07 Dec 2025 11:47 #339818 by Happppppppy
I have been tuning some steppers using the stepdir plugin and the quadencoder plugins as feedback. The tuning hasn't been working too well and I'm curious if it is possible to set the Stepgen into velocity mode? Thankyou!
08 Dec 2025 05:57 #339850 by meister
can you please add your .json config.
Have you set the scale for the quad encoder correctly?
30 Dec 2025 04:08 #340695 by Dave3891
I've started wiring and testing my custom RIO board and everything is looking good so far.
Is there any option to have a watchdog on the outputs? So if the computer crashes or loses connection the outputs will turn off?
Also are there any examples anywhere of controlling a spindle VFD over modbus with RIO?
30 Dec 2025 06:10 #340702 by meister
there are an buildin watchdog, it will disable the pwm/stepdir output if the connection is lost.
you can also set a chain of 'modifiers' to each pin (plugin -> Pins -> Modifiers) like delay, debounce, ... and 'onerror'.
The 'onerror' modifier hold the pin to low or high if connection is lost.
You can also use the 'chargepump' hal-component (www.linuxcnc.org/docs/html/man/man9/charge_pump.9.html) to control a master power relay.
30 Dec 2025 08:30 #340705 by meister
about the VFD, it depends on the type,
i have only a hy_vfd and no real examples, what kind of VFD you have ?
is it realy modbus conform or like the hy_vfd a modbus like protocol ?
30 Dec 2025 16:10 #340722 by Dave3891
The drive is a WK600 series VFD, looking at the modbus manual, I think it is true modbus?
I have attached the modbus details
30 Dec 2025 18:04 #340726 by meister
It could be a bit difficult. To be honest, I've never really thought about how to integrate a VFD using normal Modbus commands.
The main problem is that Rio sends the values in a loop, and individual commands cannot be triggered by a button, for example (to start/stop).
I think I'll have to expand it a bit for that,
but you can try reading out a few values to test the communication.
in json it looks like that to read BusVoltage and RunningFrequency:
    "type": "modbus",
    "pins": {
    "config": {
        "BusVoltage": {
            "address": 1,
            "type": 3,
            "register": 4098,
            "values": 1,
            "datatype": "int",
            "scale": 1.0,
            "unit": "",
            "error_values": "",
            "format": "d",
            "timeout": 100,
            "delay": 60,
            "priority": 0,
            "direction": "input"
        "RunningFrequency": {
            "address": 1,
            "type": 3,
            "register": 4097,
            "values": 1,
            "datatype": "int",
            "scale": 1.0,
            "unit": "",
            "error_values": "",
            "format": "d",
            "timeout": 100,
            "delay": 60,
            "priority": 0,
30 Dec 2025 18:20 #340727 by Dave3891
Could the speed command be sent in the modbus loop and then I could use regular gpio for the start stop?
30 Dec 2025 19:36 #340730 by meister
not with my VFD, if it set to RS485 mode, all other inputs are disabled.
But I'm already trying something.
I'm currently writing a simple Modbus simulator in Python.
I already have an idea of how I can implement it.
30 Dec 2025 19:38 #340731 by meister
perhaps also useful for others
File Name: modbus-vfdsim.py
File Size:2 KB
Time to create page: 0.188 seconds
