  • Ahmed.emara
  • Ahmed.emara
14 Sep 2025 10:35 - 02 Oct 2025 13:10
Sync Problem LinuxCNC + EL8EC400F was created by Ahmed.emara
Category: EtherCAT
SOLVED!
I am running LinuxCNC with EtherCAT  and Leadshine EL8-EC400F servo drives in Cyclic Synchronous Position (CSP) mode. I’m struggling with jitter / noise that seems to be related to Distributed Clock (DC) synchronization between LinuxCNC and the drives.
My Machine Setup:
  • Controller: LinuxCNC (2.9.4) + EtherCAT (lcec)
    • Drives: 5 × Leadshine EL8-EC400F
      • Mode: CiA-402 CSP (0x6060 = 8) ( Control mode CSP)
        • Interpolation time (0x60C2): Read-only, fixed at 2 ms (
          value=2, [code]index=-3)
          [/code]
          • [code][b]Servo thread: 2 ms (2000000 ns) in LinuxCNC INI
            Please the attached XML for EtherCAT communication settings.
            My problem is as follows : [/b]
            [/code]
            • [code][b]When I jog axes in LinuxCNC, the motors make a [b]raspy / friction-like noise.[/b][/b]
              [/code]
              • [code][b][b]In HALScope, I see [b]large torque and acceleration spikes at the same time.[/b][/b][/b]
                [/code]
                • [code][b][b][b]In Leadshine MotionStudio → Diagnostics, I see the counter [b]“Synchronization overflow times” increasing steadily during motion.[/b][/b][/b][/b]
                  [/code]
                  • [code][b][b][b][b]However, when I test motion with the Leadshine tuning software (without LinuxCNC), the motors run perfectly smooth.
                    what i tried so far :
                     [/b][/b][/b][/b]
                    [/code]
                    • [code][b][b][b][b]Matched [b]SERVO_PERIOD, [code]appTimePeriod, and [code]sync0Cycle to 2 ms.
                      [/code][/code][/code][/b][/b][/b][/b][/b]
                      • [code][b][b][b][b][b][code][code]Tested different [code]refClockSyncCycles values:
                        [/code][/code][/code][/code][/b][/b][/b][/b][/b]
                        • [code][b][b][b][b][b][code][code][code][code]5 (every 10 ms) → overflow counter increased faster.
                          [/code][/code][/code][/code][/code][/b][/b][/b][/b][/b]
                          • [code][b][b][b][b][b][code][code][code][code][code]1 (every 2 ms) → better, but still some overflows.
                            [/code][/code][/code][/code][/code][/code][/b][/b][/b][/b][/b]
                            • [code][b][b][b][b][b][code][code][code][code][code][code]0.5 (every 1 ms half-cycle) + [code]sync0Shift=10000 → gave the [b]best result so far, but the overflow counter still increments slowly.[/b]
                              [/code][/code][/code][/code][/code][/code][/code][/code][/b][/b][/b][/b][/b]
                              • [code][b][b][b][b][b][code][code][code][code][code][code][code][b]Increased [code]sync0Shift from 1 µs up to 20 µs → small improvements, but not fully stable.
                                [/code][/code][/code][/code][/code][/code][/code][/b][/code][/code][/b][/b][/b][/b][/b]
                                • [code][b][b][b][b][b][code][code][code][code][code][code][code][b][code]Checked 0x60C2 (interpolation time) → confirmed it is [b]read-only fixed at 2 ms, so I cannot change the drives to 1 ms.
                                  Also i noticed in the tunner motion studio that all the drivers has EtherCAT slave ID = 2 , while it should be configured by the master which is wired.
                                  my Questions : [/b]
                                  • [code][b][b][b][b][b][code][code][code][code][code][code][code][b][code][b]Is it valid/expected that [code]refClockSyncCycles="0.5" works better than [code]1 or [code]5? Or does this mean I have a deeper DC setup issue?
                                    [/code][/code][/code][/code][/code][/code][/code][/code][/code][/code][/b][/b][/code][/code][/b][/b][/b][/b][/b]
                                    • [code][b][b][b][b][b][code][code][code][code][code][code][code][b][code][b][code][code][code]For LinuxCNC + EL8 drives fixed at 2 ms interpolation, what is the recommended [b]refClockSyncCycles and [b]sync0Shift strategy?[/b][/b]
                                      • [code][b][b][b][b][b][code][code][code][code][code][code][code][b][code][b][code][code][code][b][b]Has anyone successfully run EL8-EC400F in CSP under LinuxCNC without sync overflows?[/b][/b]
                                        • [code][b][b][b][b][b][code][code][code][code][code][code][code][b][code][b][code][code][code][b][b]Any advice on NIC/IRQ tuning (isolated cores, rt-preempt) that could help with reducing these overflows?[/b][/b]
  • Aciera
  • Aciera's Avatar
14 Sep 2025 08:06
Replied by Aciera on topic 5-axis CNC recommendation
Apologies @Jmp97 your profile got deleted by accident. Feel free to reregister with the previous username/ password.
