  • jetbadger
  • jetbadger
15 Apr 2026 06:32
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
I guess my question now would be: Why are there relatively huge steps in the commanded position?
That's exactly the issue I can't get rid of. This is just with G0Cxx commands. I'm suspecting if I zoomed in the second plot enough it would look the same just at higher frequency. For example when homing it acts fine but that's probably because the commanded position is instantly much different and the PID loop takes care of reaching it. But here the commanded position supposed to trail ahead by some degree to let the PID do it's thing I suppose and it just doesn't seem to work with the joint either reaching the position and output going to 0 and then falling behind and shooting up, rinse and repeat... If I lower the P ratio to where it trails just behind, the commanded position slows down aswell eventually leading to coarse steps like before.
I finally checked your drive manual.  Your drive can handle 4mhz pulse input when using differential signals.
If your drive is set to the default input of 10,000ppr (parameter P0.22), and you want ~4100rpm (motor) for 6000rpm (spindle), that means your maximum pulse frequency will be ~680khz.
Tuning or inertia issues aside, it also results in a fairly coarse positioning resolution of 19 pulses per degree.
You could increase the drive positioning resolution by a factor of 4 without running in to the drive's (or Mesa's) input frequency limit.
I'm aware that the motor is not exactly right for this, however it was already on there before me. It's the same one from the manual with 1500rpm rated speed, making for a pretty slow spindle. The 4MHz value is what I had in mind when figuring out the pulse widths and so on, I admit though I forgot about the motor rating, but for now in spindle mode I only had it in the hundreds range and in axis mode it's even slower. I will try increasing the resolution and see, thanks. :)
  • dm17ry
  • dm17ry's Avatar
15 Apr 2026 05:52
Replied by dm17ry on topic HAL component for tangential knife
Category: HAL
why not just align the C axis with the last segment of the trajectory? with trajectory blending on that worked okish for me on a leather cutting machine.
github.com/yur7aev/linuxcnc/blob/nyx2.8/...ponents/tangent.comp
  • bedouno
  • bedouno
15 Apr 2026 02:59
Replied by bedouno on topic HAL component for tangential knife
Category: HAL
dear sir , i hope i can explain my idea in accurately , and hope it is usefull, what if we index the code data vector sent from the interpreter to the motion controler , like a sequence segment to force the motion controller to attach and trigger the heeding calculations to the segment without override , sure ther might be some data or technic in the strcure would be helpfull without adding a new data field
  • rodw
  • rodw's Avatar
15 Apr 2026 02:52
Replied by rodw on topic HAL component for tangential knife
Category: HAL
I have not been able to review this further today but
In the interpreter I have added a couple of procedures here that calculate the headings
github.com/rodw-au/linuxcnc/blob/state-t...erp_convert.cc#L7080
tag_straight has a debugging print line that is correct. There is a simple gcode file here that draws a square
github.com/rodw-au/linuxcnc/blob/state-t.../nc_files/testg2.ngc
and the output in the print statement is perfect.
But the values are altered before it gets to the pins so I wanted to repeat the debugs with these files.
But look at that, I am not calling
write_canon_state_tag(block,&_setup);
in tag_straight. Hopefully that is what's missing. I've hacked into this procedure so much, I had a clean up that went too far...
the block is written to state tags in
github.com/rodw-au/linuxcnc/blob/state-t...4ngc/interp_write.cc
both the block and the tags
the heading for the arc is calculated in motion at
github.com/rodw-au/linuxcnc/blob/state-t...tion/control.c#L2230
We need to do that because the interpreter tags are static for the life of the segment but on an arc, we need to calculate the heading at the point on the circle at every call of the servo-thread. It seems to be working but I have not validated the data.
Good luck!
  • NWE
  • NWE's Avatar
15 Apr 2026 01:57
retrofitting a Proxon for coin die milling
Category: Milling Machines
ballscrews ar primary because the original threads in brass nuts have quite some deadway.
Just so you know, LinuxCNC has backlash compensation parameters. That said, I'm not real sure milling dies would go well with backlash. I used to have a diy CNC router with cheap ACME screws, running LinuxCNC + parport + microsteppers. I did more drilling than routering with it, drilling the thru-holes in home-brew PCBs. On that machine, backlash compensation was the ticket.
  • spumco
  • spumco
15 Apr 2026 01:34
Replied by spumco on topic Lathe C axis homing
Lathe C axis homing
The drive is at 10000 PPR and around 1.45:1 spindle:motor overdrive, from my calculations 6k rpm spindle speed is around the limit.
However...unless I'm looking at the wrong manual - or you have an unlisted motor - the 5.5kw servo is advertised as having a max speed of 2000rpm.
Do you have a different motor/drive than is listed in the manual?  If not, I'm not sure that motor is going to do what you want in spindle mode.
