  • wusel0464
  • wusel0464
04 Jun 2025 15:52
Replied by wusel0464 on topic Reading variable from ini no longer works?
Category: Qtvcp
Hello,
According to today's update of Linux CNC 2.10, the comment in the INI is still not recognized as such.
This modest entry is already sufficient.
WL_POS_X = 6.934 #
Without a comment, everything works normally.
It would be nice if someone could see over the knowers.
Thanks and best regards, Frank.
  • PCW
  • PCW's Avatar
04 Jun 2025 15:49
Replied by PCW on topic LinuxCNC compatible industrial PC
Perhaps his ethernet is just really, really speedy.
Not physically possible with a 100BT link
100 Mbits/sec is 12.5 bytes/usec = ~5 usec for a minimum size packet
since packets need to be sent and echoed that's ~10 usec absolute
minimum for the smallest  (64 byte) packet (ignoring overhead and response time)
  • workshop54
  • workshop54
04 Jun 2025 15:49
Replied by workshop54 on topic LinuxCNC compatible industrial PC
I tried to get the Mesa card on 10.10.10.10, but I never got that to work. I tried mesaflash --device 7i94t --addr 192.168.1.121 --set ip=10.10.10.10 before, but that didn't seem to change the boards IP address.
I ran the test again an now the values are probably more realistic:
$ sudo chrt 99 ping -i .001 -q -c 60000 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
--- 192.168.1.121 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.054/0.140/0.494/0.027 ms
What do you think about these values, and if they are good, are there any other tests you can recommend for this PC before I go all-in?
  • andypugh
  • andypugh's Avatar
04 Jun 2025 15:20
GUI that somewhat resembles haas or fanuc workflow.
The discussion ot touchscreens missed out a third tech, Surface Acoustic Wave. I actually delibearately seek these out, as they have a hard glass front panel for scratch resistance, but are not as easily false-triggered as capacitive.
I use Touchy + jogwheel on both my machines, it suits me. The MDI tab is rather neat.
  • Aciera
  • Aciera's Avatar
04 Jun 2025 15:10
Replied by Aciera on topic xml and hal - I am lost
Category: EtherCAT
I always stuck in error I can`t resolve by myself for now.
1. It's usually a good idea to attach any error messages you get.
2. Share your config folder (compress and attach here)
  • cakeslob
  • cakeslob
04 Jun 2025 15:03 - 04 Jun 2025 18:26
Here is my current attempt to have a fanuc like gui
github.com/cakeslob/regularmac_800
I dont have all the controls mapped to the Tab/arrow keys yet, or a softkey menu
What would be a short list of requirements for an industrial screen?
No axis movement without START button?
No graphics?
Mostly text styles or more modern graphical elements?
Multi function soft keys? Hardware only keys.
What target monitor size?
Etc.
Fanuc has a nice workflow because you dont have to screw around with a mouse and find buttons and stuff like that.
- Not everything needs to be on the screen at the same time.
- I dont think people have a problem with graphics, most stuff is crude text shortforms.
- It uses a combo of hard keys for each menu -(some multi press buttons, ie press offset for tool, press offset again for work offset) and soft keys that change with each menu
- you can load/setup/run the program with like 5 buttons(some soft) + arrow keys
- some modes (ie edit/MDI/Jog/pendant/auto) disable other features , so you cant run a program from edit mode, you can edit a program in MDI mode, you cant jog in auto, etc
-the whole gui is bacically controlled by pg up/down, arrow keys, and function keys
- monitor aspect is usually 1:1 square, but thats uncommon in consumer stuff, so 4:3 is closest
- no axis movement until start button. so any probe routines or toolsets, you need to press cycle start.
Not sure what GUI you are using but it seems to me that you might not have given the existing GUIs much consideration other then the fact that it does not look and feel like the controls you are used to.
External buttons can be implemented with most GUIs. Start/stop/pause, jogging, overrides, homing, etc. with physical buttons, encoders and potentiometers. This has been possible for a long time.
