  • DemonClaW
  • DemonClaW
29 Nov 2025 17:14
Replied by DemonClaW on topic StepperOnline A6 Servo
Category: EtherCAT
I just got my first servo, too. But even after all Iread here i wasnt able to get it running maybe one of you already had the same problem or im just doing the same mistake over and over again.
Thanks for your help
  • PCW
  • PCW's Avatar
29 Nov 2025 16:32
Is there any way to use Pncconf Wizard to set up 7i97T with 7i73 pendant board?
Adding a simple probe input does not require adding any components, basically just
making some connections in the hal file, something like:
 net probe hm2_7i97.inmux.00.input-15 =>  motion.probe-input
 or perhaps
net probe hm2_7i97.inmux.00.input-15-not =>  motion.probe-input
depending on the probe polarity.
Adding a MPG will typically require at least one components as a mux component
is often used to select between jog increments.
Searching the forum for MPG will finds a number of MPG implementations and hal file examples.
  • PCW
  • PCW's Avatar
29 Nov 2025 16:21
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
With a 7I92, you would normally chose firmware that matches the
pinout of the breakout board you use. The G540x2 firmware is made
to match the pinout of the Gecko G540 4 Axis step/dir drive.
A commonly use breakout board (BOB)  is the Sainsmart "Mach 5 Axis CNC" breakout
For the, you would use  "5ABOB" firmware
  • zz912
  • zz912's Avatar
29 Nov 2025 16:20 - 29 Nov 2025 18:20
Replied by zz912 on topic GTK little probe screen
Category: Gmoccapy
Little probe screen was added to master branch.
github.com/LinuxCNC/linuxcnc/pull/3643
I will be happy for feedback.
  • Tinker
  • Tinker
29 Nov 2025 16:16
I really don't even need to use the 7i73, all I am really trying to do is add a probe input and set up this MPG for my 7i97T. I really don't know how to add custom components to hal and ini files from scratch. I will admit that I do need to read up on the process...
  • mooser
  • mooser
29 Nov 2025 16:03
Replied by mooser on topic 7i84u probably toasted
Just received the other email, (didn't make the connection to you)
I'll try as you suggested, nothing to loose at this point.
Thanks so much for the help
M
  • Sekai
  • Sekai
29 Nov 2025 16:01 - 29 Nov 2025 16:04
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
Ok. got it to work with the intel itx board. the fujistu minipc is hopeless.
I got it with 7i92_G540x2D firmware, kind of weird to setup the pins. Is there a simple firmware?
For reference i'm planning to use an lathe like 400x1000 3 tons with live tooling so no Y axis (X axis, Z axis and C-axis)
Edit: BTW i used a chinese usb stick (USB 3.0) and when i install the linuxcnc it gave errors (like the password for the wifi did not work or it refuse to install grub loader, so i use another usb and it works like charm).
  • PCW
  • PCW's Avatar
29 Nov 2025 15:58
Replied by PCW on topic 7i84u probably toasted
As I mentioned in our email communications, the 3.3V power supply may be shorted out
by the damaged chip (there may be more than one unfortunately). So if that is cleared,
communications may work. Also as I mentioned, damage to the I/O section of the 7I84U
is unlikely to propagate to the serial interface side as that is galvanically isolated (2KV!)
from the I/O side.
  • mooser
  • mooser
29 Nov 2025 15:58 - 29 Nov 2025 17:04
You might check if there is 3.3V (measure from W1 pin 1 to 3, pin 1 should ++3.3V)
Lack  of 3.3V may mean damaged 3.3V regulator or shorted part.
M
  • mooser
  • mooser
29 Nov 2025 15:50
Nothing like that around me. The LV4051A chip closest to that area of the board has a bulged up spot in the middle and it's a multiplexer so it's probably toast but since there's no sign of any connection between the two boards now it must have taken out more upstream of that. I'm just hoping it didn't kill the communication part on the 7i06s
M
  • PCW
  • PCW's Avatar
29 Nov 2025 15:48
  • PCW
  • PCW's Avatar
29 Nov 2025 15:40
There is an experimental version of pncconf (for LinuxCNC 2.10 only) that supports the 7I97T in this thread:
forum.linuxcnc.org/plasmac/55286-servo-d...ofit?start=10#331289
Note that there is no specific firmware needed to support the 7I73
There's also a sample 7I97T configuration to which  7I73 support could be added:
File Name: basic7i97_...1-29.zip
File Size:4 KB
To list 7i73 pin and parameter names:
halcmd show all | grep 7i73
while LinuxCNC is running
  • Ul
  • Ul
29 Nov 2025 15:12 - 29 Nov 2025 15:22
Replied by Ul on topic 7i84u probably toasted
Do you have a thermal imaging or infrared camera or do you know someone who has one? Defective ICs often get hot when you apply power to them.
  • nick.smith
  • nick.smith
29 Nov 2025 14:11
Replied by nick.smith on topic 4th axis scale factor (steps per degree)
Category: PathPilot
Just chiming in that I purchased a similar amazon 4th axis and had the same issue and fixed it with this. This reply just serves as a personal bookmark for me.
  • Tinker
  • Tinker
29 Nov 2025 14:11
I have been trying to get my 7i97T to work with a 7i73 so I can use an MPG and a few other local input buttons. I've tried Mesa CT but it will not work with the 7i73, no option to flash that card. So I tried Pncconf and it does not build a good file for the 7i97T. I tried the board discover option and it appears to work but when i actually try to launch the build file it give me a bunch of errors on the 7i73. If I change the I/O of the error pin to not used it just errors out on the next pin... Another issue that is also related and why I'm attempting to use the Pncconf is that I need to install a tool setter and touch probe. Pncconf would be the way to go but i cant get it to work with me. Has any one run into this before?
Displaying 10261 - 10275 out of 12716 results.
Time to create page: 0.683 seconds
