28 May 2025 09:27
Spindle Speed Settings only from file, no MDI possible?
Might also need $0 for the first spindle, so
M3 $0 S12000
  • zz912
  • zz912's Avatar
28 May 2025 09:17
Replied by zz912 on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Why don't you make this a Pull Request?
  • Aciera
  • Aciera's Avatar
28 May 2025 09:10
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
I've decided to include G28 and G30 position:
Files are here for anybody interested (based on current master)
File Name: offsetpage.glade
File Size:19 KB
File Name: offsetpage_widget.py
File Size:27 KB
Note
rows 1-3 (Tool, G28, G30) are not editable. (The comments of those CAN be changed in the .pref file though)
'offsetpage_widget.py' seems to have been written to be used by other Gui(s) as well. I have only tested this on Gmoccapy (there are substantial sections of the code that are not used in Gmoccapy)
  • jackj120
  • jackj120
28 May 2025 08:58 - 28 May 2025 09:00
Replied by jackj120 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
Good to know samlevy0515 , do you know a good place were to buy them ? I found them on the sites that i named .
  • jackj120
  • jackj120
28 May 2025 08:54
Hi, yes im the same guy , the machine its giving me some problems , btw if i can ask how much did you paid them ? I saw them for ~400 the motor and ~400 the drive. Leadshine seem a good product but idk i'ld like if someone can guarantee them for a professional work as the Delta , they seem pretty good at a really good price.
  • samlevy0515
  • samlevy0515
28 May 2025 08:50
Replied by samlevy0515 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
If you want 90% of Delta's performance at 60% cost, pick Leadshine.
  • unknown
  • unknown
28 May 2025 08:45
Replied by unknown on topic LinuxCNC compatible industrial PC
Just run the latency tests that come with linuxcnc. If they look ok go with it.
But I've never had much faith with the Atom platform for Linuxcnc.
  • workshop54
  • workshop54
28 May 2025 08:14
Replied by workshop54 on topic LinuxCNC compatible industrial PC
I did some configuration and testing on the Fitlet3.
I made changes in the BIOS, ran the script created by mozmck ( forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity ) and did the latency test (results in the thread forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity ). It doesn't look too good so far for the Fitlet3.
Does anyone have ideas on how to improve it because I'm all out of ideas (for now)
  • Hakan
  • Hakan
28 May 2025 08:10
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
Can you please confirm that you do not see the 16-bit shift in Codesys.
Can you also please confirm that you see/don't see the 16-bit shift in linuxcnc using <complexentry>
Please show the output when you in linuxcnc enter test-values for the bit-outs pins. Do all  32 pins individually.
Change the line <pdoEntry idx="7010" subIdx="01" bitLen="32" halPin="bit-out" halType="bit"/> to <pdoEntry idx="7010" subIdx="01" bitLen="32" halPin="bit-out" halType="u32"/> and redo the bit output test. Do one bit at the time. All 1,2,4,8,16, 32, 64,128, and so on up to the 31th bit.
Show the input and output for all these tests in a way that one clearly can see and correlate the linuxcnc input and the drive output.
Can you please show the output of "ethercat -p 1 -m 1 pdos" Modify the p and m field values as needed to get the output from the tested unit.
Can you please provide a screenshot from Codesys of the definition of the output variable. To include at least pdo index, pdo entry index, subindex, datatype and datatype length.
  • workshop54
  • workshop54
28 May 2025 08:08
Results of latency test, list of computers tested for use with LinuxCNC
I just did the latency test on a Fitlet3 after making some changes to the BIOS and running the script from forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
LinuxCNC pc tests, version 20200930, started 28.05.2025 09:37:54
General info:
Compulab,  fitlet3
Bios version FLT3.TPM.00.09, dated 06/08/2024
Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name    : Intel Atom(R) x6425E Processor @ 2.00GHz
cpu cores    : 4
stepping    : 1
cache size    : 4096 KB
RAM related data:
Maximum Capacity: 16 GB
Maximum Voltage: 1.2 V
Non-Volatile Size: None
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Size: No Module Installed
GPU related data:
product: Elkhart Lake [UHD Graphics Gen11 32EU]
configuration: depth=32 driver=i915 latency=0 mode=1920x1200 resolution=1920,1200 visual=truecolor xres=1920 yres=1200
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager       : Xfwm4
Displaymanager      : lightdm
Kernel related data:
Kernel 6.1.0-35-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_idle.max_cstate=0 idle=poll isolcpus=3 nohz_full=3 rcu_nocbs=3 i915.enable_rc6=0"
Cpu idle driver: none
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech Trackball
Mice  attached to USB:
Keyboards attached to USB:
Logitech, Inc. Keyboard K120
LinuxCNC related data:
LinuxCNC version is: 2.9.4
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID
Command for latency test is:
su johan -c  "latency-histogram --nobase  --sbinsize 1000 --nox 2>&1 | tee -a 1748417872.lat &"
Latency testing loop started Wed May 28 09:38:08 AM CEST 2025,
should end after Wed May 28 11:38:08 AM CEST 2025
Manual termination requested at 28.05.2025 09:54:18
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 53.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 1: Tmin: 53.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 2: Tmin: 52.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
Core 3: Tmin: 52.0°C, Tmax: 61.0°C, (high = +105.0°C, crit = +105.0°C)
last latency data is as follows:.
