  • Schaublin12
  • Schaublin12
15 Sep 2026 08:02
Replied by Schaublin12 on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
Thanks, Rod, for your help. I'm still pretty overwhelmed by this right now. But I've figured out that the automatically generated XML file lists all the operating modes, and I have to choose one. I hadn't realized that, which is why I ended up with duplicate variable names. I've now decided on operating mode CSP and deleted the rest. I'll give it a try when I get home.
  • Pieter69
  • Pieter69
15 Sep 2026 07:59
2.9.4 uspace: interpreter stops reading ahead mid-session severe stuttering
Hi all,
Sorry topic appeared first double then deleted all together (site is reacting a bit slow) Now back
I've been chasing an intermittent slowdown on my router for a while -- motion that should run smooth and at full commanded feed instead crawls and stutters, seemingly at random. I've now managed to localise and measure it precisely enough that I think it's worth a proper writeup rather than a vague "my machine is slow sometimes" post. Full data below; happy to share raw captures if useful.
SUMMARY
Motion on dense toolpaths sometimes degrades to roughly a quarter to a tenth of programmed feed. The degradation shows up part way through a session, persists across different programs, and is cured completely by restarting LinuxCNC -- a full reboot is not required, just restarting the LinuxCNC application.
I've localised the cause to the interpreter no longer reading ahead. In the degraded state the trajectory-planner queue never holds more than one move, so the planner has nothing to blend into and executes every segment as a discrete stop-start move.
MY SETUP
- LinuxCNC: 2.9.4, uspace
- Kernel: 6.1.0-30-rt-amd64 (PREEMPT_RT)
- GUI: QtDragon / qtvcp (qtdragon_hd)
- Motion card: Mesa 7i96s over Ethernet (hm2_eth, 100BASE-TX)
- Servo period: 1,000,000 ns (1 kHz)
- CPU: 4 cores @ 3.4 GHz, isolcpus=3 nohz_full=3 rcu_nocbs=3 irqaffinity=0-2
- Machine: 3-axis gantry router, X/Y/Y2/Z (Y is a slaved gantry pair)
- Axis limits: X 15000 mm/min @ 1200 mm/s^2; Y 8000 @ 1000; Z 3000 @ 300
THE MEASUREMENT
I ran the same air-move program twice, about ten minutes apart, with a LinuxCNC restart in between and nothing else changed. Two independent monitors ran throughout: a HAL sampler on the servo thread capturing per-joint velocity/position at 1 kHz, and a Python poller reading linuxcnc.stat().queue (trajectory-planner queue depth), .current_line, and /proc/<pid>/stat CPU for milltask and qtvcp, five times a second.
Test file: 2.84 mm median segments, G64 P0.05 Q0.2, F7000
(put this block inside a
tag when posting so the spacing holds -- it only lines up in a monospace font)
[code]
                                  healthy (after restart)  degraded (before)
mean feed while moving            112.2 mm/s               34.3 mm/s
retention of F7000 (116.67 mm/s)  96%                      29%
TP queue depth                    1039 -- full             0-1, never more
read-ahead                        3,674 lines in 0.6 s     ~5 lines/s
milltask CPU                      15% burst, then idle     0.4%
In the healthy run the interpreter fills the entire 1039-move queue within six tenths of a second of pressing start and holds it saturated the whole run. In the degraded run it never gets more than one move ahead.
Second file: 0.54 mm median segments, G64 P0.01 Q0.05, F3600 (denser and tighter-tolerance than the file above, to rule out density as the cause)
                              healthy       degraded
mean feed while cutting       56.7 mm/s     6.3 mm/s
retention of F3600 (60 mm/s)  94%           10.5%
TP queue depth                1781 -- full  n/a
program advance               85 lines/s    ~5 lines/s
THE ARITHMETIC CHECKS OUT
With one move queued the planner can't blend, so each segment accelerates and decelerates in isolation. For a segment of length L under acceleration a, a stop-start traverse peaks at sqrt(a*L) and averages roughly two thirds of that. For the first file: L = 2.84 mm, a = 1200 mm/s^2 gives a peak of 58 mm/s and a mean near 29 mm/s. Measured: 34.3 mm/s. No parameter was fitted to get that number.
THE DETAIL THAT RULED OUT A LOT OF OTHER EXPLANATIONS: RAPIDS ARE UNAFFECTED
In the same degraded capture where every G1 crawled at 12-30 mm/s, the opening G0 rapid held 136.3 mm/s, dead flat, for 2.25 seconds. A rapid is a single long move and needs no queue at all. So the axes, stepgens, Mesa link, servo thread, and acceleration limits are all demonstrably capable of full-speed smooth motion in the degraded state. Only motion that depends on queued look-ahead is affected.