  • WKS-3D
  • WKS-3D's Avatar
14 Sep 2025 07:48
Replied by WKS-3D on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
I changed it as follows:
# ---Encoder Feedback Signals/Setup
setp    hm2_7i92.0.encoder.00.counter-mode 0
setp    hm2_7i92.0.encoder.00.filter 1
setp    hm2_7i92.0.encoder.00.index-invert 0 # war 0
setp    hm2_7i92.0.encoder.00.index-mask 0
setp    hm2_7i92.0.encoder.00.index-mask-invert 1  # war 1
setp    hm2_7i92.0.encoder.00.scale  [JOINT_0]ENCODER_SCALE
setp    hm2_7192.0.encoder.00.index-enable true
# ---Indexsignal GMS fuer Referenzpunkt X (NICHT MIT NORMALEM ENDSCHALTER)
net x-pos-fb  <=  hm2_7i92.0.encoder.00.position
net x-vel-fb  <=  hm2_7i92.0.encoder.00.velocity
net x-pos-fb  =>  joint.0.motor-pos-fb
#net x-index-enable  joint.0.index-enable  <=>  hm2_7i92.0.encoder.00.index-enable
net x-pos-rawcounts  <=  hm2_7i92.0.encoder.00.rawcounts
 but I get this error message:
  • WKS-3D
  • WKS-3D's Avatar
14 Sep 2025 07:25
Category: Deutsch
That's what I did:
but it doesn't work
  • dskinne6
  • dskinne6
14 Sep 2025 07:18
Replied by dskinne6 on topic Installing 2.9.5 on Raspberry Pi 5
Category: Installing LinuxCNC
Now working, many thanks!
  • farmer_mike
  • farmer_mike
14 Sep 2025 04:59
Replied by farmer_mike on topic Getting (hopefully) close to an Rtelligent build
Category: EtherCAT
I halved the SDO values one more time and the servos are nice and quiet now. I will have to look at the HAL Oscilloscope to see how the tune is, but for now the tune is quiet and on scale.
Here are the files below. I used an ECT60 paired with a precision planetary gearbox for the Z axis of my milling machine. The X and Y axis are controlled by RS750E drives with a slight belt reduction.
Emergency stop button is wired into the ECT60 on input number 6. From the input of the ECT60, I mapped the E stop over to the HALUI emergency stop. Without the HALUI mapping, the drives would start back up as soon as the physical E stop was released. The limit switches and homing switches for the Z axis were straight forward.
Limit switches and homing switches for the RS750E drives were a little more complicated. I converted the drive input tags from s32 to u32 then bit sliced the u32 to break out the switches. I bet all the slicing could have been done in the XML file, but I could not figure that out.
When I first started the project, my plan was to run everything off of a laptop. I have since switched to a raspberry pi 4.
I still have a bit of work to do, but I want to thank everyone for their help so far.