The final output of the latency test:
^C
Stand by and let me stop gracefully...
  970 s  servo min:-409.600 us max: 404.900 us sdev:  15.700 us
  971 s  servo min:-409.600 us max: 404.900 us sdev:  15.700 us
Core 0:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 1:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 2:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Core 3:        +59.0°C  (high = +105.0°C, crit = +105.0°C)
Cleaning up
terminated latency-test ...
Closing browser firefox with WID of
There are no windows in the stack
Invalid window '%1'
Usage: windowactivate [options] [window=%1]
--sync    - only exit once the window is active (is visible + active)
If no window is given, %1 is used. See WINDOW STACK in xdotool(1)
Done.
Hardware info is logged here: 1748417872.hw.
Full latency-test data is logged here: 1748417872.lat.
Kindly place the contents of "1748417872.hw" here:
https://forum.linuxcnc.org/18-computer/39371-results-of-latency-test-list-of-computers-tested-for-use-with-linuxcnc
Thanks, and good bye.
  • Hakan
  • Hakan
28 May 2025 07:45
Replied by Hakan on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
It was mentioned an existing vfd, but to go pure ethercat an ethercat vfd is the way.
It got me to check the manual and yes it is RS-485 Modbus RTU.
  • Aciera
  • Aciera's Avatar
28 May 2025 06:48 - 28 May 2025 06:49
Replied by Aciera on topic woodpecker.ini - cant be loaded
I don't think anybody actively maintains the 'woodpecker' ui. It doesn't run on my 2.9.4 rip install either, fails with a different error.
I wish we wouldn't drag all these broken things along. A while ago I suggested to remove all the broken sim configs but I was not successful.
  • zz912
  • zz912's Avatar
28 May 2025 06:23
woodpecker.ini - cant be loaded was created by zz912
Hello,
I have RIP installation LCNC 2.10
I cannot woodpecker.ini in sim configs.
Is it bug or dont I have some packages?
zdenek@cnc:~/linuxcnc/linuxcnc-zz912$ linuxcnc
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/zdenek/linuxcnc/linuxcnc-zz912/configs/sim/woodpecker'
Machine configuration file is 'woodpecker.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./core_sim.hal
Found file(lib): /home/zdenek/linuxcnc/linuxcnc-zz912/lib/hallib/simulated_home.hal
[QTvcp.QTVCP.QT_MAKEGUI][CRITICAL]  'MachineLog' object has no attribute 'setFrameShape' (qt_makegui.py:213)
[QTvcp][CRITICAL]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.10.0~pre0
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 607, in <module>
    _qtvcp = QTVCP()
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/qtvcp", line 307, in __init__
    window.instance(filename=self.PATH.XML)
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/lib/python/qtvcp/qt_makegui.py", line 202, in instance
    instance = uic.loadUi(filename, self)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
    return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
    return self.parse(filename, resource_suffix)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
    actor(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
    self.traverseWidgetTree(elem)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
    handler(self, child)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
    self.stack.push(self.setupObject(widget_class, parent, elem))
  File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 230, in setupObject
    self.wprops.setProperties(obj, branch)
  File "/usr/lib/python3/dist-packages/PyQt5/uic/properties.py", line 417, in setProperties
    getattr(widget, 'set%s%s' % (ascii_upper(prop_name[0]), prop_name[1:]))(prop_value)
AttributeError: 'MachineLog' object has no attribute 'setFrameShape'
 (qtvcp:557)
'QTVCP' object has no attribute 'panel'
/home/zdenek/linuxcnc/linuxcnc-zz912/scripts/linuxcnc: řádek 990: 14734 Neoprávněný přístup do paměti (SIGSEGV)                     $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS "${EXTRA_ARGS[@]}"
task: 0 cycles, min=0.000005, max=0.010430, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/zdenek/linuxcnc_debug.txt
and
    /home/zdenek/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
  • Aciera
  • Aciera's Avatar
28 May 2025 05:28
Loading different configurations during startup.
Category: Basic Configuration
To load a config you basically execute a command line command. So you could have different Icons on your desktop for all the different setups.
The mesa board does not need to be reprogrammed as you can change things around in HAL.
I have machines with several different configurations (eg vertical milling, horizontal milling, turning, milling with slanted spindle).
  • juliankoenig87
  • juliankoenig87
28 May 2025 05:04
Replied by juliankoenig87 on topic Getting Setup with PC and MESA
Thinkcentre tinys (m73, m93, m710q ....) working great. They have Intel nics.
But also Fujitsu Esprimos working great with Realtek nics. To be honest we encounters over the past year, that realtek working a lot faster. Also pci realtek boards working damn good.
But yes, historically there were problems with realtek nics, so one can have problems. But I personally looking nowadays for realtek instead of intel, but I know what I have to look for.
For a beginner I would say a Lenovo Thinkcentre tiny (maybe with wlan on board) is a really good machie. Look for m73 or m93 with 8GB and ssd and you will be happy. Isolcpus needed! and of course the lines for the intel nic. Other than that no need for tweaking when speaking of 1kHz thread.
Displaying 15286 - 15300 out of 16336 results.
Time to create page: 0.393 seconds
