  • PCW
  • PCW's Avatar
12 Sep 2025 01:03
PnCconf Mesa 7i96s PWM speed control OUTPUT_SCALE
Category: Driver Boards
Yes, but the pncconf spindle setup also works with other devices with fixed 10V or +-10V  full scale
(7I77,7I76,7I83 etc)
It really should have an additional field for potentiometer type outputs based on the card type
Maybe "Full Scale Analog Output" and "Voltage For Maximum RPM" or some such
  • rhscdn
  • rhscdn
12 Sep 2025 00:54 - 12 Sep 2025 00:55
Thanks PCW! The quick reply saved me much head scratching. I will admit that I find this area of the setup a little confusing. Isn't the Mesa 'Spindle Out' voltage fully defined by the input Spindle+ and Spindle- values? Given a potentiometer wiper can never have a voltage higher than its input, what is the need for specifying the 'analog Max Voltage' at all?
  • royka
  • royka
12 Sep 2025 00:31
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Yeah I've seen it before, I believe it's a bug with the version of Mesa you're using.
Compiling a new version of mesa with panfrost would likely solve it.
Otherwise I'd suggest to take a new Armbian image and install the 6.1.115 kernel from: drive.google.com/drive/folders/1sPtbXDfx...WCB8o-ur0CINmMNvcjTQ
With the overlay "opi5plus-fixedfreq-undervolt.dts" it has a very low latency. You only need to remove the "-plus" at comparability and after that install it with "sudo armbian-add-overlay opi5plus-fixedfreq-undervolt.dts"
  • PCW
  • PCW's Avatar
12 Sep 2025 00:22
Its because pncconf assumes that the PWM full scale is always 10V so if you specify 5V
Is sets the scaling so that you would get 5V (1/2 of full scale scale) at 18000 RPM.
Just leave the "analog Max Voltage" at its default 10V
  • rhscdn
  • rhscdn
12 Sep 2025 00:03 - 12 Sep 2025 00:05
I'm setting up my machine and 7i96s using PnCconf and have had some issues with the spindle speed control. My VFD expects an analog 0-5v signal for speed control, i.e. 0v stopped, 5v 18000 RPM. It is open-loop, no spindle encoders. The motor has 2 poles and the drive frequency at 18000 RPM is 300 Hz. When I generate my .ini and .hal files with PnCconf I get the following in my .ini file.
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 18000.0
OUTPUT_SCALE = 36000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 18000
With these settings, when I specify a speed of 18000 RPM (M3 S18000), I'm seeing less than 200 Hz on the VFD display and the spindle seems slower than I expect. Looking through the forums, I see most examples have OUTPUT_SCALE=MAX_OUTPUT. Sure enough, when I change the .ini file and set OUTPUT_SCALE = 18000, and command the spindle with M3 S18000 I get 300 Hz on the VFD display and a higher speed at the spindle. Can anyone explain what is going on here? Have I done something foolish? Any ideas on why OUTPUT_SCALE is configured as 36000 in PnCconf?
  • ccc774
  • ccc774
11 Sep 2025 23:29
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
Hello everyone,
I installed linuxcnc 2.10 on orange pi5 - with armbian + rt-kernel 6.1.75. The system was made a year ago, and I installed linuxcnc 2.10 now with old versions of dependencies, to keep the 3D acceleration functional.
The problem is that at startup I get the error:
python3: ../src/mesa/state_tracker/st_texture.c:73: st_texture_create: Assertion `height0 > 0' failed.
/usr/bin/linuxcnc: line 1005: 24283 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS "${EXTRA_ARGS[@]}"
Does anyone have an idea if it's a bug in linuxcnc, or the error appears as a result of a conflict?
  • cmorley
  • cmorley
11 Sep 2025 23:08
Having issues calling ACTION.CALL_MDI() from python handler
Category: O Codes (subroutines) and NGCGUI
linuxcnc.org/docs/stable/html/gui/gladevcp-libraries.html
I don;t see anything you have done wrong.