# CIA 402 example snippet Hal
# Setup
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ethercat-conf.xml
#loadusr -W /home/cnc/linuxcnc/configs/linuxcnc-cia402-single/python_control.py
loadrt lcec
loadrt cia402 count=3
loadrt pid names=0-pid,1-pid,2-pid
loadrt bitslice count=6 personality=32,32,32,32,32,32
addf bitslice.0 servo-thread
addf bitslice.1 servo-thread
addf bitslice.2 servo-thread
addf bitslice.3 servo-thread
addf bitslice.4 servo-thread
addf bitslice.5 servo-thread
loadrt conv_s32_u32 count=6
addf conv-s32-u32.0 servo-thread
addf conv-s32-u32.1 servo-thread
addf conv-s32-u32.2 servo-thread
addf conv-s32-u32.3 servo-thread
addf conv-s32-u32.4 servo-thread
addf conv-s32-u32.5 servo-thread
# Functions servo-thread
addf lcec.read-all servo-thread
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf 0-pid.do-pid-calcs servo-thread
addf 1-pid.do-pid-calcs servo-thread
addf 2-pid.do-pid-calcs servo-thread
addf cia402.0.write-all servo-thread
addf cia402.1.write-all servo-thread
addf cia402.2.write-all servo-thread
addf lcec.write-all servo-thread
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1
#config
# Joint 0
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 786432
#from servo(ethercat) to cia402
net 0-statusword      lcec.0.0.cia-statusword => cia402.0.statusword
net 0-opmode-display  lcec.0.0.opmode-display => cia402.0.opmode-display
net 0-drv-act-pos     lcec.0.0.actual-position => cia402.0.drv-actual-position
net 0-drv-act-velo    lcec.0.0.actual-velocity => cia402.0.drv-actual-velocity
#from motion to cia
net 0-enable     <= joint.0.amp-enable-out => cia402.0.enable
net 0-amp-fault  => joint.0.amp-fault-in   <= cia402.0.drv-fault
net 0-pos-cmd    <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd
net 0-pos-fb     => joint.0.motor-pos-fb   <= cia402.0.pos-fb
#from cia402 to servo(ethercat)
net 0-controlword         cia402.0.controlword => lcec.0.0.cia-controlword
net 0-modes-of-operation  cia402.0.opmode => lcec.0.0.opmode
net 0-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.target-position
net 0-drv-target-velo     cia402.0.drv-target-velocity => lcec.0.0.target-velocity
net my-out-0 conv-s32-u32.0.in <= lcec.0.0.digitalinputs
net my-in-0 conv-s32-u32.0.out => bitslice.0.in
net my-bit-0 bitslice.0.out-00 joint.0.neg-lim-sw-in
net my-out-0 conv-s32-u32.1.in <= lcec.0.0.digitalinputs
net my-in-1 conv-s32-u32.1.out => bitslice.1.in
net my-bit-1 bitslice.1.out-01 joint.0.pos-lim-sw-in
net my-out-0 conv-s32-u32.2.in <= lcec.0.0.digitalinputs
net my-in-2 conv-s32-u32.2.out => bitslice.2.in
net my-bit-2 bitslice.2.out-02 joint.0.home-sw-in
# Joint 1
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale -786432
net 1-statusword      lcec.0.1.cia-statusword => cia402.1.statusword
net 1-opmode-display  lcec.0.1.opmode-display => cia402.1.opmode-display
net 1-drv-act-pos     lcec.0.1.actual-position => cia402.1.drv-actual-position
net 1-drv-act-velo    lcec.0.1.actual-velocity => cia402.1.drv-actual-velocity
net 1-controlword         cia402.1.controlword => lcec.0.1.cia-controlword
net 1-modes-of-operation  cia402.1.opmode => lcec.0.1.opmode
net 1-drv-target-pos      cia402.1.drv-target-position => lcec.0.1.target-position
net 1-drv-target-velo     cia402.1.drv-target-velocity => lcec.0.1.target-velocity
#from motion to cia
net 1-enable    <= joint.1.amp-enable-out => cia402.1.enable
net 1-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault
net 1-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net 1-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb
net my-out-1 conv-s32-u32.3.in <= lcec.0.1.digitalinputs
net my-in-3 conv-s32-u32.3.out => bitslice.3.in
net my-bit-3 bitslice.3.out-00 joint.1.pos-lim-sw-in
net my-out-1 conv-s32-u32.4.in <= lcec.0.1.digitalinputs
net my-in-4 conv-s32-u32.4.out => bitslice.4.in
net my-bit-4 bitslice.4.out-01 joint.1.neg-lim-sw-in
net my-out-1 conv-s32-u32.5.in <= lcec.0.1.digitalinputs
net my-in-5 conv-s32-u32.5.out => bitslice.5.in
net my-bit-5 bitslice.5.out-02 joint.1.home-sw-in
# Joint 2
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 96000
net 2-statusword      lcec.0.2.cia-statusword => cia402.2.statusword
net 2-opmode-display  lcec.0.2.opmode-display => cia402.2.opmode-display
net 2-drv-act-pos     lcec.0.2.actual-position => cia402.2.drv-actual-position
net 2-drv-act-velo    lcec.0.2.actual-velocity => cia402.2.drv-actual-velocity
net 2-controlword         cia402.2.controlword => lcec.0.2.cia-controlword
net 2-modes-of-operation  cia402.2.opmode => lcec.0.2.opmode
net 2-drv-target-pos      cia402.2.drv-target-position => lcec.0.2.target-position
net 2-drv-target-velo     cia402.2.drv-target-velocity => lcec.0.2.target-velocity
#from motion to cia
net 2-enable    <= joint.2.amp-enable-out => cia402.2.enable
net 2-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault
net 2-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd
net 2-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb
net  2-CCW-limit lcec.0.2.in-3 => joint.2.neg-lim-sw-in
net  2-CW-limit lcec.0.2.in-4 => joint.2.pos-lim-sw-in
net  2-in-home lcec.0.2.in-5 => joint.2.home-sw-in
net  2-in-6 lcec.0.2.in-6 => halui.estop.activate
#net spindle_speed     spindle.0.speed-out => python_control.rpm_in
# This config file was created 2020-08-14 17:19:37.621705 by the update_ini script
# The original config files may be found in the /home/demo/linuxcnc/configs/et-3ax/et_3ax_CIA402.old directory
[EMC]
