  • tsaG
  • tsaG
10 Nov 2025 20:42
Replied by tsaG on topic Probebasic tool length calculation
Category: QtPyVCP
Okay, with "remove any current tool length offset" you mean to remove the offset saved in the tool table? Shouldn't the tool probing overwrite this offset?
  • Boltten
  • Boltten
  • jtrantow
  • jtrantow
10 Nov 2025 19:26 - 10 Nov 2025 19:32
HAL visualization with GraphViz was created by jtrantow
I have extended the python code mentioned in forum.linuxcnc.org/24-hal-components/145...with-graphviz#325079 in github.com/JTrantow/LCNC_HAL_to_graphviz
With these changes I can use it to get 99% of the graphviz I use to document my configurations.
The attached CompleteConfig.svg is an example I whipped up today to help a friend setup a spindle VFD and external estop switch.
Using an online graphvix editor, I can quickly delete the subgraphs and signals that were cluttering up the spindle VFD and estop we were working on. See attached VFDandEStop.svg.
See the readme.md in github for further detail. I have run this on multiple configurations without issue. When your config is divided into multiple files, it's relatively easy to only load the portions you want to document.
When I tried to attach individual .svg files it complains about "Unable to get properties for the image."???
File Name: HALvisualization.zip
File Size:10 KB
  • Boltten
  • Boltten
10 Nov 2025 19:24
Replied by Boltten on topic Mesa 7i96s Torch on and arc ok problems?
Category: Plasma & Laser
Sorry for late reply. I've have made a new rebuild of my wiring, and i would appreciate if you guys would check if everything looks correct. I will make a video of the problem if it still there, if my wiring diagram looks right.
  • Hakan
  • Hakan
10 Nov 2025 19:05 - 10 Nov 2025 19:37
Replied by Hakan on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
The unit of pos-scale is increments/distance unit, like steps/mm or steps/inch.
If you motor's encoder has 500 pulses/rev, then it is 2000 increments/rev.
With a axis movement of 5 mm/motor revolution you should set pos-scale = 2000/5 and 2000/180 respectively.
400 and 11.111
It may be possible to set the increments/rev separately from the encoders value, check the drive manual if the above doesn't match.
  • Hakan
  • Hakan
10 Nov 2025 18:59 - 10 Nov 2025 19:34
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
Not sure what you mean by encoder_value.
You have the cia402.x.pos-scale to work with.
Instead of mathematically figuring it out, multiply the current value with 6.5/2 = 3.25 and try again.
If you find that number matches a known relation, use that.
I think the following errors follows from the pos-scale. At least get this right first.
More text here on how to calculate pos-scale
forum.linuxcnc.org/ethercat/22346-etherc...er?start=1360#338150
  • mlcupen
  • mlcupen
10 Nov 2025 17:55
Replied by mlcupen on topic Ethercat drive configuration woes
Category: EtherCAT
state machine from my comp is ok . 0x6 -> 0x7 -> 0x7f . Bit 2 (quickstop) is always set.
mine too, do you fix that
  • mlcupen
  • mlcupen
10 Nov 2025 17:43
Category: EtherCAT
Did you start the motor?
  • mlcupen
  • mlcupen
10 Nov 2025 17:41
Category: EtherCAT
Hello,
I'm trying to start the motor but it's not working, I tried via halrun and via sudo ethercat upload -p and motor enters OP, but it doesn't accept OP_STATUS, always 0, and the motor dont move, please can you help me somehow.
  • peterpan
  • peterpan
10 Nov 2025 17:32 - 10 Nov 2025 17:33
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I have been trying to solve these problems on my own with very little headway:
When the Servo moves 2 inches, LinuxCNC registers it as ~6.5inches regardless of the encoder_scale value
joint following error when I try to jog over ~60in/min (linuxcnc units)
joint following error when try to home (probably related)
I haven't even gotten to the real configuration and am already failing :'/
Help is appreciated
  • PCW
  • PCW's Avatar
10 Nov 2025 17:14
Replied by PCW on topic THC Plasma
THC Plasma
Category: Deutsch
1. there is no issue changing the firmware (unless you needed the 7I74)
2. 150V full scale should be OK though it may give less margin for sensing ARC OK if you don't have an
ARC OK signal from the plasma source. You can use any divider but /32 is suggested for best noise immunity
If you use /1 you must reduce the encoder filer time constant (so not suggested)
3. Yes, for 7i96s_7i74 or 7i96s_d or 7i96s_dpl firmware, the "A0" encoder input
is always on TB2 pins 7,8 (you can check by looking at the .pin files in the firmware directory)
  • dgdodo
  • dgdodo
10 Nov 2025 16:32 - 19 Nov 2025 01:19
[SOLVED] Backlash issues on Y-AXIS was created by dgdodo
Backlash not working anymore in LinuxCNC v2.9.x
Build my own laser CNC machine about 4 years ago, which worked fine with LinuxCNC 2.8.2.
