  • JT
  • JT's Avatar
20 Feb 2026 21:59
Proposal to improve forum stability and structure
Category: Forum Questions
Log in to SSH, start "top" and monitor CPU usage and see if "log" appears often near the top of the screen.
If high CPU usage and no logs = DDOS
If both = brute force = someone trying to find user passwords using automated software
We had no brute force for quite a while as the result of that was the influx of existing member accounts being hijacked and used to post spam.
Or also possible, users using stronger passwords so much harder to crack. This is highly likely as nowadays wherever you register there are several warnings to use stronger mixed passwords.
The CPU usage is back to normal right now.
JT
  • NWE
  • NWE's Avatar
20 Feb 2026 21:47
Maybe install btop, then you can watch a lot more stuff, including network and disk usage. When I learned of btop, I pretty much dropped using top because btop is sorta nice. sudo apt install btop
hope that helps
20 Feb 2026 20:36
Replied by tommylight on topic Proposal to improve forum stability and structure
  • snowgoer540
  • snowgoer540's Avatar
20 Feb 2026 19:38
Replied by snowgoer540 on topic QTPLASMAC integrated cad/cam
Category: Plasmac
It really seems to me like you are confusing what QtPlasmaC does and what the conversational inside of QtPlasmaC does.
QtPlasmaC does control the Z axis on its own, with exceptions being things like turning the THC on and off via g-code.
QtPlasmaC does not add lead-ins
QtPlasmaC does use the material feed rates
QtPlasmaC Conversational can add lead-ins if you so choose. It is also set up so that the material you have selected when creating the conversational file will be the material used for the generated g-code, thus using its feed rates.
QtPlasmaC is not a CAM package at all. Nor was its included conversational intended to be a replacement for a good plasma CAM package. It's there for convenience only.
This kindof makes a mess if you want to use sheet cam or something similar.
I suspect this view point to be a result of your inexperience with Plasma cutting. I create all of my cut jobs using g-code provided by SheetCAM. It's not a mess at all, and allows for great control of cutting.
aswell as theres not really a great way to run sheetcam via linux as far a i know.
Is the download link at the bottom of this link too convenient?
sheetcamshop.myshopify.com/pages/download-sheetcam
SheetCAM in Linux works fine.
  • RobC
  • RobC
20 Feb 2026 19:31
Replied by RobC on topic Poll to See Who Still Uses RTAI
I still use RTAI - not on cnc comp so I don't remember the version (likely one from 2023 or 2024)
  • 2tinker
  • 2tinker
20 Feb 2026 18:48
Replied by 2tinker on topic AMB FME-U 1400 DI
AMB FME-U 1400 DI
Category: Deutsch
Hmm... eine seltsame Antwort.
Erinnert mich an Äpfel und Birnen.
Aber erst einmal danke dafür.
Falls jemand noch etwas über den genannten AMB Motor zu berichten hat,
würde mich das helfen.
  • Avion
  • Avion
20 Feb 2026 18:21
retrofit of an existing CNC - tool sensor and 3d probe
Category: CNC Machines
oh yes, nice thank you. I did search for it but as usual, internal search did not like my keywords.
Thanks man, i will read through. My goal is to finish the primary portal CNC retrofit and to finally build my large custom 4 Axis wirecutter ;) But before I delve into that i want to have flushed out the processes and issues on the cnc and mesa and linuxcnc to fully understand everything.
BTW: What helps most if I basically have concrete issues. Shall i share configuration files or something? I don't want to dump blindly stuff ;D
  • snowgoer540
20 Feb 2026 17:47 - 20 Feb 2026 17:55
Is this QTPlasmac Expected behaviour - Cycle Start and Jog disabled.
Category: Plasmac
-what should i monitor for the issue where the machine moves to a cut position and just stays there? This happens sometimes even when doing a manual cut where pressing F9 shows the machine running on screen but nothing moves. DRO does not change, machine state does. Again this happens a lot on QtPlasmaC, do not recall this happening on PlasmaC so might be a QT thing.
Again, I'd want to know if motion.eoffset-limited goes true when this occurs. I am also curious what state it's stuck in, so I would want you to turn on plasmac.debug-print before starting any cutting, etc. and copy and paste the terminal output from when it hung up.
