  • zz912
  • zz912's Avatar
25 Aug 2026 11:18
run Linuxcnc on xenomai with EVL(the realtime core)
Hi, I was interested in your testing of Xenomai 4/EVL with LinuxCNC.
I’ve recently been testing the scripts from the xenomai4-linuxcnc project as well, and I got some interesting results — I was able to reduce the tmax values for hm2 read and write.
Could you share what tmax values you are seeing for hm2 read and hm2 write on your system? If possible, together with your servo period (which I assume is around 1 ms), it would be interesting to compare the results and see whether it would actually be worthwhile for you to pursue this further.
Thanks!
  • murdemon
  • murdemon
25 Aug 2026 10:32
Replied by murdemon on topic Xilinx Zynq 7010 fpga crypto windfall boards
Category: Driver Boards
Pins for smart serial is in Pin descriptor from IDROM of ZYNQ hostmot2 FPGA, but in usag it show as just IOPort, why it is can happens? I doing some mistake , or it is some logic of work when nothink findout on smart serial?
ubuntu@arm:~$ ./start_linuxcnc.sh
This script only needs to be run once per shell session.
LINUXCNC - 2.9.10
Machine configuration directory is '/home/ubuntu/linuxcnc-dev/configs/test'
Machine configuration file is 'puma560.ini'
check_config: Unchecked: [KINS]KINEMATICS=genserkins
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(LIB): /home/ubuntu/linuxcnc-dev/lib/hallib/basic_sim.tcl
setup_kins: cmd=loadrt genserkins
userkKinematicsSetup:
emc/kinematics/userkfuncs.c max_joints=9 allow_duplicates=0
setup_kins: unknown [KINS]KINEMATICS=
Found file(REL): ./puma560_dh.hal
hm2/hm2_soc_ol: Low Level init 0.15
hm2/hm2_soc_ol: 34 HM2 Pin Descriptors:
hm2/hm2_soc_ol: pin 0:
hm2/hm2_soc_ol: Primary Tag: 0x03 (IOPort)
hm2/hm2_soc_ol: Secondary Tag: 0xC1 (Smart Serial Interface)
hm2/hm2_soc_ol: Secondary Unit: 0x00
hm2/hm2_soc_ol: Secondary Pin: 0x81 (tx0, Output)
hm2/hm2_soc_ol: pin 1:
hm2/hm2_soc_ol: Secondary Pin: 0x01 (rx0, Input)
hm2/hm2_soc_ol: pin 2:
hm2/hm2_soc_ol: pin 3:
hm2/hm2_soc_ol: pin 4:
hm2/hm2_soc_ol: Secondary Tag: 0x05 (StepGen)
hm2/hm2_soc_ol: Secondary Pin: 0x82 (Direction, Output)
hm2/hm2_soc_ol: pin 5:
hm2/hm2_soc_ol: Secondary Pin: 0x81 (Step, Output)
hm2/hm2_soc_ol: pin 6:
hm2/hm2_soc_ol: Secondary Unit: 0x01
hm2/hm2_soc_ol: pin 7:
hm2/hm2_soc_ol: pin 8:
hm2/hm2_soc_ol: Secondary Unit: 0x02
hm2/hm2_soc_ol: pin 9:
hm2/hm2_soc_ol: pin 10:
hm2/hm2_soc_ol: Secondary Unit: 0x03
hm2/hm2_soc_ol: pin 11:
hm2/hm2_soc_ol: pin 12:
hm2/hm2_soc_ol: Secondary Tag: 0x1A (Hostmot2 DPLL)
hm2/hm2_soc_ol: Secondary Pin: 0x82 (Ref Out Pin, Output)
hm2/hm2_soc_ol: pin 13:
hm2/hm2_soc_ol: Secondary Tag: 0x04 (Encoder)
hm2/hm2_soc_ol: Secondary Pin: 0x01 (A, Input)
hm2/hm2_soc_ol: pin 14:
hm2/hm2_soc_ol: Secondary Pin: 0x02 (B, Input)
hm2/hm2_soc_ol: pin 15:
hm2/hm2_soc_ol: Secondary Pin: 0x03 (Index, Input)
hm2/hm2_soc_ol: pin 16:
hm2/hm2_soc_ol: pin 17:
hm2/hm2_soc_ol: Secondary Tag: 0x06 (PWMGen)
hm2/hm2_soc_ol: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
hm2/hm2_soc_ol: pin 18:
hm2/hm2_soc_ol: pin 19:
hm2/hm2_soc_ol: pin 20:
