  • andrax
  • andrax's Avatar
17 Jan 2026 02:36
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
I use cat5e 1m and 0.25m.
Is that the problem?
  • endian
  • endian's Avatar
17 Jan 2026 02:22
  • harindugamlath
  • harindugamlath
17 Jan 2026 02:20
Replied by harindugamlath on topic How good is Ethercat motion control?
Category: EtherCAT
Thanks. I have two machines that run Linuxcnc l. one with 3 parallel ports and running a production job. Other is an old but workhorse of a mill that run the mesa setup. Both are used daily. I'd say I'm good with Linuxcnc but first time using ethercat.
Servos that i choose are beefy. 3kw on x and y and 4.5 on z. Machine is worth saving as it's in near perfect condition. No backlash or spindle runout.
Do you know how the ethercat control loop actually works?
  • Aciera
  • Aciera's Avatar
17 Jan 2026 01:49
Can my account and post history be deleted please
Category: Forum
your user profile has been deleted.
  • RotarySMP
  • RotarySMP's Avatar
17 Jan 2026 01:26
Replied by RotarySMP on topic I got a medal!
I got a medal!
Congratulations Andy. Well deserved. Your efforts and support have been invaluable to this community for years.
Cheers,
Mark
  • abcdefg
  • abcdefg's Avatar
17 Jan 2026 01:14
Category: Forum
If full deletion isn’t possible, could you please anonymise my account.
  • rodw
  • rodw's Avatar
17 Jan 2026 01:11
Replied by rodw on topic Cloning LinuxCNC - Axis and Mesa 7196s
Category: Installing LinuxCNC
Sometimes, I have set up a basic working machine ignoring the motion parameters. Once I have any motion working, I cut and past the tried and proven motion from the old config to the new one.
But if they are the same, just copy the folder.
  • rodw
  • rodw's Avatar
17 Jan 2026 01:01
Replied by rodw on topic How good is Ethercat motion control?
Category: EtherCAT
In my experience, Erhercat is no different in performance to Mesa cards. In fact, I found I had to reduce acceleration and max velocity because my motors drove so hard but could not overtake inertia on stopping with Ethercat motors because of the mass of the table and following errors were happening. I just put that down to the normal tuning process as I was asking for speeds too high for machine physics and the motors delivered what I asked for. I would say Ethercat is not for the novice although some novices conquer it. This is because there is the additional complexity added by the Ethercat layer.
The plus side is the Ethercat wiring is a lot simpler.
I would recommend cia402 compatible drives.
With a machine under your belt its is worth considering.
  • harindugamlath
  • harindugamlath
16 Jan 2026 22:50
How good is Ethercat motion control? was created by harindugamlath
Category: EtherCAT
I'm looking forward to retrofit an new to me Okuma MC30-VA mill. I already have another okuma will with a Mesa setup that's been a workhorse and never skipped a beat for the last 3 years. It uses Delta ASDA A2 servos (Incremental with home switches) and it's been incredibly accurate and repeatable with properly tuned servos. Even 3D surfacing at high speed, it handles like a champ.
So I need to use absolute servos for this new machine. Looking at delta ASDA A3 servos as the drives have Ethercat support.
My main concern is not the price of Beckhoff modules. I'm curious to know how the ethercat setup handles the motion control part. In mesa we get the FPGA base step/dir signals and I read the ethercat system uses a target position. So I guess the control loop is closed on the PC with the encoder feedback from the motors. So how fast can you really push an ethercat system without running into following errors and latency errors etc.? I mean like in high speed 3d surfacing ?
Can anyone offer some advice on which system should I go with or point me to some user experiences?
This machine is in excellent shape I really like to set this up as close to a oem controller.
  • NWE
  • NWE's Avatar
16 Jan 2026 22:45 - 16 Jan 2026 22:47
Replied by NWE on topic New and Working RTAI debs for 2.9
Latency test is only used for testing the pc, don't use the jitter value for BASE_PERIOD, try 50000.
16 Jan 2026 21:30
Replied by tommylight on topic Can my account and post history be deleted please
Category: Forum
Should i also delete my quotes of your posts?
BTW, i am afraid to ask why, but i am also sure you have your reasons.
  • harindugamlath
  • harindugamlath
16 Jan 2026 18:58
Replied by harindugamlath on topic Modbus input for absolute encoder position?
Hi, did anyone get this to work?
I'm planning to use delta absolute servos for a retrofit, I'm very familiar with mesa hardware and really like to use absolute servo position for homing.
  • Lutra
  • Lutra
16 Jan 2026 17:52
Commission drive on AX5206) using TC3 to prep for linuxcnc-ethercat
Category: EtherCAT
Hi Endian, I am just getting started with setting up an ax5203 drive and your scripts and configs mentioned in this and previous topics sound really helpful, but they are no longer available on your codeberg. Do you plan on reuploading them somewhere?
  • roycegb
  • roycegb
16 Jan 2026 14:56
Replied by roycegb on topic Failure to find Named Subroutines
Category: O Codes (subroutines) and NGCGUI
I didn't have the SUBROUTINE PATH located in the [RS274NGC] section of the .INI file. That allowed me to use my subroutines with slight modifications..
16 Jan 2026 14:35
Replied by tommylight on topic StepperOnline A6 Servo
Category: EtherCAT
I would try using a new LAN cable, preferably CAT6
Displaying 8671 - 8685 out of 11475 results.
Time to create page: 2.584 seconds
