  • DerKlotz
  • DerKlotz
12 Mar 2026 09:03
  • masawee
  • masawee
12 Mar 2026 08:10 - 12 Mar 2026 08:11
Replied by masawee on topic Trying out LinuxCNC on Raspberry PI5
but normal need use WHITOUT this expensive hat , only gpio pin out and shift level converter can use 3,3V gpio pin to out 5V and traight to driver step and dir and enable pin.
how this made if ewer newer not has understand anything code nd not understand what need doing code, understand only good all hardware how connect and build,
i have rpi4 and SD card have linuxcnc rpi4 image, working and boot ok, (whit HDMI display) but not boot whit pi hut mikro HDMI to vga cable.
how make this gpio pins can take out gpio pin to driver DM556. were can download setting hal and ini file or what need add to rpi4, normal peoples NOT can understand and write hard code to rpi, hal or ini or what possiple need doing, not know.
i just buy rpi4, paraller port BOB, cheap chinese 10$ board, encoder, rotary SW, shift level converter modules, 3,3V to 5V, all buttons, DM556 drivers, nema 23 470 OZ/3Nm motors, lot hardware but not can made code anything.
help need send to me files what need copy and paste to rpi4 linuxcnc and were folder need add. not know were and what and how.
  • grandixximo
  • grandixximo's Avatar
12 Mar 2026 01:54 - 12 Mar 2026 02:01
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
hey guys
just wondering whats the latest on this.
cheers
andrew
Still work in progress
github.com/LinuxCNC/linuxcnc/pull/3807
you can read above, if anyone wants to test what's done so far, they can download the debs from github build artifacts
github.com/LinuxCNC/linuxcnc/actions/runs/22982518117?pr=3807
the above is today's build, scroll to the end of the page for the debs for the different systems, I think I got it to the point where it is in a good enough state for sim testing by the community
To test it set planner type 2, I have included a zip file in this post with my testing settings for planner type 2.
YangYang is refactoring the code, he put planner type 1 on pause because there are certain limitations with TP1 implementation, he cannot reach high speed on short segments.
TP2 will be the general base idea, but much needs to be refactored, the feed override needs to be reworked, kinematics TP and RT servo-thread need to be reworked, there is talk in the github about this, any extra mind is appreciated.
At the moment TP2 generally works, what's still missing from my implementation is spindle sync, I never tested probing or adaptive-feed.
as far as running gcodes and MDI, I believe everything works, but it is far from hardened, it is just me doing testing in a sim, if you put it on your machine, it is at your own risk, play with it in the sim, and let me know how it goes, here, in the gihub PR, or even on my github fork.
  • grandixximo
12 Mar 2026 01:40 - 12 Mar 2026 01:42
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
They are same
github.com/grandixximo/linuxcnc-ethercat
this just has one small optimization
dc-phased is latency dependent, can you plot in halscope, app-phase, pll-error, and servo thread?
12 Mar 2026 00:14
Replied by tommylight on topic MPG Pendant
MPG Pendant
No.
USB pendant goes to USB on PC, not to Mesa.
  • LXcncforthewin
  • LXcncforthewin
11 Mar 2026 23:53
MPG Pendant was created by LXcncforthewin
MPG Pendant
If i get a USB pendant, do i need to have an MPG interface on the controller board? (like the Mesa 7I76EU) or can i just use the USB communications into the LinuxCNC PC? Not sure if i need to connect the pendant to the PC or to the controller.
Any help would be appreciated.
Thanks.
  • rodw
  • rodw's Avatar
11 Mar 2026 22:12
Machine choice for composite panel CNC + probe-driven XY/Z G-code compensation
Category: Milling Machines
In Europe, try Grotius Machine Tools, the owner is well known on this forum
  • rodw
  • rodw's Avatar
11 Mar 2026 22:06
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
The Linuxcnc installer uses Bookworm (V12)
The Debian installer is currently Trixie (V1 3)
Trixie has better uefi support at boot
Linuxcnc installer uses Debian's Live Build which is the same as what Debian uses so its odd
so install Debian Trixie and type sudo apt install linuxcnc-uspace linuxcnc-uspace-dev to get v 2.94 (missing a few minor bug fixes)
Install Debian Sid (aka testing) do the same and get v 2.97 (missing one minor bug fix)
Follow this process  on Trixie or Bookworm and then follow the steps in the docs here to get 2.98 (current version)
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
  • Badger1875
  • Badger1875
11 Mar 2026 21:52 - 11 Mar 2026 21:52
AI generierter G-Code wird in LinuxCNC völlig verkrüppelt dargestellt...