WHAT I'VE RULED OUT BY DIRECT MEASUREMENT (NOT JUST REASONING)
- Interpreter CPU load -- milltask sits at 0.4% CPU while degraded. Not compute-bound, not falling behind -- barely working at all.
- Servo thread -- period measured at 1.006 ms in both states, thread execution ~20% of budget, no overrun.
- G-code density/geometry -- the denser file with the tighter blend tolerance runs better (94% at 0.54 mm / P0.01) than the sparser one.
- G64 P Q blending mode -- different tolerances made no measurable difference.
- File size -- 4k/15k/40k/70k/90k/110k-line programs all ran 94-95% in a healthy session.
- Memory -- qtvcp RSS tracks the size of the currently loaded program, released on load, not a cumulative leak.
- CPU frequency/isolation, NIC tuning, governor, thermals -- all measured directly, none correlated with the state.
- QtDragon's own GUI/graphics CPU load -- checked this after seeing it suggested elsewhere as a cause of large-file sluggishness in QtDragon. qtvcp's own CPU usage from the same captures: 3.67% mean / 49.9% peak (healthy) vs. 3.41% mean / 40.0% peak (degraded) -- flat to slightly lower while degraded, not elevated. Doesn't fit a "GUI thread starving the interpreter" mechanism.
WHAT I DON'T KNOW YET
Why read-ahead stops. It's a property of the session, not of any specific program -- it survives loading a different file, and a LinuxCNC restart (not a reboot) restores it completely. I haven't caught it in the act of transitioning, so I don't know if it's triggered by a specific event or degrades gradually.
Things I'm planning to check next, in rough order of promise -- any input on these, or other ideas, would be very welcome:
1. Whether anything in my config is busting interpreter read-ahead -- queue-busting words, M66, probing, a remap. None of these are present in my test programs, but the read-ahead machinery seems like the obvious place to look next.
2. Whether qtvcp's polling (stat.poll() at GUI rate) can interact with the interpreter's ability to queue, even though its CPU load doesn't change (see above) -- planning to try a run with the GUI closed/killed entirely (headless linuxcnc + halcmd) to see if degradation can even occur without qtvcp attached.
3. Whether the emcmot/emctask NML message channel saturates or throttles under some condition I haven't identified.
4. Whether this is a known 2.9.x regression -- I haven't found a matching report yet, which is part of why I'm posting this.
Operational workaround I'm using in the meantime: if a session has degraded performance, restart LinuxCNC and restart the session. Works, but obviously I'd rather find the actual cause.
Thanks for reading this far -- any pointers, even "check X" without a full answer, would help a lot.
grtz Pieter
  • rodw
  • rodw's Avatar
15 Sep 2026 06:26
Replied by rodw on topic EtherCAT Master Beckhoff slave not found
I did say try! You have duplicated a pin name in the xml file. It tells you that.
  • rodw
  • rodw's Avatar
15 Sep 2026 06:21
LinuxCNC + Mesa 7i92TF: motors barely move and ignore direction changes
Category: Driver Boards
Slow speed is generally a scaling issue in your setup. In my first ever setup I was terribly disappointed to see no motion on my first test. Then when I looked closely, the motor was barely moving!
If direction is not recognized, its probably a wiring issue.
  • Marslukan
  • Marslukan
15 Sep 2026 06:19 - 15 Sep 2026 06:30
Replied by Marslukan on topic 7i98 and 5abobx3 firmware
Category: PnCConf Wizard
Можно еще уточнить по процессу изменения, создания bitfile.
На скриншоте порядок:
  1. открываем проект seveni98.xise
  2. добавляем в проект файл PIN_MARSLUKAN_51.vhd, если нужно исправляем.
  3. выбираем нужную карту
  4. правильно сделано?
  5. генерируем проект и получаем bitfile - TopEthernetHostMot2.bit
    Или нужно еще где-то что-то нажать?
  • rodw
  • rodw's Avatar
15 Sep 2026 06:16
Home switches stopping machine but not latching fully
Category: Plasmac
Please share your hal and ini files.
  • Cristy13
  • Cristy13
15 Sep 2026 03:03
7i97T + 7i74 + 7i84U – No Smart Serial Communication
Thank you very much. I found the problem.
With:
config="sserial_port_0=00000000"
the 7I84U boards are detected correctly.
At the moment I have only two 7I84U boards powered with 28V, and LinuxCNC detects both of them on channels 5 and 7:
hm2_7i97.0.7i84.0.5
hm2_7i97.0.7i84.0.7
So the 7I97T, 7I74, firmware, adapter and DB25 cable are all working correctly.
The main issue was that I was previously using:
config="sserial_port_0=x0xxxxxx"
and I had also misunderstood the physical channel numbering on the 7I74.
I will now power the other two 7I84U boards and test all four.
Thank you again for your help.
