01 Sep 2026 11:22 #349172 by Oxbown
Thanks @meister , now works!
Two more things:
-1: would be grateful if we could make a preconfig for that kind of board.
-2: In case of host disconnection...Can I force a value?. For example, if some of the signals are high, if I close the Linuxcnc, I want to force all signals low.
 Thank you.
01 Sep 2026 11:59 #349174 by meister
cool :)
1: you mean a mbus_device template ? yes i will check it
2: Do you mean the Modbus outputs? Yes, there is something there, but I’ll need to check it again as I’ve rewritten the Modbus plugins. (Error values)
Basically, it’s just the Modbus message but without the address and without the CSUM.
This is then sent when the FPGA detects an error (disconnect / timeout).
03 Sep 2026 11:12 #349277 by Oxbown
@meister I tested your last dev commit, and the N4D3E16 template only works with the outputs; the inputs don't work.
Thank you so much for your work!
03 Sep 2026 11:40 #349279 by meister
ok, i have order one, than i can fix and test it the right way :)
maybe next monday
03 Sep 2026 12:11 #349281 by meister
try again, found a bug
and now you can try to set the Error_Values to
6 0 112 0 0
this should switch all outputs to off on connection errors (PC<->FPGA)
26 Sep 2026 05:19 - 26 Sep 2026 05:20 #349887 by viewsat
Hello, does the N4D3E16 test work correctly? I'd also like to order one to try it out.
Last edit: 26 Sep 2026 05:20 by viewsat.
26 Sep 2026 10:23 #349890 by meister
The following user(s) said Thank You: viewsat
Time to create page: 0.455 seconds
