  • meister
  • meister
30 Dec 2025 15:30 - 30 Dec 2025 15:32
I tested it with an IceBreaker board via RS485, but it makes no difference.
for the VFD-Simulation, a USB Modbus adapter is connected to the PC, along with the Python script from above.
  • Dave3891
  • Dave3891
30 Dec 2025 15:11
Nice! Is that using the rs485 serial output on the RIO board?
  • PCW
  • PCW's Avatar
30 Dec 2025 15:04
Replied by PCW on topic 7i97t Mesaflash Problem
The hal file is almost entirely commented out so will not do much.
I would start again (with the original files) and if you get a LinuxCNC startup error, post it here
  • NWE
  • NWE's Avatar
30 Dec 2025 14:48
Custom halcomp with nested functions halcompile warning: implicit declaration of
Category: HAL
I get around C++ coding some, but this halcomp thing has me confused. I am trying to call several functions within the _ function. As far as I can tell, what I have should work, but when I halcompile it I get these annoying warnings. I know they are just warnings, but I wouldn't mind fixing them.
In other C projects I sometimes use headers, etc, but I'm confused how this works in halcompile.
I searched around some, but can't seem to find examples of how what I'm trying to do would be done in halcomp.
sudo halcompile --install beam_pullmax.comp
Compiling realtime beam_pullmax.c
beam_pullmax.comp: In function ‘_’:
beam_pullmax.comp:213:5: warning: implicit declaration of function ‘y_stop’ [-Wimplicit-function-declaration]
beam_pullmax.comp:241:6: warning: implicit declaration of function ‘y_down_fast’ [-Wimplicit-function-declaration]
beam_pullmax.comp:286:6: warning: implicit declaration of function ‘y_down_slow’ [-Wimplicit-function-declaration]
beam_pullmax.comp:448:6: warning: implicit declaration of function ‘y_up_slow’ [-Wimplicit-function-declaration]
beam_pullmax.comp:467:6: warning: implicit declaration of function ‘y_up_fast’ [-Wimplicit-function-declaration]
Linking beam_pullmax.so
cp beam_pullmax.so /usr/lib/linuxcnc/modules/
Ah Ha! I think I got it! Just include a header file like any old C program...
I guess I'll post anyway now that it is all typed up, in case it saves someone else time on a future project.
  • meister
  • meister
30 Dec 2025 14:47
  • manny
  • manny
30 Dec 2025 14:44
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
thank you :) So I should pin that axis the way you sent it to me, and it will work for me, right? Thank you very much… what do I owe you?
  • ContinenteCNC
  • ContinenteCNC's Avatar
30 Dec 2025 14:10 - 01 Jan 2026 15:30
Replied by ContinenteCNC on topic PID Windup on the way down
Category: HAL
In my case, there is no need to limit the output at zero. I am using pwmgen to generate the 0–10 V signal in type=0, so any negative PID output is clamped to zero.
The PID behaves correctly during ramp-up, since the output is limited to the maximum possible pwmgen value. The derivative gain provides enough damping to prevent overshoot in that direction. However, during ramp-down, there is a small amount of overshoot. It is minimal and perfectly acceptable for my application.
I was just wondering whether it would be useful to have a minoutput pin, allowing the lower limit to be set to zero instead of -maxoutput.
  • Dave3891
  • Dave3891
30 Dec 2025 13:48 - 30 Dec 2025 13:49
Looking at the manual for this drive I think I can set the control inputs to the terminals and the frequency input to the modbus, I will have to try it later this week.
  • Robin123
  • Robin123
30 Dec 2025 13:44
Replied by Robin123 on topic 7i97t Mesaflash Problem
I just edited the automatically generated .ini and .hal files as needed or commented out lines until LinuxCNC worked. The limit switches, etc. are also not wired yet; I just want to test the old amplifiers once. So, nothing fancy. Maybe I removed too much there or haven't adjusted it yet...?
File Name: Klopp4.0.hal
File Size:11 KB
File Name: Klopp4.0.ini
File Size:4 KB
30 Dec 2025 13:44
Replied by tommylight on topic Following errors
Following errors
RotarySMP has issues with 1 drive causing a fault after a jog, 1 drive faults immediately on jog, and 1 is working OK, so not the same thing as this topic.
This was trying to jog while the drives were disabled, and the subsequent tuning.
RotarySMP has most probably issues with EXE cards that translate whatever feedback Maho uses to pulses.
I though he already figured that out as he did mentioned the same thing on his last video.
  • meister
  • meister
30 Dec 2025 13:38
perhaps also useful for others
File Name: modbus-vfdsim.py
File Size:2 KB
  • meister
  • meister
30 Dec 2025 13:36
not with my VFD, if it set to RS485 mode, all other inputs are disabled.
But I'm already trying something.
I'm currently writing a simple Modbus simulator in Python.
I already have an idea of how I can implement it.
  • PCW
  • PCW's Avatar
30 Dec 2025 13:32
Can you post your hal/ini files?
  • Robin123
  • Robin123
30 Dec 2025 13:21
First of all, thank you so much for the quick replies! With the spontaneous help of a colleague, I downloaded the latest version of mesaflash, etc., did the same thing, and it worked for him. However, the problem is still that I can't control the analog outputs. I got the idea about the firmware because I read somewhere that I need a different version so that analog output is available instead of PWM. Currently, I have PWM 00...05, with both value and enable settings. When I set enable, the Mesa outputs about 0.35V at the analog output. Scale = 10 Max_output = 10 Do I need to adjust anything else? If you need any further information, please let me know! Thank you!
Displaying 9376 - 9390 out of 11475 results.
Time to create page: 0.917 seconds
