a dim glow on the output LEDs with the outputs off normal for the 7I97T? Or does it point to a damaged output driver?
  2. If it is damage, can it get worse? Could an output that is off start to conduct? Is there a further test you would suggest?
Thank you.
  • tuxcnc
  • tuxcnc
21 Oct 2026 06:57
TTC3018 Pro for small hobby projects - real accuracy on wood/acrylic and LinuxC
Category: CNC Machines
In a nutshell:
All small Chinese milling machines based on 10 or 12 mm shafts and TR8 screws should be considered working models at best.
They have a lot of educational value and zero practical value.
Of course, there are worse and better models, but all of them have problems with stiffness, vibrate and have irremovable backlash.
Any attempt to improve anything in them is a waste of time and money.
The GRBL driver is the least of your problems. Code written for GRBL can be executed on LinuxCNC without any changes (it may or may not work the other way around).
To be usable, a milling machine must have linear rails, ball screws, and a rigid metal frame. With a budget of USD 1,000 you can find something.
  • tuxcnc
  • tuxcnc
21 Oct 2026 06:17
Replied by tuxcnc on topic Bug in G12.1
Bug in G12.1
many further changes are currently in testing and will hopefully be merged step by step into master over the coming months.
I'm afraid this won't be a solution for me, just replacing one problem with another.
forum.linuxcnc.org/ethercat/59324-lcec-c...c-2-10-and-debian-13
The changes in the master branch have gone way too far. You should wait until version 2.10 is finished before rewriting the basic code. Now it's the case that code written a month ago will not work with LinuxCNC compiled today. If it continues like this, no one will control it...
For now, I would like to stay with the version compiled on September 26, i.e. with working Ethercat.
I know how to deal with changing limits and I wrote the appropriate m-codes yesterday and changed existing M428 and M429.
#!/bin/bash
halcmd setp ini.x.max_limit 1000
halcmd setp ini.x.min_limit -1000
halcmd setp ini.y.max_limit 1000
halcmd setp ini.y.min_limit -1000
halcmd setp ini.z.max_limit 1000
halcmd setp ini.z.min_limit -1000
# Filename: M166
#!/bin/bash
halcmd setp ini.x.max_limit 146.0
halcmd setp ini.x.min_limit -86.0
halcmd setp ini.y.max_limit 178.0
halcmd setp ini.y.min_limit -178.0
# Filename: M167
; Filename: M428.ngc
; by remap: kinstype==1 (xyzab-tdr kinematics)
o<428remap>sub
  #<kinstype> = 1        ; xyzab-tdr
   G12.1 P#<kinstype>                   ; select kinstype, syncs interp and motion
o2 if [[#<_task> EQ 1] AND [#<_kins_type> NE #<kinstype>]]
     (debug,M428: Wrong kinematics type)
     (debug,STOP)
     M2
o2 endif
m166
o<428remap>endsub
M2
; Filename: M429.ngc
; by remap: kinstype==0 Identity kinematics
o<429remap>sub
  #<kinstype> = 0
   G13.1                                ; back to identity kinematics, syncs interp and motion
     (debug,M429: Wrong kinematics type)
     (debug,STOP)
     M2
o2 endif
m167
o<429remap>endsub
M2
It can also be solved differently.
It's workable for now.
  • Aciera
  • Aciera's Avatar
21 Oct 2026 02:33 - 21 Oct 2026 02:37
Replied by Aciera on topic Bug in G12.1
Bug in G12.1
This is a limitation of the current implementation. See the millturn sim config on how to switch the limits using the 'ini' halpins when switching the kinematics. Note that this workaround is crude and will basically only allow to expand the limits to avoid false soft limit errors.
There is currently major work underway to give linuxcnc proper multi axis capabilities, including proper limits handling. The G12.1/ G13.1 codes are part of this work and many further changes are currently in testing and will hopefully be merged step by step into master over the coming months.
github.com/LinuxCNC/linuxcnc/pull/4374
  • HansU
  • HansU's Avatar
21 Oct 2026 02:10
Replied by HansU on topic Themes
Themes
Category: Gmoccapy
But today a serious problem arose and I had to look into it
I wouldn't call an incorrect syntax highlighting a serious problem =)
The second image is in program execution mode. Why the hell do the parameters change from black to gray,
It's because editing is disabled while the program is running.
And if this is the case, why is the default g-code theme set to "classic" and not "gcode"?
What of the classic G-code theme do you dislike in detail?
  • rodw
  • rodw's Avatar
20 Oct 2026 23:25
Replied by rodw on topic Jogging a 2nd Spindle
Category: AXIS
I'd report that as a bug, somebody might change it to act on the current spindle as they have been out for a while...
Displaying 286 - 300 out of 11392 results.
Time to create page: 0.150 seconds