hm2/hm2_soc_ol: Secondary Unit: 0x04
hm2/hm2_soc_ol: pin 21:
hm2/hm2_soc_ol: pin 22:
hm2/hm2_soc_ol: Secondary Unit: 0x05
hm2/hm2_soc_ol: pin 23:
hm2/hm2_soc_ol: pin 24:
hm2/hm2_soc_ol: Secondary Unit: 0x06
hm2/hm2_soc_ol: pin 25:
hm2/hm2_soc_ol: pin 26:
hm2/hm2_soc_ol: Secondary Unit: 0x07
hm2/hm2_soc_ol: pin 27:
hm2/hm2_soc_ol: pin 28:
hm2/hm2_soc_ol: pin 29:
hm2/hm2_soc_ol: pin 30:
hm2/hm2_soc_ol: pin 31:
hm2/hm2_soc_ol: pin 32:
hm2/hm2_soc_ol: pin 33:
hm2/hm2_soc_ol: Smart Serial Firmware Version 43
hm2/hm2_soc_ol: 34 I/O Pins used:
hm2/hm2_soc_ol: IO Pin 000 (GPIO0.P1-01): IOPort
hm2/hm2_soc_ol: IO Pin 001 (GPIO0.P1-14): IOPort
hm2/hm2_soc_ol: IO Pin 002 (GPIO0.P1-02): IOPort
hm2/hm2_soc_ol: IO Pin 003 (GPIO0.P1-15): IOPort
hm2/hm2_soc_ol: IO Pin 004 (GPIO0.P1-03): StepGen #0, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 005 (GPIO0.P1-16): StepGen #0, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 006 (GPIO0.P1-04): StepGen #1, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 007 (GPIO0.P1-17): StepGen #1, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 008 (GPIO0.P1-05): StepGen #2, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 009 (GPIO0.P1-06): StepGen #2, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 010 (GPIO0.P1-07): StepGen #3, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 011 (GPIO0.P1-08): StepGen #3, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 012 (GPIO0.P1-09): Hostmot2 DPLL #0, pin Ref Out Pin (Output)
hm2/hm2_soc_ol: IO Pin 013 (GPIO0.P1-10): Encoder #0, pin A (Input)
hm2/hm2_soc_ol: IO Pin 014 (GPIO0.P1-11): Encoder #0, pin B (Input)
hm2/hm2_soc_ol: IO Pin 015 (GPIO0.P1-12): Encoder #0, pin Index (Input)
hm2/hm2_soc_ol: IO Pin 016 (GPIO0.P1-13): IOPort
hm2/hm2_soc_ol: IO Pin 017 (GPIO0.P2-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 018 (GPIO0.P2-14): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 019 (GPIO0.P2-02): PWMGen #2, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 020 (GPIO0.P2-15): StepGen #4, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 021 (GPIO0.P2-03): StepGen #4, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 022 (GPIO0.P2-16): StepGen #5, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 023 (GPIO0.P2-04): StepGen #5, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 024 (GPIO0.P2-17): StepGen #6, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 025 (GPIO0.P2-05): StepGen #6, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 026 (GPIO0.P2-06): StepGen #7, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 027 (GPIO0.P2-07): StepGen #7, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 028 (GPIO0.P2-08): IOPort
hm2/hm2_soc_ol: IO Pin 029 (GPIO0.P2-09): Encoder #1, pin A (Input)
hm2/hm2_soc_ol: IO Pin 030 (GPIO0.P2-10): Encoder #1, pin B (Input)
hm2/hm2_soc_ol: IO Pin 031 (GPIO0.P2-11): Encoder #1, pin Index (Input)
hm2/hm2_soc_ol: IO Pin 032 (GPIO0.P2-12): IOPort
hm2/hm2_soc_ol: IO Pin 033 (GPIO0.P2-13): IOPort
hm2/hm2_soc_ol: registered
DUMMY DISPLAY MODULE, press to continue.
