  • zoeper
  • zoeper
11 Nov 2025 22:56
Replied by zoeper on topic Avon 3000 Mill retrofit
Category: Milling Machines
Plain sailing this is not! I have been battling for days now to get LinuxCNC up and running. Resorting to building from source now. Hope to have it up and running by tomorrow morning.....ok, later this morning. :)
11 Nov 2025 22:44
Replied by tommylight on topic [SOLVED] Backlash issues on Y-AXIS
Backlash speed was functional last i used it for sure, some 15 or 20 years ago, no idea what's the status now.
Back then it solved the issue of missing steps i wasted 2 hours chasing, and ended up being the G540 issue where for 9 steps it did nothing.
  • unknown
  • unknown
11 Nov 2025 21:47
Replied by unknown on topic [SOLVED] Backlash issues on Y-AXIS
Your ini file is a mess and very hard to follow, but:
Y axis/joint has unreasonably big ferror and min_ferror values, probably should be close to what X axis has
Backlash_speed is set at 6000 inch !!!
What is the drive train? Belt? Screw? Ball screw?
Since it is a laser, i would advise belt only on X and Y.
I not even sure if there Backlash_speed is used in the hal file, there doesn't seem to be anything related to backlash_spped or similar mentioned in the docs for motmod.
  • Masiwood123
  • Masiwood123's Avatar
11 Nov 2025 21:45 - 11 Nov 2025 21:51
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
I'll try it tomorrow if I didn't remember to try jogging via the button on screen:) I'll also try in hal to edit the acceleration, etc., the next step is to connect the home switches for referencing.. when I set the motors well, there are two buttons on the panel, one is for starting the program, later I'll try it via ``halui'' and ``drive on'' should provide ``power`` to the drivers, than for ``enabling`` the driver works via the ena+ and ena - wire on the 7i77 when I turn it on machine via linux. the next steps are to connect the inputs and outputs to the 7i77, because now in the basic configuration I have made a connection with the 7i92+7i77 and I have no idea how I will use one of the step dir channels with the 7i96s as well as the whole 7i96s in general. thank you very much
  • unknown
  • unknown
11 Nov 2025 21:42
In all honesty it may be worthwhile going back to you original setup. I generally think of the PC for a cnc setup as a "black box". As along as it doing everything you want leave it that way.
But it is quite curious as to why backlash is not working as expected. Maybe raising an issue on github may get better responses. The guys that do the coding will be answering.
I hate to say this but backlash comp should be a last resort after you have exhausted all mechanical ways to reduce it.
Sorry I haven't been able to solve this issue and I wish you all the best. If you do find a solution it would be great to describe the fix for anyone else in the future. Good luck as always.
11 Nov 2025 21:37
11 Nov 2025 21:29
Replied by tommylight on topic beta bulleri for retrofit?
Try jogging with on screen buttons, does it still jerk?
The wire you connected 24V is the machine enable, so it goes to Mesa 7i77 output, while the other wire should go to input as machine is ready. Does the other pin come from the ON/START/GREEN button?
Tuning does not seem OK, but it is very nice that you can jog at low speed, try increasing the speed gradually and see this for further instructions:
  • dgdodo
  • dgdodo
11 Nov 2025 21:18
Replied by dgdodo on topic [SOLVED] Backlash issues on Y-AXIS
I Tried with 'hal_pi_gpio.write base-thread' at the end of the base-thread, but it does not make any difference.
Thanks for the info anyways.
11 Nov 2025 21:09
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Category: EtherCAT
No double posting.
And fix the tittle to explain what it is about.
Thank you.
  • peterpan
  • peterpan
11 Nov 2025 20:42
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I can't find much on Ethercat homing. Maybe I'll be able to figure it out down the road. How would I set it up with Inputs on the EL1008 instead, in the meantime?
  • peterpan
  • peterpan
11 Nov 2025 20:29
Replied by peterpan on topic EtherCAT servo homing
Category: EtherCAT
My drive have several homing method built in, and I recently solved to change the drive state druring the LCNC start, so I can initialize the drive to HM mode first, than CNP mode.
How?
  • Masiwood123
11 Nov 2025 20:25 - 11 Nov 2025 20:26
  • endian
  • endian's Avatar
11 Nov 2025 20:18
Replied by endian on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Translate it as complex . Import it as s32 or u32.. Then create simple component to cut it a pieces... Simple and effective
  • Masiwood123
11 Nov 2025 20:14 - 11 Nov 2025 20:24
  • Masiwood123
11 Nov 2025 20:12
watch both videos, I think the following is motor tuning, connecting the home switch, and again I have a problem with the keyboard, the velocity changes when jogging, I need to find Tommylight's post on how to solve it. thanks:)
Displaying 11236 - 11250 out of 12770 results.
Time to create page: 8.447 seconds