The status library seems not to be able to poll.
Is linuxcnc running when you ran the glade panel?
This might be useful too:
linuxcnc.org/docs/stable/html/gui/gstat.html
  • Gusgus
  • Gusgus
11 Sep 2025 21:32
Hi!
So the cnc is now moving and it was the SPI cable shielding!!! Thank you Scotta and tommylight!!!
But now we have another, issue, we are using 2 stepper motors for the Y-axis each of the stepper motors is connected to one stepper driver and we have the config setup in a way so that joint 1 pulses both, but that doesn't seem to be happening, only on Y motor moves, and the x axis moves as well, the z axis actually just doesn't move at all.
  • scotta
  • scotta's Avatar
11 Sep 2025 20:28
Is that the config file you have loaded? There are no TMC5160 driver configuration in your config. For each stepper you need to load a stepgen, as you have done, as well as configure the TMC driver. I'll share a config over the weekend.
  • Will_cnc
  • Will_cnc
11 Sep 2025 19:48
Step By Step Help Needed . EL8 Leadshine to PI 5
Category: EtherCAT
Hi Shemj,Thank you so much for your help with getting the EtherCAT drives set up! Following your guide, I’ve successfully managed to connect all three drives, and they’re now running with the Probe Basic interface. The only step left is calibrating them to get the correct mm/rev on each axis.I’d really appreciate some suggestions on how to connect the spindle drive:
  • Current setup:
    • The machine’s three axes are using EtherCAT, connected through a daisy chain of Ethernet cables.
    • The spindle came with a 1.2 kW generic Chinese servo motor and drive, which has a 15-pin RS-232 serial connector.
  • Questions/options I’m exploring:
    1. Using Beckhoff hardware:
      • I have a Beckhoff EK1100. Could this be used with the appropriate module to control the spindle servo drive?
    2. Using a Mesa board:
      • Would connecting a Mesa board to the Pi via a USB-to-Ethernet adapter work, or would that introduce unnecessary complications?
    3. Alternative hardware setup:
      • Replace the Pi 5 with something like an Odroid H4 (dual Ethernet ports). That way one port could handle the Mesa board and the other the EtherCAT drives.
    4. Replacing the spindle drive:
      • The supplied spindle drive is an XCSD-20A from cncservocontrol.com. Are there any EtherCAT-compatible alternatives that would work with my motor?
  • Motor details:
    • Model: 80ST-M04030LBP
    • Power: 1.2 kW
    • Current: 5.2 A
    • Voltage: 220 V
    • Torque: 4.0 N·m
    • Speed: 3000 rpm
    • Encoder: 2500 PPR
If anyone has advice or suggestions on the best approach to integrate the spindle motor/drive, I’d be very grateful!
  • MaHa
  • MaHa
11 Sep 2025 18:38
Having issues with oword test scripts in version 2.9.4
Just in case it's not solved yet:
Use capital letters for ini file entrys...
[LASER]
LASER-OFFSET-X = -3.1702
LASER-OFFSET-Y = 0.0568
[PARK]
PARK-OFFSET = 0.125
[PROBE]
Z-OFFSET = 0.543
11 Sep 2025 17:58
Replied by tommylight on topic Plasmac Post Processors
Category: Plasmac
There are no
N75 M3 $0 S1
in the gcode after the first piece, and no M5 at the end of the cut except for the first cut.
Those must be added by the post processor.
  • tymko
  • tymko
11 Sep 2025 17:42
After installing probe screen, G-code does not start
 remap=m6 modalgroup=6 prolog=change_prolog....
  • tymko
  • tymko
11 Sep 2025 17:33
maybe I solved the problem, I removed one line of code from ini.file, I don't know if it was a good solution but for now everything works
Displaying 13051 - 13065 out of 13747 results.
Time to create page: 1.281 seconds