  • jelost
  • jelost
25 Aug 2026 10:22
M19 orientation drift with external encoder and orient component (LinuxCNC 2.9.4
A big thank you for those two lines!
Now i have G33.1 working perfectly, as well as M19!
  • hansfbaier
  • hansfbaier
25 Aug 2026 10:13
Replied by hansfbaier on topic Controller recommendations (other than mesa)
Not true anymore. There is a very nice open hardware card, called rioctrl:
github.com/festlv/rioctrl-hw/tree/main/rioctrl-controller
I still have a number of those surplus from the last production run and can sell those.
I also designed Mesa-Style IO hats for it with
5 axes 4 encoder inputs, 8i/4o direct I/O and 16 out/32 in (shifted),
which I could sell, if anyone is interested.
  • hansfbaier
  • hansfbaier
25 Aug 2026 09:32 - 25 Aug 2026 09:36
I created a terminal based HAL viewer, 100% keyboard based operation
Category: HAL
write this halshow based HAL viewer, because halshow is unusable from the keyboard only.
This one is completely operable by the keyboard and is compatible with halshow save files.
For example toggling a boolean Pin is only the press of the space bar and
moving between the tree and the WATCH/SHOW tabs uses left/right arrows.
Here is the source code:
github.com/hansfbaier/linuxcnc-haltui
Have fun!
Hans
  • dm17ry
  • dm17ry's Avatar
25 Aug 2026 09:09
Replied by dm17ry on topic LinuxCNC S-Curve Accelerations
took a log of servo drives commands on a deckel dmc 70v, MELDAS 500 circa 1992, 25MHz 68040 CPU. runs at 1.77(7) ms servo cycle. rapids use trapezoidal velocity profile, cutting feed is s-curve. interestingly, the later overshoots target position up to 20 um and backs off...
  • tietouwa
  • tietouwa's Avatar
25 Aug 2026 08:41
IgH 1.6.9 MEASURE_TIMING 1 kHz on Debian 13 RT, N100, I226-V + ec_igc (isolcpus
Category: EtherCAT
Hi, first post. This is IgH only (not LinuxCNC), 1 kHz servo/press application.
Hardware / software
- CPU: Intel N100 (4 cores)
- Distro: Debian 13 (Trixie)
- Kernel: 6.12.101+deb13-rt-amd64, PREEMPT_RT
- IgH: 1.6.9, native driver ec_igc
- NIC: Intel I226-V (8086:125c), dedicated EtherCAT port
- Slave idle in PREOP during the test (application stopped)
- Governor: performance (cores locked 700-800 MHz)
CPU isolation (cmdline)
isolcpus=managed_irq,domain,3 nohz_full=3 rcu_nocbs=3 irqaffinity=0-2
intel_idle.max_cstate=0 processor.max_cstate=0 idle=poll
RT thread is pinned to isolated CPU3 with SCHED_FIFO.
Measurement
Same method as examples/dc_user MEASURE_TIMING:
clock_nanosleep(CLOCK_MONOTONIC, 1 kHz) wakeup latency, then only
receive / process / queue / send. No PDO mapping, no CiA402.
SCHED_FIFO 90, taskset -c 3, 60 s / 60000 cycles.