Category: Deutsch
Der verwendete Zeichensatz war UTF-8 und ich hatte auch mehrere Editoren ausprobiert, Überall wurde der Code passend interpretiert. Gedit direkt in Linux hat ihn auch ohne krytische Zeichen richtig angezeigt, nur im maschineneigenen G-Code Fenster kamen dann die wirren Zeichen zum Vorschein.
Ich hab mir anderweitig auch noch Hilfe geholt, und wir haben den Fehler gefunden.
Wie schon richtig vermutet, war ein Sonderzeichen Schuld an der Misere...
Allerdings nicht unsichtbar, sondern offen im Code zu sehen:
'-' ist im Editor klar zu lesen, aber effektiv gibt's da 3 Varianten davon, den Geviertstrich, den Halbgeviertstrich und den Bindestrich. Der letztere ist in der Darstellung ein Minus-Zeichen. Da die AI in den meisten Fällen (außer sie wird direkt aufgefordert ein anderes Format zu nehmen) Textfiles so generiert, dass sie für digitale Druckvorlagen genügen, kommt je nach Zusammenhang im Text, der Geviertstrich, vielleicht auch als 'em-Slash' bekannt, zur Anwendung.
Auf den ersten Blick fällt das nicht auf, aber wenn man ihn dann unmittelbar neben einem Minuszeichen sieht, kann man den Unterschied erkennen.
Ich hab dann meine Schnipsel diesbezüglich geändert und seitdem funktioniert es so wie es sein soll.
Danke für eure Hilfe und Gedanken!
Freddie
11 Mar 2026 21:08
I downloaded the official Debian installer image (not the LinuxCNC specific one) and it ran and installed absolutely fine, didn't even complain about missing firmware, grub installed fine, and it didn't even hiccup once.
That is/was my next question/tip/request/advice! :)
Thank you.
11 Mar 2026 21:04
1. had good and bad experience with some of those companies, and almost (almost) always the machines are made in china.
-Some German companies have smaller machines that are good and do what they advertise, cant recall company names
-i know of a German company that sells machines made in 2024 using RS232 communication to PC (to damn old controller, still being made), it works, i would not sell nor buy such a machine because of that, although mechanically it is nice:
forum.linuxcnc.org/show-your-stuff/55825...ial-connection-to-pc
  • Xnke
  • Xnke
11 Mar 2026 20:58
CSM enabled does not make any difference for my install when using the LinuxCNC live USB image.
From here, I'll follow the normal install instructions for installing the preempt-RT kernel and linuxCNC from packages.
  • Becksvill
  • Becksvill
11 Mar 2026 20:34
Replied by Becksvill on topic LinuxCNC S-Curve Accelerations
hey guys
cheers
andrew
  • spicer
  • spicer's Avatar
11 Mar 2026 19:35
Category: Deutsch
Kannst die ngc bitte mal posten?
Ich vermute, dass das mit dem verwendeten Zeichensatz zutun hat (es sollte UTF-8 sein).
  • Badger1875
  • Badger1875
11 Mar 2026 19:32 - 11 Mar 2026 19:32
Category: Deutsch
Jaja meister,
so mag das sein...
...wenn man aber als Autodidakt von Null anfängt, ist es glaub ich durchaus normal, sich Beispiele zu holen und was liegt heute näher als die KI?
Sich dann aber mit dem Problem auseinanderzusetzen und versuchen den Fehler zu finden ist die logische Schlussfolgerung.
Auf die Spur mit den Sonderzeichen bin ich selber schon gekommen, da der gleiche Code, nur handgeschrieben, funktioniert. Da Du nun da gleiche sagst, werd ich mich in dieser Richtung mal weiterbewegen...
Freddie
Displaying 4291 - 4305 out of 14024 results.
Time to create page: 0.805 seconds