  • bedouno
  • bedouno
15 Apr 2026 01:28 - 15 Apr 2026 02:23
Category: HAL
sir , i am sure of hoe good teacher you are that i follow your work
i see that you are doing very well in your path and sure you will solve the problem , i am trying to think systematically when i say that the loss of the data may be because deffirent time frams between the sender and reciever or the sequencing -sorry about the terms are not accurate , i am a beginner- hope this might help , it is enough to me now to run a customed component to do the job , i am struggling to make it , its performance like mach3 feature is great now , i hope you help me to do such component , i have just made one and compield it but it crashed because of syntax error , i used a c code with primary approach
angle = atan2(y-vel, x-vel)
y-vel = y-vel + y-acc * dt // dt = fperiod
x-vel = x-vel + x-acc * dt // dt = fperiod
for open loop machine - stepper motors
  • PCW
  • PCW's Avatar
14 Apr 2026 23:23
Replied by PCW on topic Lathe C axis homing
Lathe C axis homing
  • MaHa
  • MaHa
14 Apr 2026 23:09
Replied by MaHa on topic Probleme mit G Code...
Die 2 files liefen in meiner Simulation fehlerfrei. Sogar bei Radius Toleranz auf null gesetzt.
[RS274NGC]
#CENTER_ARC_RADIUS_TOLERANCE_MM = 0.00127
Bezüglich den % am Anfang/Ende ist noch diese Info verfügbar:
Using % to wrap a G-code file will not do the same thing as using a program end. The machine will be in what ever state the program left it in using %, the spindle and coolant may still be on and things like G90/91 are left as the last program set them. If you don’t use a proper preamble the next program could start in a dangerous condition.
  • rodw
  • rodw's Avatar
14 Apr 2026 22:57
Some people run the pi4b with a slower servo thread eg 2 ms or 1.5 Ms with mesa cards
run:
latency-histogram  --nobase --nobase 1000 --show
and share the screenshot here. the 4b is marginally OK but 126us is fine for a Mesa card at 1 ms servo thread.
  • Sierevello
  • Sierevello
14 Apr 2026 22:34
Replied by Sierevello on topic In Need of 3 axis mill sample program
No. The tool change position has to be commanded in the Gcode. The tool change on this mill is manual.
Thank You!
-Steve
  • 0x2102
  • 0x2102's Avatar
14 Apr 2026 22:11 - 15 Apr 2026 11:16
Replied by 0x2102 on topic Ethercat, CIA402, Yaskawa Sigma-X
Category: EtherCAT
This might be still related to the fact the Yaskawa does not support LRW
github.com/sittner/linuxcnc-ethercat/issues/121
forum.linuxcnc.org/ethercat/48110-etherc...-responding?start=20 (there seems to be a patch / experimental code further in the thread)
Not sure if this was ever resolved in any linuxcnc-ethercat version.
  • jetbadger
  • jetbadger
14 Apr 2026 22:03
Lathe C axis homing
I have these snippets right now. The first is the original behaviour and the next one is after a full day of tweaking the PID values and acceleration. In both the axis moves very slowly.
  • spumco
  • spumco
14 Apr 2026 21:55
Replied by spumco on topic In Need of 3 axis mill sample program
You could send them one of the sample programs that is installed with LCNC.  Like chips.ngc.
Keep in mind that your tool changer is going to be specific to your machine and LCNC configuration, especially if the tool change sequence requires anything beyond "M6 Tn G43" in it.
Example - does your machine require the post to raise the head to a safe point before the tool change M-code is commanded, or is that part of the internal change sequence?
Same for any custom or machine-specific M-codes.
  • 0x2102
  • 0x2102's Avatar
14 Apr 2026 21:07 - 14 Apr 2026 21:08
Replied by 0x2102 on topic spindle-at-speed
spindle-at-speed
Category: Deutsch
Ich wuerde sagen du schaust dir Parameter P04.04 an. Laut Chinglischer Anleitung steht da sowas wie: "3 : When any frequency arrives, it will be powered, otherwise it will lose power (related to the setting of P02-10)"
Frei Plattdeutsch bedeutet das soviel wie:
Wenn P04.04 = 3 (Frequenzvorgabe erreicht) dann schaltet das Relay.
Verdrahtung:
Du nutzt NO (normally open):
• VFD CM → 24V Versorgung (+) anlegen
• VFD NO → Mesa Input (z.B. IN05)
• Mesa GND bleibt wie gehabt
Waehle einen freien Input an der Mesa und verdrahte.
In deiner HAL kannst du das dann verbinden:
net spindle-at-speed hm2_7i96.0.7i96.0.0.input-05 => spindle.0.at-speed
Der Input ist nur ein Beispiel. Schau was du frei hast bzw. wie genau der Input bei der 7i96 heisst.
Displaying 2971 - 2985 out of 13997 results.
Time to create page: 0.415 seconds