Wakeup latency (µs)
min / p50 / p90 / p95 / p99 / p999 / max / avg
= 6.311 / 6.901 / 10.717 / 10.898 / 11.143 / 11.592 / 29.024 / 7.741
Question: for I226-V + ec_igc on 6.12-rt, is this in the expected
range for 1 ms, or do people still prefer I210/igb for the worst-case
tail?
Thanks.
  • Otatiaro
  • Otatiaro
25 Aug 2026 08:36
7i95T PktUART: no usable TX output with either official bitfile
Thanks Peter. Same md5 here for both files, Modbus block on TB4-14..17 with 1v3pkt, so neither the bitfile nor the wiring is the difference — and the transceiver, pad and connector are proven by the 7i84 running error-free in sserial on that same port.
Since it works for you with a plain setup, could you post the minimal config you tested on master — the mesambccc file and the HAL lines — and say whether tx-drv-en.invert_output appears in it? On my card the driver is never enabled during TX without it (checked on the analyzer), and I see no polarity handling for "Drv Enable low" in pins.c.
Which master build was it? Mine is 2.10.0~pre0.6386 (g3cd702c690).
One correction to my report: all symptoms, including the dead transmitter, were reproduced across several full power cycles, so it is not a stuck state.
I will re-flash 1v3pkt from the md5-verified file and redo a minimal test with a single hm2_modbus transaction and the analyzer directly on TB4-16/17, no raw register writes, and post the capture.
  • Gile65
  • Gile65
25 Aug 2026 08:34
Retrofitting an old industrial CNC Plasma table
Category: Plasmac
Hu Gemox,A plasma cutter generates a huge amount of electrical noise, so all signals should be galvanically isolated.For this reason, I would not recommend the Mesa 7i97. Instead, I would use a 7i83 for the analog outputs, since it provides galvanic isolation from the rest of the control system.To determine the complete hardware configuration, the machine’s existing electrical schematics would need to be reviewed.A THCAD2, or an equivalent interface, is necessary to measure the plasma arc voltage. This voltage measurement is used by the torch height control to maintain the correct distance between the torch and the plate.I would not recommend using a stepper motor for the Z axis, as it may not be able to achieve the required speed.How are you planning to generate the G-code?
  • tuxcnc
  • tuxcnc
25 Aug 2026 03:47
Replied by tuxcnc on topic Breakout Board Speed Control
Category: Basic Configuration
this would work, right?
Yes, this is a very similar circuit to the one used in BOB and will work identically.
The difference is that the power supply for this circuit should be not used for anything else, that BOB does not provide.
Voltage is a potential difference and is measured between two points.
The same wire, it may be 12V to the second pole of the power supply, but hundreds of volts to machine chassis.
  • grandixximo
  • grandixximo's Avatar
25 Aug 2026 02:55
Replied by grandixximo on topic Threading Index Varies With Speed
GH, I don't get the email notifications here, and I have to remember to check
25 Aug 2026 02:06
Replied by tommylight on topic Mesa 7i76eu Encoder Questions
store.mesanet.com/index.php?route=produc...oduct&product_id=399
Click on "specification" then Download Support Software
  • Chaney101
  • Chaney101
25 Aug 2026 01:31
Replied by Chaney101 on topic Mesa 7i76eu Encoder Questions
Did you download this through the pcnconfig or the browser?
  • Logthor
  • Logthor
25 Aug 2026 00:14
Replied by Logthor on topic Breakout Board Speed Control
I would think something like this would work, right? It has a PC817C, so I figure it is used to optically isolate the two circuits. What has me slightly concerned is that the listing (and many others) don't mention the fact that they are optically isolated (does this mean that it isn't?).
  • Logthor
  • Logthor
24 Aug 2026 23:56
I see what you mean now about it not being properly isolated. I'll buy a cheap board off of amazon. In the mean time though, I just want to make sure I know how to set it up in general. I just want to know why I'm not getting anything out of it when I issue a s command.
Displaying 1306 - 1320 out of 12531 results.
Time to create page: 0.340 seconds
