  • zz912
  • zz912's Avatar
27 May 2025 16:51 - 27 May 2025 17:12
Replied by zz912 on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
turtle:
rabbit:
  • Soccer Kid
  • Soccer Kid's Avatar
27 May 2025 16:50
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
Thank you for your kind help. I have already conducted a joint investigation with OFF in the group. At present, there is no good solution for the time being.
  • Soccer Kid
27 May 2025 16:40 - 27 May 2025 16:47
Category: EtherCAT
Sorry, due to my personal technical reasons, the detailed explanation of this issue will be very verbose.
In fact, I have made a detailed list of pins. Derived from idx00~31, the test results are the same. Additionally, I also tested other models of modules, and the xml used was almost exactly the same, but the test results were fine. Meanwhile, I received a message in other communities: Someone used the module of the same brand (with a different model), and the test results were fine.
I have recently conducted more module tests made in China and discovered some patterns. I will release the results later.
The current apparent result is that for the module I mentioned above, Linuxcnc can only read 16-bit data originated from ethercat PDO. Even for a data range of 32 bits.
Here are some examples: Please look at the picture
For this kind of problem, I plan to conduct network data packet analysis later. Later, I will provide detailed network data results. Thank you all.
  • my1987toyota
  • my1987toyota's Avatar
27 May 2025 16:23
Replied by my1987toyota on topic Why does it seem like everyone here is Australian?
I guess one of theses days I will have to give that one a go.
27 May 2025 16:12
Replied by tommylight on topic Up grading Debian 12 rt
In a terminal one line at a time
sudo apt update
sudo dpkg -P raspi-firmware
sudo apt dist-upgrade
27 May 2025 16:03
Replied by tommylight on topic 7i97T+7i74+7i84+7i73
Category: Driver Boards
Moved to "driver boards".
While waiting, you can use 7i84 OR 7i73 with 7i97T for testing or anything, without the 7i74, meaning only one at a time.
27 May 2025 16:00
Replied by tommylight on topic How to set up parallel port in Debian
Link i posted has working cards, and later in that topic also ways to check and sometimes make work some other cards.
27 May 2025 15:57
I would like to play Doom Eternal, but since i messed up my right index finger, it will have to wait.
Already on the third play through, still sweat a lot while paying on "nightmare"... :)
  • aaron
  • aaron
27 May 2025 15:52
Up grading Debian 12 rt was created by aaron
Hi
File Name: Upgradeerror.txt
File Size:2 KB
I have a fresh install of Debian 12 and I want to make sure everything is up to date, but when do 'sudo apt upgrade I get the error in the attachment;I am not sure how to fix this. Help would be much appreciated.
Aaron
  • Cdub
  • Cdub
27 May 2025 15:33
Replied by Cdub on topic M62-M68 codes not working
Category: Plasmac
I’m not too familiar with Hal but his is what I could find not sure if I’m even looking in the right spot.
  • Cdub
  • Cdub
27 May 2025 15:24
Category: Plasmac
Version is 2.9-238.315.
  • Aciera
  • Aciera's Avatar
27 May 2025 15:06 - 27 May 2025 15:09
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Traffic lights? Walk!!!
Cycle!
Problem might be that the material symbol and icon library doesn't contain a turtle and/or a rabbit:
fonts.google.com/icons
Anyway regarding the Offset page I came up with this:
  • Lampje
  • Lampje
27 May 2025 15:01
Mill setup troubles and questions (Speed display, at speed signal, coolant pump)
I've been away on sick leave for a bit.
Just getting back to work on ' trail' basis.
What i find is that there are some issues with the Z settings.
My machine is setup as 600x900x-200mm Home is 0,0,0 of course.
Procedure:
Home the machine.
Move the spindle and put the 3D probe in the ER collet.
Then run the Toolsetter macro. To my knowledge this sets the tip at 39.2mm above the bed.
Then I probe the work piece corner (werkstuk_tasten...) This should set G54 to the offsets from machine home, right?
Then I replace the probe with a mill (actually a lollypop stick for testing purposes). And run the toolsetter routine. I remove the workpiece to mill air while getting the bugs sorted out.
Then I load a program. The Touchy GUI shows the program movements etc on the screen. What i see is that it is correctly positioned in the X and Y but that the Z is to high up in the machine volume (red box on the screen).
Running the program errors out on that it runs out of Z distance wanting to go higher than is available.
So my question is on how to set the height coming out of the toolsetter routine.
The distance from Z-home (0) to the bed is unknown to enough of a certain height to be useable, right?
Or is there some other issue at hand?
  • Hastrh2o
  • Hastrh2o
27 May 2025 14:36
Replied by Hastrh2o on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
You can use the old drivers as Todd said. But, sometimes, changing everything is easier. I already kept old servos on a retrofit, then two years after I changed them because there were damaged .
Delta B2 are ok.
  • Muftijaja
  • Muftijaja
27 May 2025 14:29 - 27 May 2025 14:39
Spindle Speed Settings only from file, no MDI possible?
Hi langdons,
yes the chinese has only 1,5kW instead of 2,2, just 320 Hz, no vector, no safety settings and outputs, no rs232 programming, it's cost is only 1/4 of the Hitachi. It is 3 years old, mostly layd in stock, has had 7 hours this year since built in, mostly parametring and testing time, but the 10V problem was from the beginning and sucked. Hitachi made a costless repair on it. I think, there's nothing wrong with the VFD itself, but sth has changed in Linuxcnc. But where?
(Hitachi is founded in 1910 and in the US since 1959, Hitachi VFD's are very common here in Europe and I have no doubt about their quality)
Displaying 15346 - 15360 out of 16338 results.
Time to create page: 0.402 seconds