The following commit will catch any commanded motion that would put the offending axis outside of the eoffset limits (soft limits) - this precludes you from having to monitor motion.eoffset-limited:
github.com/LinuxCNC/linuxcnc/commit/d179...e54c97ccc2bc0c58bf34
The following commit will catch any z-motion state transition issues (z-motion stalls in the same state for more than 3 seconds):
github.com/LinuxCNC/linuxcnc/commit/e2f0...30feba767f8588b2f28e
If you should encounter either of these error messages, please comment here with a recent backup of your QtPlasmaC config made from the SETTINGS tab, and the g-code file you were attempting to cut.
  • Dudelbert
  • Dudelbert
20 Feb 2026 17:28
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
I’m not sure how many encoders it showed on that page, I will confirm tomorrow. And thanks for the idea with the dummy config.
I will try getting it running tomorrow.
  • PCW
  • PCW's Avatar
20 Feb 2026 17:19
Category: Turning
If I run discovery on a 7i92t_7i85x2d config I get:
with all 4 encoders on P2
Does pncconf show2 all 8 encoders on the configuration page? like this:
( These should be adjusted to the actual number required to avoid wasted transfer/processing time)
For the 7I83 I suspect the easiest current way to add the hal interface code is to make a dummy configuration
for a 7I77 configuration and copy paste the analog hal an analog section from that as an example
(changing the 7i77 name to 7i83 and the sserial channel number as required)
  • JT
  • JT's Avatar
20 Feb 2026 16:58
Also, from time to time the forum has high CPU usage that slows down the forum but I don't know why.
DDOS and "brute force" attacks, from what i gathered.
Just got another one from 9:03 to 10:40 Central time.
JT
  • AlessandroEmm
  • AlessandroEmm
20 Feb 2026 16:57 - 21 Feb 2026 10:31
  • Dudelbert
  • Dudelbert
20 Feb 2026 15:24
Category: Turning
Hi, I have a bit of a problem getting my initial LinuxCNC config up and running. I’m using a 7i92T (flashed with 7i92t_7i85x2d.bin) connected to a 7i85 and multiple Smart Serial cards (one 7i83, two 7i84, and one 7i73).
I tried getting it configured with PnCconf, aided by this post concerning unlisted Mesa boards:
forum.linuxcnc.org/39-pncconf/52554-disc...ted-mesa-fpga#299687
This mostly worked as expected, but I have two problems. One is that only two of the four encoder interfaces of the 7i85 are shown (this would be okay for now), and I cannot choose the 7i83, which means I am unable to have any PWM channels.
This means I cannot configure the X and Z axes, and because of that I cannot finish the configuration.
I am definitely doing something wrong. If anyone knows what that is, I would be extremely happy if someone could tell me where I am going wrong.
I also attached some pictures of what I am seeing right now.
  • michaeln
  • michaeln
20 Feb 2026 14:14 - 20 Feb 2026 14:32
Replied by michaeln on topic G-code wizard für Gmoccapy
Category: Gmoccapy
Hallo,
ich denke NativeCAM ist aktuell das was deinem Wunsch als ShopMill-Alternative am nächsten kommt.
Da gibt es ja im Forum einen längeren Thread wie man das zum Laufen bekommt. Zudem gibt es mittlerweile mehrere Github-Forks von NativeCAM.
Wenn es da aktuell nur um Drehen geht, ist dieser Thread trotzdem interessant:
forum.linuxcnc.org/qtvcp/58056-latheeasy...-programming?start=0
Da stellt cmorley seine QT-Portierung von NativeCAM vor.
Die Frage ist ja ob die Entwicklung in diese Richtung noch so wichtig ist bzw weitergeht, da es mit FreeCAD ja mitlerweile ein sehr gutes CAD-System gibt (das deutlich mehr kann) welches direkt auf dem LinuxCNC-Rechner läuft.
Viele Grüße
Michael
20 Feb 2026 14:13
Displaying 5161 - 5175 out of 14030 results.
Time to create page: 0.390 seconds
