  • PCW
  • PCW's Avatar
09 Jul 2025 22:00
Replied by PCW on topic poor surface quality
As had been suggested before, it looks like the drives themselves need tuning.
  • PCW
  • PCW's Avatar
09 Jul 2025 20:49
Replied by PCW on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
Not a firmware issue.
I would not expect motion until you enable the drives.
If there is an analog output issue, it typically shows up as a non-zero
output voltage when the 7I77 is powered.
  • Sternfox
  • Sternfox
09 Jul 2025 20:46
Replied by Sternfox on topic poor surface quality
Hi tommy,
The voltage was the same at both drivers. I have dug a bit deeper and used Halscope and probed
Joint.0.motor-pos-cmd against hm2_7i95.0.encoder.01.position
For both X and Y, I cut a few circles using arcs, and this is my result. Looks like the motor isn't keeping up with the encoder?
I wasnt sure what /k to use, so I have attached two screenshots, one all even /k and some scaled to fita better curve. This is all new to me so apologies in advance.
I'm using Step/Dir Servos, I have just temporarily fed the endcoder back to LinuxCNC for testing.
Im using 1kw ac servos by Litchaun 4NM the machine is a Haas mini mill. any thoughts?
  • Sternfox
  • Sternfox
09 Jul 2025 20:38
Mesa 7i95T spindle step/Direction setup using stepgen
Category: Driver Boards
File Name: main_2025-07-09.hal
File Size:12 KB
It works perfectly, will attach my hal for others to use
09 Jul 2025 19:59
HUGE Mazak fully automated 5 axis laser cutter for pipes/tubes/profiles/
Category: Show Your Stuff
that things sick, i wish i worked around something that epic and complicated,
And terrifying !!! :)
You see those big things on both ends of the machine with the rotating parts? Those move at 60m/m when at full tilt so the whole concrete floor shakes so much that the left servo drive errors out with over current!!! No errors when moving one or the other, just both. At 50m/m all is fine.
15cm of concrete is not enough rigid for all that monstrosity, but no one ever told them. I would venture a guess at least 30cm or 50cm just to be on the safe side, but i am no expert.
09 Jul 2025 19:46
Replied by tommylight on topic Disable probe on plasmac
Category: Plasmac
This is the third time i am reading this and still makes no sense.
If you browse a bit through this forum, you can see i have/use/built over 20 CNC plasma machines, so it is very hard to understand why would you change something that works perfectly for something else that will not work at all, or will work ONLY if you have a perfectly flat table and perfectly flat material.
Makes even less sense if using THC as that takes over control of Z axis, so does not matter what you put in the tool table.
Lack of replies should have alarmed you to something being off as there are plenty of Plasma machine users here willing to help anytime.
Material will warp during cutting, always, some more and some less, so using a plasma with no THC is possible but not enjoyable at all, and causes messed up nozzles and bad cuts.
I am pretty sure QtPlasmaC has a feature to skip probing for a given distance to reduce probing time, but i never use it.
I want to press "run" and go do something else while the machine does it's job.
09 Jul 2025 19:35
Replied by tommylight on topic My CNC with EtherCAT and Mesa card
Pictures of the machine?
09 Jul 2025 19:34
09 Jul 2025 19:25
Replied by tommylight on topic Bios error during lcnc start
That means if a PC running Linux happens to break, you can just take out the HDD and plug it into another PC and it will work no fuss, no muss.
Yes, for the last 20 odd years Linux could do that, even through external USB cases and/or CD/DVD rom's.
That is very hard to explain to "PC experts" who used windows only as that never worked, till win10 had that haphazardly implemented and intermittently working about 5% of the time.
"""ntldr not found""" :)
  • PCW
  • PCW's Avatar
09 Jul 2025 19:12
Replied by PCW on topic HY_VFD RS-485 HAL config
Just guessing that the port migration is because USB communications were
lost due to EMI as soon as the VFD started.
Does the VFD have a line filter?
I would keep the USB cable as short as possible and try wiring the RS-485 connection
through a common mode choke (a large ferrite bead)
Also check the VFD frame grounding
VFDs radiate EMI like a radio station, and USB is typically quite poor
in EMI resistance.
  • PCW
  • PCW's Avatar
09 Jul 2025 17:36 - 09 Jul 2025 17:57
Koike Aronson Plasma Conversion - sanity check on Mesa board selection?
If the ferror is in the opposite direction of the velocity plot, FF1 is too high (first plot, FF1 = 1.8 is too high)
If the ferror is in the same direction of the velocity plot, FF1 is too low (second plot, FF1 = .027 is too low)
On the polarity, it should be checked with a voltmeter and the most positive lead goes to the OUT+ pin.
  • scsmith1451
  • scsmith1451's Avatar
09 Jul 2025 17:19
Replied by scsmith1451 on topic HY_VFD RS-485 HAL config
Spoke too soon.
After verifying the VFD parameters and the loadusr arguments to insure matches, I was able to issue a M3 S6000. The spindle enable relay activated and the spindle ramped up to 6000. However, M5 did nothing and I had to stop the spindle with the VFD control panel.
Next I tried to rerun the M3 S6000 command. I heard the relay activate, but the VFD did not respond. I shut down and restarted LCNC this time it failed to restart complaining that about not being able to communicate with the VFD. Checking dmesg I found that the dongle had migrated from ttyUSB0 to ttyUSB1? I updated the custom.hal and restarted LCNC without issue. This time I issued a M3 S10000 which worked perfectly. but again M5 was ignored.
I've now gone through this sequence several time and each time the VFD starts at the requested speed, then fails to stop. Each time the dongle migrates to a different ttyUSB1/2 port. The last time I issued a start command I noticed that the pyVCP display did not show the speed nor at speed and as I was monitoring the display I saw the OS notify that the dongle had again reattached at a different port.
At this point I'm confident that I can communicate via hy_vfd to VFD, but I'm frustrated that the dongle keeps toggling between ports on its own. Any ideas what is going on and how to resolve the issue?
  • Esaber
  • Esaber
09 Jul 2025 17:05 - 09 Jul 2025 19:35
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
How about reflashing the mesa 7i77 firmware?
I started linuxcnc in debug mode and when I enable the machine I get this error:
joint 0 following error
emc/task/taskintf.cc 976: Error on joint 0, command number 226
task: main loop took 0.112439 seconds
  • Benb
  • Benb's Avatar
09 Jul 2025 17:00 - 09 Jul 2025 17:06
Best HAL function 2 contol bits for S32 in, 1 of 4 out?
Category: HAL
An alternative approach is to create a custom mux2u32.comp component by adapting the existing mux2.comp—replacing its float data types with u32. Once modified, you can compile it with halcompile and integrate it  into your local LinuxCNC.
  • Kieran
  • Kieran
09 Jul 2025 16:34 - 09 Jul 2025 16:42
Replied by Kieran on topic Do I need a better PC?
Category: EtherCAT
Im finding it quite hard to track down a mini itx or micro atx mobo with intel NIC. they all like to use the realtek it seems.
Maybe i should just get an add on card with intel chips?
Displaying 14416 - 14430 out of 14639 results.
Time to create page: 1.740 seconds