  • PCW
  • PCW's Avatar
14 Sep 2026 18:24
Replied by PCW on topic 7i98 and 5abobx3 firmware
File Name: 7i98_marslukan.zip
File Size:87 KB
Left the first connector with all 4 5ABOB stepgens
(if you need the stepgen3 pins  as I/O, only
enable 3 stepgens  (0,1,2) in the hal file)
I have included the pinout source file in case you
want to make changes and compile a new bitfile yourself.
  • PCW
  • PCW's Avatar
14 Sep 2026 17:04 - 14 Sep 2026 17:10
Well naturally, no problem found...
pcw@pcw-HP-Compaq-Elite-8300-USDT:~/bitfiles$ md5sum 7i97t_7i74d.bin
4130ebee623115267327c166f8da9d39  7i97t_7i74d.bin
7I97T with that firmware finds 7I84Us on all (1..7) 7I74 channels
7I74 channel 0 (lower left if facing the jacks) is not used with this firmware
as port 0 channel 0 is on the 7I97T card.
This is with our normal DB25M-IDC26 cable (and 7I74 powered over cable)
For external power make sure you have both the 7I74 and 7I97T Jumpered correctly:
7I97T W22 DOWN
7I74 W1 DOWN
Also note the 7I74 channel 1 is the top/left jack
facing the jacks, they are numbered:
1  3  5  7
0  2  4  6
  • Cayenne
  • Cayenne
14 Sep 2026 15:55
Replied by Cayenne on topic Probe panel for Axis GUI
Category: AXIS
2.7.15
  • Cristy13
  • Cristy13
14 Sep 2026 15:20
  • PCW
  • PCW's Avatar
14 Sep 2026 14:42
  • PCW
  • PCW's Avatar
14 Sep 2026 14:24 - 14 Sep 2026 14:27
I would try:
Might also be a DB25 cable issue, not all adapters are wired correctly for this use.
  • Cristy13
  • Cristy13
14 Sep 2026 13:58
Hi,I am retrofitting a CNC lathe with LinuxCNC and I have the following Mesa hardware:
  • 1x Mesa 7i97T
  • 1x Mesa 7i74
  • 4x Mesa 7i84U
  • IDC26 to DB25 adapter
  • DB25 male-male 1:1 cable between 7i97T P2 and 7i74
  • standard straight-through CAT5e cables between 7i74 and 7i84U
The problem is that none of the 7i84U boards are detected over Smart Serial.The 7i97T is reachable at:
192.168.1.121
I am using firmware:
7i97t_7i74d.bin
MD5:
I also verified the firmware in flash with:
mesaflash --device 7I97T --addr 192.168.1.121 --verify /home/cnc/7i97t_7i74d.bin
and I get:
Board FLASH memory verified successfully
mesaflash --device 7I97T --addr 192.168.1.121 --sserial
gives only:
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 8
SSLBP Baud Rate: 2500000
but no 7i84U devices are listed.I tested 7i84U boards on CH1 and CH2 of the 7i74 with the same result.On the 7i84U:
  • W3 = LEFT / operate mode / 2.5 Mbaud
  • VIN = about 28 V
  • VFIELD A = about 28 V
  • VFIELD B = about 28 V
  • CR2 ON
  • CR7 ON
  • CR5 red ON
  • CR6 green OFF / never blinks
On the 7i74:
  • CR1 is ON
  • I initially measured only about 4.5 V
  • I changed it to external regulated 5 V supply
  • now TB1 measures 5.08 V
  • the problem is still exactly the same
I checked the RJ45 cable and it is straight-through:
1-1, 2-2, 3-3, 4-4, 5-5, 6-6, 7-7, 8-8
I also tested the 7i97T P2 interface with W21 UP and P2 disconnected:
mesaflash --device 7I97T --addr 192.168.1.121 --rpo 0x1008
Result:
0001FFFF
So that test appears to pass.
readhmid
 also shows the expected Smart Serial signals:
RXData0/TXData0
 on the 7i97T and
RXData1...7 / TXData1...7
 for the 7i74 channels.I also tried loading HostMot2 manually:
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=192.168.1.121 config="sserial_port_0=x0xxxxxx"
The 7i97T loads and registers normally, but the 7i84U is still not detected.Everything is new hardware.At this point I suspect either the 7i74 itself, the IDC26/DB25 path between P2 and the 7i74, or something I am missing in the Smart Serial configuration.Does anyone have a known-good 7i97T + 7i74 + 7i84U setup and can tell me what I should test next?In particular:
  • Is
     correct for a 7i84U connected to CH1 of the 7i74?
  • Is there a direct test for TX/RX on the 7i74 without an oscilloscope?
  • Are there any jumpers/settings on the 7i74 or 7i84U that I may have missed?
Thanks.
Displaying 991 - 1005 out of 11357 results.
Time to create page: 0.519 seconds
