  • bladekel
  • bladekel
22 Jul 2025 18:33
How to control brake before moving ? was created by bladekel
Category: HAL
I have an axis that I use with a stepper motor with brake. Before this axis starts moving, I have to disable the brake, wait for the mechanical delay and then move it. And when the movement is finished, I have to activate the brake immediately. I used the following commands to do this.
loadrt ddt count=1
loadrt abs count=1
loadrt comp count=1
loadrt timedelay count=1
loadrt not count=1
addf ddt.0 servo-thread
addf abs.0 servo-thread
addf comp.0 servo-thread
addf timedelay.0 servo-thread
addf not.0 servo-thread
# Joint 3 movement detection
net joint3-pos-cmd joint.3.pos-cmd => ddt.0.in
net joint3-velocity ddt.0.out => abs.0.in
net joint3-vel-abs abs.0.out => comp.0.in0
setp comp.0.in1 0.001
setp timedelay.0.on-delay 0
setp timedelay.0.off-delay 1
net joint3-moving comp.0.out parport.0.pin-14-out timedelay.0.in
net dontMove timedelay.0.out => not.0.in
net canMove not.0.out => stepgen.3.enable
I can do what I want in manual movement with these commands. But when I use it with mdi commands, it gives “joint 3 following error” error.
How can I solve this?
  • dunnitagain
  • dunnitagain
22 Jul 2025 18:22
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
That makes sense , this has Linear Scales for Feedback with Steppers.
  • Todd Zuercher
  • Todd Zuercher's Avatar
22 Jul 2025 17:55
Todd , what do the halscope files do ? Are they a test ? All the Bios settings appear to be correct , to allow the Boot from ISO, tried several times with Tommies advice , still no luck.
The halscope files are saved from the Halscope oscilloscope app. They are merely a record of the scope settings and signals that were being used at the time it was saved. So for example I have some Halscope files saved for the settings I use for tuning each of the servos on one of my machines. Using them makes opening and configuring Halscope quicker when doing something you might need to do the same again later or after a restart. But they certainly are not needed for running Linuxcnc.
  • kworm
  • kworm
22 Jul 2025 17:45
Replied by kworm on topic Servo Driver Plasma Retrofit
Category: Plasmac
You would replace /usr/bin/pncconf with the pncconf.py file, ie "sudo mv pncconf.py /usr/bin/pncconf". You might also need to do a "sudo chmod +x /usr/bin/pncconf". I would suggest making backup copies of those files first just in case.
  • claytoncramer
  • claytoncramer
22 Jul 2025 17:19
Is mini still available? was created by claytoncramer
Category: Other User Interfaces
I just upgraded from 2.7.14.  (No laughing please.)  I find the other supported guis not as friendly.  They have features of no value for a Sherline mill.
  • rubinstu
  • rubinstu
22 Jul 2025 16:51
Replied by rubinstu on topic Weird G54 orientation
Any have any thoughts on this? I'm kind of stuck! Thanks
  • Kieran
  • Kieran
22 Jul 2025 15:49
Fusions CAM drives me crazy - Axis out of bounds
Category: Fusion 360
It sounds like something was up with your offsets. Are you using g54? Make sure to switch into g54 or 55, 56, ect before touching off. That, or maybe you had cutter comp on and a large diameter in the tool table?
22 Jul 2025 15:03
Replied by tommylight on topic (solved) python error on startup
as an aside, how do i mark this as answered ??
Done, thank you.
22 Jul 2025 14:59
Replied by tommylight on topic Set program zero using XY positioning laser
BUTTON_1_NAME = ZERRO\Materialit
BUTTON_1_CODE = G10 L20 P0 X89 Y29.5 \ G53 G0 Z-10
This is just to give you an idea, i use this on my plasma machines with laser cross.
  • GDTH
  • GDTH's Avatar
22 Jul 2025 14:57
Replied by GDTH on topic Hot reload/update carousel probe basic
Category: QtPyVCP
Okay, I've been looking into this. I've already added exceptions for all the unique tools. The main feature I want to add now is the ability to switch tools between the spindle and carousel without unloading the tool from the spindle. To make that work, I need a way to store the current tool number somewhere temporarily.
At the moment, I'm trying to find a method to manually edit the carousel positions—specifically, assigning a tool number or 0 to each slot.
I think the simplest approach might be to build a custom UI. I’m not entirely sure how to implement it yet, but I’m imagining a subroutine that lets you set a given tool number into a specific carousel slot (addresses 4001–4012).
I briefly considered removing the randomisation from tool numbers, but that doesn’t really help with the main issue. What I need is a fast way to manually update the carousel—without relying on the machine to handle the full tool change process.
What's strange is that I haven’t come across anyone else doing this, at least from what I’ve been able to find. If anyone has suggestions, I’d really appreciate them.
  • PCW
  • PCW's Avatar
22 Jul 2025 14:27
Trouble with LinuxCNC and Gantry stepper motor setup.
You do not absolutely need to have switches on a gantry
but if not, you need to use an "immediate" homing setup:
linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
  • CADdy
  • CADdy's Avatar
22 Jul 2025 14:05
Replied by CADdy on topic Starting with QTVCP - need a little help.
Category: Qtvcp
Hi Chris,
yes, it is now. I'm going to start a few experiments now. Thank you very much for your tip!
Peter
  • Revinvoss
  • Revinvoss's Avatar
22 Jul 2025 14:04
So, I will need to install physical limit switches to the table for this homing setup?
Is there a tutorial and were for wiring limit switches correctly to the control board ST-V3. As I do not have any switches install at this time. It never needed them when I had the table setup for Plasma cutting. Now I have changed to Router it seems that this is an issue.
  • Benb
  • Benb's Avatar
22 Jul 2025 14:04 - 22 Jul 2025 14:09
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
You need to keep name  for axis z as joint2. I noticed in your ini file you using the name joint 1 that should 2.
For the exposed pin from the vista pedant keep the names of the axis as number example vc-p1as.axis.0,
I attached revised hal file check for typos
revise your own ini file for joint names (numbers)
edit:
have read through this thread:
forum.linuxcnc.org/38-general-linuxcnc-q...ling-to-share#261003
  • scsmith1451
  • scsmith1451's Avatar
22 Jul 2025 13:53
Set program zero using XY positioning laser was created by scsmith1451
Hi all;
I've been converting from MACH3 to LCNC. In MACH3 I had configured an XY positioning laser using a macro that would allow me to jog to the program zero for a given project, then once positioned at the appropriate point I would click on a button that would calculate the X/Y offsets, move the spindle to the true program zero then set the G54 X/Y DROs to zero. This was very fast and accurate way to perform this task and along with a tool probe to zero the Z axis, program home is quickly established.
I would like to do something similar adding a button in the pyVCP to turn on the laser and once positioned a second button to compute the offsets, move the spindle to program zero, set the X/Y DROs to zero and turn off the laser.
Searching the forum, I've not found any info to work from. Has anyone configured a positioning laser on their system?  I'm a little rusty on my Python, but I can get back into it quickly or would classic ladder be a better option?  Any help would be greatly appreciated.
Kind regards
Displaying 13891 - 13905 out of 14620 results.
Time to create page: 0.473 seconds