# The version string for this INI file.
VERSION = 1.1
MACHINE = EtherCAT Machine
DEBUG = 1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
#PYVCP = pyvcp_panel.xml
# places the pyvcp panel at the bottom of the Axis window
PYVCP_POSITION = RIGHT
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME =            0.100
# Path to help file
HELP_FILE =             doc/help.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1
# Prefix to be used
PROGRAM_PREFIX = /home/demo/linuxcnc/nc_files
INTRO_TIME = 0
INCREMENTS = 1in .5in .25in .125in .0625in .025in .05in
#INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
nc = /usr/bin/axis
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD =  0
SERVO_PERIOD = 1000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.005
[HAL]
HALFILE = cia402.hal
#SHUTDOWN = shutdown.hal
HALUI = halui
[HALUI]
[TRAJ]
HOME = 16 12 7
COORDINATES = XYZ
LINEAR_UNITS = in
ANGULAR_UNITS = deg
DEFAULT_LINEAR_VELOCITY = .25
MAX_LINEAR_VELOCITY = .5
MIN_LINEAR_VELOCITY = .01
DEFAULT_ANGULAR_VELOCITY = 360
MAX_ANGULAR_VELOCITY = 720
POSITION_FILE = position.txt
[EMCIO]
# Name of IO controller program, e.g., iov2 has tool changer stuff
EMCIO =         iov2
CYCLE_TIME =    0.100
# tool table file
TOOL_TABLE =    cia402.tbl
TOOL_CHANGE_POSITION = 0 0 50.8
#RANDOM_TOOLCHANGER = 1
[KINS]
JOINTS = 3
KINEMATICS = trivkins kinstype=both coordinates=xyz
[AXIS_X]
MIN_LIMIT = 0.1
MAX_LIMIT = 17.9
MAX_VELOCITY = .5
MAX_ACCELERATION = 10
BACKLASH = 0.0000
[JOINT_0]
TYPE = LINEAR
MAX_VELOCITY = .5
# is this applicable for ethercat????
#STEPGEN_MAXVEL = 1.25
#STEPGEN_MAXACCEL = 1.25
SCALE = 1
FERROR = 200
MIN_FERROR = 50
MIN_LIMIT = 0
MAX_LIMIT = 18
HOME                    = 16
HOME_OFFSET                = 16
HOME_SEQUENCE            = 0
HOME_SEARCH_VEL = -.125
HOME_LATCH_VEL = -.125
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS        = NO
[AXIS_Y]
MIN_LIMIT = 0.1
MAX_LIMIT = 12.9
MAX_VELOCITY = .5
BACKLASH = 0.0000
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = .5
STEP_SCALE = 1
FERROR = 2
MIN_FERROR = 20
MIN_LIMIT = 0
MAX_LIMIT = 13
HOME                    = 12
HOME_OFFSET                = 12
HOME_SEQUENCE            = 1
HOME_SEARCH_VEL = .125
HOME_LATCH_VEL = .125
HOME_USE_INDEX = NO
[JOINT_2]
TYPE = LINEAR
MAX_VELOCITY = .5
STEP_SCALE = 1
FERROR = 200
MIN_FERROR = 20
MIN_LIMIT = 3.4
MAX_LIMIT = 8.1
HOME                    = 7
HOME_OFFSET                = 7
HOME_SEQUENCE            = 2
HOME_USE_INDEX = NO
[AXIS_Z]
MIN_LIMIT = 3.5
MAX_LIMIT = 8
MAX_VELOCITY = .5
BACKLASH = 0.0000
<masters>
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="5">
  <slave idx="0" type="generic" vid="00000A88" pid="0a880013" configPdos="true">
   <!-- Joint 0 -->
  <sdoConfig idx="2009" subIdx="1"><sdoDataRaw data ="00 32"/></sdoConfig> <!-- position p gain default is 1000 -->
  <sdoConfig idx="2009" subIdx="2"><sdoDataRaw data ="00 08"/></sdoConfig> <!-- velocity p gain default is 256 -->
  <sdoConfig idx="2009" subIdx="3"><sdoDataRaw data ="00 01"/></sdoConfig> <!-- position i gain default is 200 -->
   <syncManager idx="0" dir="out"> </syncManager>
   <syncManager idx="1" dir="out"> </syncManager>
   <syncManager idx="2" dir="out">
    <pdo idx="1600">
     <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
     <pdoEntry idx="607a" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
     <pdoEntry idx="60b8" subIdx="00" bitLen="16" halPin="touchprobefunction0" halType="bit"/>
    </pdo>
    <pdo idx="1601">
     <pdoEntry idx="6081" subIdx="00" bitLen="32" halPin="profile-velocity" halType="u32"/>
     <pdoEntry idx="6083" subIdx="00" bitLen="32" halPin="target-accel" halType="u32"/>
     <pdoEntry idx="6084" subIdx="00" bitLen="32" halPin="target-decel" halType="u32"/>
     <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
    </pdo>
    <pdo idx="1602">
     <pdoEntry idx="60ff" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
    </pdo>
   </syncManager>
   <syncManager idx="3" dir="in">
    <pdo idx="1a00">
