  • unknown
  • unknown
15 Nov 2025 02:51
Replied by unknown on topic Why is there no BSDCNC?
I don't think that's true.
The NIST designed if for POSIX systems.
Could you provide the literature that confirms your claim.
Even if it is the RT implementations for WIndows NT & Linux are going to be different beasts, as would the RT for BSD.
Even then Linux (most distros) NetBSD & OpenBSD are not certified as POSIX compliant yet comply in large part. Windows I think there was an effort with NT4 or Windows 2k, from memory a "POSIX Pack" was available.
After looking through a number of documents I could not find posix mentioned. But if you have access to any plesae link.
  • unknown
  • unknown
15 Nov 2025 02:35
Linuxcnc isn't "designed for debian" originally the ISO were built for Ubuntu,
I think that _originally_ EMC targeted Windows NT...
But FreeBSD was originally supported, according to en.wikipedia.org/wiki/LinuxCNC
Once again you have a more in depth, I can't think of the word.......I don't think I'm well and may not have long left before I'm not much good to anyone.
Th point I was trying to make is that building & running Linuxcnc is achievable on, I'll say most< Linux platforms. Even Puppy Linux had an ISO for Linuxcnc.
  • unknown
  • unknown
15 Nov 2025 02:30
Replied by unknown on topic Experimental raspios Linuxcnc Trixie images.
Category: Installing LinuxCNC
You've done something terribly wrong,
1; Didn't use RPi Imager to setup the settings
2: Choose to ignore the setup dialogue on the first boot.
In both instances you should have been able to setup a user name & password, the password for your account is the one that you use for sudo.
Both gparted and synaptic work when setup following the advice above.
imp can be replaced with (this module was removed from the version of python3 on trixie)
sudo apt install python3-zombie-imp
To go any further I think you will need to ask whether ProbeBasic and pyqtvcp has Trixie support.
  • COFHAL
  • COFHAL
15 Nov 2025 02:00
I understand, but I installed GParted and Synaptic, and both require a password to log in. I use both because I have an SSD, and Synaptic for other tasks. I set a password in raspi-config, but it doesn't work to log in to these applications.
  • unknown
  • unknown
15 Nov 2025 01:51
First of all I recommended to use the Rpi Imager to setup username, locale, and the other things needed.
If you didn't do this you should have gone through the setup screens to configure things.
This would have given you a user name.
This image is NOT LIKE the former images, it is based on the infrastructure that build the raspios images. The idea was to make it easier to setup the image and not have a preconfigured username and password.
  • COFHAL
  • COFHAL
15 Nov 2025 01:40 - 15 Nov 2025 02:01
Perhaps I wasn't more specific, but the error message indicates that it can't find the imp module.Then I send a screenshot of the error.From what I've read now, it seems to be due to something related to the Python version.
  • andypugh
  • andypugh's Avatar
15 Nov 2025 01:39
Replied by andypugh on topic Why is there no BSDCNC?
  • COFHAL
  • COFHAL
15 Nov 2025 01:37
If they do it now, I use it on several PIs with Debian 12.
  • COFHAL
  • COFHAL
15 Nov 2025 01:35
I haven't set up any user name.
  • andypugh
  • andypugh's Avatar
15 Nov 2025 01:24
2.9.5 should not be available to download due to it being broken.
When will GitHub start building versions for 2.10/master branch? It really is necessary.
It shouldn't be necessary....
But it _should_ already work, except that Sid isn't building right now so the process fails.
Trial run: github.com/andypugh/linuxcnc-petter/actions
  • ihavenofish
  • ihavenofish
15 Nov 2025 00:40
lemontart - a call for help with s curve, ui's, and all the cool toys
nema17 ha! this is a 300lb machine, nema17 wont be moving it.
200w ac servo is fine for the z. I wouldn't go smaller power. A nema23 stepper would work, it would just be very slow, probably not getting past 1000rpm before the torque falls off too much.
  • rrhoten
  • rrhoten
15 Nov 2025 00:39
Debian Linuxcnc9, network boards xcarve
Been using LinuxCNC for years without problem. Now, Linuxcnc loads but xcarve gives and error. Last line before load stops says it can't find network card. Is it referring to my wifi card or my mesa card? Don't know why it would need a network card.
- Ray -
  • rodw
  • rodw's Avatar
15 Nov 2025 00:34
Can i use 5A Sanyo Denki 60mm stepper motors? :)
Of course you can. Plenty of ethercat stepper drivers out there. even 2,3 and 4 motor controls in the single driver...
links to the multi kits with ethercat?
The only hitch on servo choice is there's only 100mm room for the Z motor. A 200w modern servo with a brake fits. a lot of others will be too long.
Rtelligent and Leadshine have ethercat dual motor stepper drives. example www.rtelligentglobal.com/ethercat-stepper-drive/  and www.leadshine.com/product/2EM3E-522-14-15-990-69.html
If space is an issue, there is always NEMA 17! there are 3 and 4 motor options I've seen recently but may not have been ethercat
  • rodw
  • rodw's Avatar
15 Nov 2025 00:24
This is what pisses me off.
I've spent quite a few weeks working on this, with no input from anyone, no one bothering to lend a hand (testing when I gave links and requested some one to test), and when an issue does come up all I get " I installed probe basic and tried to run it, but it gives an error." with no description of the error.
Can you understand why I may be a little bit terse. If you can't be bothered to give any indication of what the error is or anything like that I'm not going to waster time trying to pull information out of you bit by bit.
I'm not even sure that the probe basic/qtpyvcp team even support distributions for the Pi. They never used to.
  • rodw
  • rodw's Avatar
15 Nov 2025 00:22
Most people expect to be able to install packages just usually apt or apt-get, as far as I know github doesn't provide the resources to host a git repo.
no but a script could copy new versions from git releases to the existing LinuxCNC Deb repository
Displaying 11071 - 11085 out of 12723 results.
Time to create page: 0.414 seconds
