06 Nov 2025 14:57
Can't reverse after homing on 5-axis parallel breakout
Category: Basic Configuration
once I home the machine on the last joint to home (1) it stops being able to move in one direction on all axes. If I try and move it in the other direction it doesn't move.
Can you try again explaining that as it does not make sense to me, or even better make a video and upload to youtube.
  • daveansell2
  • daveansell2
06 Nov 2025 14:47 - 06 Nov 2025 19:34
I am having a strange issue I have been running a CNC router with a dual motor axis for a while very happily and have just put in a second limit switch on the dual axis so it unracks itself on home in case it gets out of square, and have a really odd issue.Before I home the machine all the non-dual axes work fine (though it won't let me use the dual axis, which is annoying), once I home the machine on the last joint to home (1) it stops being able to move in one direction on all axes. If I try and move it in the other direction it doesn't move.
I am attaching the previous version which uses a different config of limit switches, and seems to work fine - davemill-vfd.hal & davemill-vfd.ini
The new config is davemill-vfd-ind.hal & davemill-vfd-ind.hal
Does this make any sense to anyone?
   thanks
*** SOLVED *** see my post below
  • dm17ry
  • dm17ry's Avatar
06 Nov 2025 14:39
Replied by dm17ry on topic MECHATROLINK-II interface
Category: Driver Boards
sure: This email address is being protected from spambots. You need JavaScript enabled to view it.
  • Gogonfa
  • Gogonfa
06 Nov 2025 13:50
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
i made an support request (issue) on git...
"Support for additional device ID (0xeb91) for XHC-WHB04B-6 clone (EDING CNC rebrand)"
  • JT
  • JT's Avatar
06 Nov 2025 13:16
Replied by JT on topic Flex GUI - Axis Position Labels
Category: Flex GUI
Thanks for the report, this is fixed.
JT
  • andypugh
  • andypugh's Avatar
06 Nov 2025 13:06
  • andypugh
  • andypugh's Avatar
06 Nov 2025 13:00
How to set current encoder pos to current position while homing by Driver.
Category: EtherCAT
I would rather expect joint.N.motor-pos-cmd to re-init to the current encoder feedback value (joint.N.motor-pos-fb) on restart.
Maybe you have a missing HAL connection?
It's probably worth halscoping / halmetering those pins (and others) to see what is happening.
  • emresensoy
  • emresensoy
06 Nov 2025 12:30
Replied by emresensoy on topic Fiatech exhibition - 9 axis ethercat setup
Category: Show Your Stuff
Of course, it means free
06 Nov 2025 11:22
Replied by tommylight on topic Fiatech exhibition - 9 axis ethercat setup
Bedava means free, right?
  • kor
  • kor
06 Nov 2025 10:26 - 06 Nov 2025 10:59
pc for linuxcnc using ethercat and Mesa
I am looking to buy a "firewall" PC with 4 ethernet ports to have one ethernet port for my mesa 7i76e one for ethercat and one for LAN.
Do you have recommendations for that currently I am looking at this system on amazon: amzn.to/4nEujde it has 4 x i226-V 2.5Gigabit Ethernet ports and seems to be fine for a linuxcnc build what do you think.
Or do you think I should rather get a normal big pc and get pci-express lan cards?
  • pmchetan
  • pmchetan
06 Nov 2025 09:38
Replied by pmchetan on topic MECHATROLINK-II interface
Hey,
I have Omron R88D-GN04H-ML2 drives in a three axes CNC pick and place setup. The drive takes the commands from Omron trajexia MC04/ML04 motion controller. I was hoping, I could control the servo drives from linuxcnc but found out about the mechatrolink-II network is the only available command interface to the drives. I would like to buy the FPGA hadware that you developed. May I contact you through personal email?
  • KlausB
  • KlausB
06 Nov 2025 09:31
Touch Plate was created by KlausB
Touch Plate
Category: Qtvcp
With this installation, I also tried the touch plate function. It’s visible that after probing the touch plate, the program sets the Z value to the height of the touch plate before executing the retract. This causes the retract value to be added, and the resulting height above the object is correct.
Unfortunately, the program then subtracts the length of the current tool, which in my case is not useful.
Is it possible to disable this behavior?
Thank you very much for your support.
Best regards,
Klaus
  • KlausB
  • KlausB
06 Nov 2025 09:18
z_level_compensation again was created by KlausB
After experiencing issues with other software on my computer, I decided to perform a fresh installation using the current DVD version 2.9.4. (2.9.7 after Upgrade)
Unfortunately, I'm once again encountering problems with Z-Level Compensation.
After creating the “probe_points.txt” file, I can enable “Z-Comp”, but the value in the “Z_Axis Comp” field does not change as expected. Once “Z_COMP” is turned off, it cannot be reactivated without restarting the program.
Do you have any idea what might be causing this?
Best regards,
Klaus
  • Hakan
  • Hakan
06 Nov 2025 09:11
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
What I noticed right away was that they use SyncManager 0 for process data. This is not normal.
SyncManagers 2 and above are for process data, SM 0 and 1 are for mailboxes and handles SDO upload/download especially during the early phases like INIT.
I don't think you can change the syncmanagers, the device has what it has, but a wild experiment could be to change the SyncManager idx="0" to idx="3". If you haven't thrown the device in the bin already :)
  • Gogonfa
  • Gogonfa
06 Nov 2025 08:18
EdingCNC uses a Chinese clone of this wireless handwheel, probably with a customized Product ID. I’m not sure if this is a general issue, but it might be interesting for users who want to switch from EdingCNC to LinuxCNC without buying a new wireless handwheel controller.
The controller sold by EdingCNC — which is basically identical to the ones available on AliExpress — costs more than €300. It is needed in order to run with the EDING CNC Software.
Displaying 11461 - 11475 out of 12773 results.
Time to create page: 0.553 seconds