Using an RPi 3B+, laser and 2 x L293D controllers and 28BYJ-48 steppenmotors.
After trying to update Debian to trixie the SD-card would not boot anymore, so build new one (back to Bookworm).
(Although i can get the old data from LinuxCNC of the card.)
Debian Trixie is not that RT compatible as written all over, still need an RT version to run LinuxCNC on RPI 3B+.
Pitty there is no complete RPi 3 (only 4 and 5) version of LinuxCNC available anymore?
After installing LinuxCNC v2.9.6 (on Debian Bookworm) I could not get the machine working as it did with v2.8.2.
I also changed X-axis steppenmotor with a spindle drive to make it more accurate, this works fine (backlash between 0.1 - 0.3),
but after this I still have trouble with the Y-axis (on which i did not changed anything).
Before (v2.8.2) the Y-axis had a backlash of 1.315, but now I can not get it right anymore.
It looks like the backlash is now only working in 1 direction and I do not see the backlash correction back on the motor movement.
Even if I make the backlash much bigger, just to see if is really done by the motor.
It only draws (i.e. circles) bigger, but the error stays (see IMG_4618a.JPG with BL of 1, 2 and 3)
My question is what has been changed in v2.9.x according the backlash, as I only find 'improved'.
In my case it is not improved but getting worse.
Maybe the new changes do not work with my controllers (L293D)?
And how to solve this weird issue.
Reagrds, DG
File Name: dgplot14_90.hal
File Size:1 KB
File Name: dgplot14_13.hal
File Size:4 KB
  • seuchato
  • seuchato
10 Nov 2025 13:48
hal file for gamepad pendant with retrofitted 12-position selector switch
Category: HAL Examples
Juergen
Very well done and extremely inspiring!!!
Thanks for sharing. I happen to have one of these gampads trailing around somewhere. Off searching :-)
Greez
chris
  • lorenzing
  • lorenzing
10 Nov 2025 11:59
Replied by lorenzing on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Hi all, can someone help me with "setp cia402.x.pos-scale xxxx" value?
I've this type of motor with the same encoder: EMMB-ST-87-M-SM (X), EMMB-ST-87-M-SMB (Z1,Z2,Y1,Y2).
Z1, Z2 5mm/rev; X, Y1, Y2 180mm/rev but I don't know the correct pos-scale value.
  • Plasmanfm
  • Plasmanfm
10 Nov 2025 11:45 - 10 Nov 2025 11:49
THC Plasma was created by Plasmanfm
THC Plasma
Category: Deutsch
Unser Plasmaschneider Hevy-Metal hat diese Jahr gute Dienste und schöne Ergebnisse geliefert....
Des halb haben wir uns entschlossen das THC nach zurüsten....
Erste Frage da wir damals die falsche Firmware genommen ( 7I96S_7I74 )haben gibt es ein Chaos wenn wir auf 7I96S-dpl gehen ?
Frage zum THCAD2 High isolation A-D:
10 V Full Scale
Wiederstände sind ok
Da der Plasmaschneider etwa 103 V beim Schneiden abgiebt was sich mit den Typenschild decktist die frage kann ich auf 150 V gehen für die Wiederstands berechnung oder sollte man auf 200 V gehen ?
Output Frequency ??Mode F/32 oder weiche für die 7I96S ?
Die Eingänge auf der 7I96S Endcoder-Stecker immer die beiden unteren wie in Beitrag
MESA THCAD-2 - couple quick questions ?
Das war es fürs erste.
Our Heavy-Metal plasma cutter has served us well this year and delivered great results.... Therefore, we've decided to upgrade to the THC....
First question: Since we used the wrong firmware (7I96S_7I74) back then, will there be any problems if we switch to 7I96S-dpl?
Question regarding the THCAD2 High Isolation A-D
10V Full Scale
Resistors are OK Since the plasma cutter outputs about 103V during cutting, which matches the nameplate, the question is: Can I use 150V for the resistor calculation, or should I use 200V?
Output Frequency? Mode F/32 in the THCad 2 for the 7I96S?
The inputs on the 7I96S encoder connector are always the two lower ones, as in the post "MESA THCAD-2 - couple quick questions" ?
That's all for now.
king regard e Juergen
Displaying 11296 - 11310 out of 12769 results.
Time to create page: 1.139 seconds