     <pdoEntry idx="603f" subIdx="00" bitLen="16" halPin="errorcode" halType="bit"/>
     <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
     <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
     <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
     <pdoEntry idx="60b9" subIdx="00" bitLen="16" halPin="touchprobestat" halType="bit"/>
     <pdoEntry idx="60ba" subIdx="00" bitLen="32" halPin="touchprobe1pos" halType="s32"/>
     <pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digitalinputs" halType="s32"/>
    </pdo>
    <pdo idx="1a01">
     <pdoEntry idx="606c" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
    </pdo>
   </syncManager>
   <dcConf assignActivate="300" sync0Cycle="1000000"/>
  </slave>
  <slave idx="1" type="generic" vid="00000A88" pid="0a880013" configPdos="true">
   <!-- Joint 1 -->
    <pdo idx="1600">
    </pdo>
    <pdo idx="1601">
    </pdo>
    <pdo idx="1602">
    </pdo>
   </syncManager>
    <pdo idx="1a00">
    </pdo>
    <pdo idx="1a01">
    </pdo>
   </syncManager>
  </slave>
     <!-- Joint 2 -->
    <slave idx="2" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="88 13"/></sdoConfig>  <!-- Max motor current (5.0) -->
      <sdoConfig idx="2007" subIdx="3"><sdoDataRaw data ="01"/></sdoConfig>     <!-- Input 3 - CCW Limit -->
      <sdoConfig idx="2007" subIdx="4"><sdoDataRaw data ="02"/></sdoConfig>     <!-- Input 4 - CW Limit -->
      <sdoConfig idx="2007" subIdx="5"><sdoDataRaw data ="03"/></sdoConfig>     <!-- Input 5 - Home Function -->
      <sdoConfig idx="2007" subIdx="6"><sdoDataRaw data ="05"/></sdoConfig>     <!-- Input 6 - Emergency Stop -->
      <sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig>  <!-- Closed loop -->
      <sdoConfig idx="6098" subIdx="0"><sdoDataRaw data ="11 00"/></sdoConfig>  <!-- Home mode 17 -->
      <sdoConfig idx="607C" subIdx="0"><sdoDataRaw data ="00 00"/></sdoConfig>  <!-- Home offset 0  -->
      <sdoConfig idx="609A" subIdx="0"><sdoDataRaw data ="F4 01"/></sdoConfig>  <!-- Home accelleration 500 -->
      <sdoConfig idx="6099" subIdx="01"><sdoDataRaw data ="C4 09"/></sdoConfig>  <!-- Home fast speed 2500-->
      <sdoConfig idx="6099" subIdx="02"><sdoDataRaw data ="F4 01"/></sdoConfig>  <!-- Home slow speed 500 -->
        <pdo idx="1600">
          <!-- Target Position -->
          <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
          <!-- Target Velocity -->
          <pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
          <!-- Digtial Outputs (manufacturer's extension ECT86/ECT60)-->
          <pdoEntry idx="204A" subIdx="0" bitLen="16" halType="complex">
            <complexEntry bitLen="1" halPin="out-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-2" halType="bit"/>
            <complexEntry bitLen="14"/>
          </pdoEntry>
        </pdo>
      </syncManager>
        <pdo idx="1a00">
          <pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
          <pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32"/>
          <!-- Digtial_inputs (cia402 compatible) -->
          <pdoEntry idx="60FD" subIdx="0" bitLen="32" halType="complex">
            <complexEntry bitLen="1" halPin="CW-limit" halType="bit"/>
            <complexEntry bitLen="1" halPin="CCW-limit" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-home" halType="bit"/>
            <complexEntry bitLen="13"/>
            <complexEntry bitLen="1" halPin="in-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-6" halType="bit"/>
            <complexEntry bitLen="10"/>
          </pdoEntry>
        </pdo>
      </syncManager>
    </slave>
  </master>
</masters>
  • RsSalvador
  • RsSalvador
14 Sep 2025 04:14
Replied by RsSalvador on topic M66 keeps waiting
M66 keeps waiting
Category: G&M Codes
Hi, I'm having the same error in version 2.9.4 with Debian 12, M66 L3. Q10 doesn't work from the M06 subroutine, it only works from an MDI command. When I run it, the console deactivates, and when I activate the sensor, it reactivates. How can I resolve this?