None of my machine refits use screen jogging buttons and _certainly_ no keyboard shortcuts.
Also tool and work offsets pages have been around for years.
As an example, Gmoccapy which I use, but there are others:
linuxcnc.org/docs/html/gui/gmoccapy.html#_hal_pins
I have tested out every gui to find the most similar one. All the GUI could be made to be like fanuc style, The cloest ones to fanuc style workflow were keystick and mini, but its been a long time since I was able to use those so maybe its nostalgia. Qtdragon or the smaller one could be made to work like fanuc style with not to much changes, but it would be more python backend behavior for keyboard behavior/navigation (no mouse needed), and softkey stuff than actual GUI organization, the layout of the small one (woodpecker?) is pretty close to what fanuc stuff looks like .
  • PCW
  • PCW's Avatar
04 Jun 2025 14:32 - 04 Jun 2025 14:41
Replied by PCW on topic Index homing Heidenhain ls 403/exe602
Category: Basic Configuration
I figured it could be tested with a normal rotary encoder by setting the "home" detection
index interval to the CPR of the encoder, so 2 index detection's with the proper delta
would arm LinuxCNC's index search.
I guess a fancier scheme would use it as an absolute scale ( generate the correct absolute
position after any  two index detection's  and a table lookup ) but I think that would need
a new homing routine rather than just a hal component.
  • PCW
  • PCW's Avatar
04 Jun 2025 14:20
I'm not sure what you mean PCW,
Your initial ping statistics had 3 and 4 usec times which are not
possible unless you are pinging the host.
Also the address range of enp3s0 overlaps enp2s0
This is why it's suggested to use the FPGA cards 10.10.10.10 address.
( as it will not overlap a local network DHCP range )
  • PCW
  • PCW's Avatar
04 Jun 2025 14:02 - 04 Jun 2025 14:04
The N100DC draws no more than ~20 W...
Basically a laptop CPU in a Mini-ITX format
  • PCW
  • PCW's Avatar
04 Jun 2025 13:57
Replied by PCW on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
It would be easier with a starting hal/ini file set because
while the Mesa and LinuxCNC pin names are known,
the specific signal names used are configuration dependent.
(signal names are arbitrary and everyone uses different ones)
  • alexandrap
  • alexandrap
04 Jun 2025 12:55 - 04 Jun 2025 12:56
Replied by alexandrap on topic Updating pncconf for 7i95t
I resigned.
Can you tell me what lines you would put in the fictitious .hal and .ini files to make the step-dir spindle work?
for lathe config XZ(C?)
Or a link to an example.
thanks
  • cmorley
  • cmorley
04 Jun 2025 12:47
Replied by cmorley on topic indicatorPushButton led hal pin
Category: Qtvcp
The led name will be the button name with '-led' on the end.
in the above example the pin name would be 'SCREENNAME.mybutton-led'
  • andypugh
  • andypugh's Avatar
04 Jun 2025 12:34
Replied by andypugh on topic Index homing Heidenhain ls 403/exe602
I checked my randomly-purchased liner scale (found at EMFCamp) and that is an LS 903 (no C) so is probably no help.
  • andypugh
  • andypugh's Avatar
04 Jun 2025 10:22
Replied by andypugh on topic LinuxCNC compatible industrial PC
Late to the party, but I have recently switched both my machines to run from the Asrock N100DC-ITX board.
Latency is "fair" rather than good. But they are avaialble, run from 12V DC and can be booted from an M2 SSD for a neat installation in the machine cabinet.
www.mini-itx.com/~N100DC-ITX
(Unhelpfully, out of stock, maybe because I bought three of them from there.)
Apparently they are picky about memory, especially at 12V rather than 19V, so maybe buy memory at the same time.
  • andypugh
  • andypugh's Avatar
04 Jun 2025 10:13
Replied by andypugh on topic Toyota embroidery machine - retrofit
Category: CNC Machines
You might want to set feed-hold when the needle is down, and release it when the needle is up...
Displaying 14941 - 14955 out of 16326 results.
Time to create page: 0.372 seconds