  • ccc774
  • ccc774
14 Sep 2025 02:36
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
I installed Trixie with Cinnamon and 3D acceleration. I applied rt-kernel over the original 6.1.115 kernel and it wouldn't boot. I commented out overlays=panthor-gpu in armbianEnv and it booted. So the system has the capability to use 3d acceleration but something in rt-kernel is stopping it.
  • unknown
  • unknown
14 Sep 2025 02:12
Replied by unknown on topic Installing 2.9.5 on Raspberry Pi 5
Just received notification and confirmed am64 permissions for the packages have been corrected. Thanks to Andy
  • unknown
  • unknown
14 Sep 2025 00:57
Replied by unknown on topic My Sherline Linux CNC Ubuntu PC won't start
If you think you're SSD is dying cloning may not be an option,
Best option would be to boot from a CD mount the partition your home directory is on and copying that to a usb drive.
Having not used such a early version of Ubuntu in ages, and noticing that dev-mapper is loading, do you have any LLVM partions is this a dual boot system? Or rather how are the partitions setup ? If you boot into a lice session via CD
sudo fdisk -l /dev/sda
will display the partition layout.
First place I would have started was searching for the text via google in the second last message in the picture. This particular error seemed to have a habit of popping up with no prior warning or sometimes errors that have been ignored. Also I would search for the line beginning with "error: unexpectedly disconnected from boot status daemon"
14 Sep 2025 00:51
Replied by tommylight on topic 5-axis CNC recommendation
But for crying out loud do not use any form of Artificial Intelligence, a lot of humans haven't gained Actual Intelligence yet.
Oh how much i laughed, and how painfully true that is.
14 Sep 2025 00:45
Replied by tommylight on topic My Sherline Linux CNC Ubuntu PC won't start
You only need to save the config folder from the old SSD that is located in the "user name" folder so should be EMC2 or LinuxCNC and inside is the "configs" folder so copy that.
You can try changing the SATA cable as those can cause such issues, look for cracks in the shielding near connectors and if you see any = change cable. And if there other SATA cables plugged into the mainboard but not used, unplug those.
The strange thing is, there is no Ubuntu 12.04 with LinuxCNC officially, but there is a Debian Wheezy ISO with the same kernel.
  • Eugene12
  • Eugene12
14 Sep 2025 00:06
Replied by Eugene12 on topic My Sherline Linux CNC Ubuntu PC won't start
Thanks, I was able to load from my install CD. It says Ubuntu 12.04. Same in config description. I use this PC to run Linux CNC for my Sherline CNC mill and lathe. It's being used only for this. I run the disk utility to check the SSD and it found no errors. What it can be then? Anyway I've ordered a new SSD. Now I need to understand how to make an image of my system to transfer it to new SSD. Could you please assist here? On my MacBook I always use Time machine and have no problem.
  • ihavenofish
  • ihavenofish
13 Sep 2025 23:51
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
made a little prelaunch video :)
  • Pryston
  • Pryston
13 Sep 2025 23:41
Replied by Pryston on topic Roland mdx-650a question
Hi, I am from Colombia, and  I need foud that servomotor to the acis Z, could some one help me, to found that +57 3172122584
Displaying 12961 - 12975 out of 13747 results.
Time to create page: 0.957 seconds
