  • mathwld
  • mathwld
24 May 2025 16:35
Retrofit Gildemeister ct40 was created by mathwld
Hello all,I’m in progress to get information about how to retrofit an old Gildemeister.To make a plan with what to buy and set the proper path. In the begging was pretty clear, new servo, new Vfd, go with ethercat and modbus for spindle. But when o checked today the spindle is a very large dc motor. The amplifier is old but in working condition. A new amplifier have a huge price for this motor. Do you have some suggestion for me?
  • billykid
  • billykid's Avatar
24 May 2025 16:24
Replied by billykid on topic sanmotion rs2a03a0al0w00
Category: Driver Boards
Hi Tom, with the new cable all four work. I looked for motors but they ask 200 euros, in your opinion are these drives valid or are new Chinese ones better?
I calculate the cost of the motors because the drives didn't cost me anything.
  • PCW
  • PCW's Avatar
24 May 2025 16:12
Replied by PCW on topic MESA 7i76E burning out issue
Perhaps an output is marginal because of previous damage
I would verify full 5V swing on all step/dir pins.
Here is a simple script to toggle all stepgen step and direction pins slowly:
File Name: stepgens_2...5-24.txt
File Size:1 KB
Download then
chmod +x stepgens.txt
and
./stepgens.txt to run
Note that this needs a relatively recent mesaflash
github.com/LinuxCNC/mesaflash
  • CallumRD1
  • CallumRD1
24 May 2025 16:07
Replied by CallumRD1 on topic Keyboard shortcut rempaping
Category: Qtvcp
I'm running version 2.9.3
  • COFHAL
  • COFHAL
24 May 2025 16:01
W5100S-EVB-PICO stepgenerator and encoder driver
When I open this link: developer.arm.com/downloads/-/gnu-rm, it says: This page is deprecated. See Arm GNU Toolchain for updated content and latest releases. Arm GNU Toolchain.
If I follow Arm GNU Toolchain, many download options appear. Which one should I download?
The truth is, I have little experience doing this type of installation from scratch, and it seems like what you've written on your Github is for experts. I don't know if there's a way to do all these processes automatically with bash.
  • cmorley
  • cmorley
24 May 2025 16:00
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
Which version of linuxcnc are you using?
  • tiagounderground
  • tiagounderground
24 May 2025 15:51 - 24 May 2025 16:21
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
i cant tell as am not machining anything, just moving the machine.
with other files this doesnt happen, but the position errors still happens
a lot of times i have drivers out off op state, then back on, i can run the same hardware on standard linuxcnc without any problem
edit:
emcMotionInit: emcTrajInit failed
this message shows in terminal when i start the scurve ethercat config, is this a problem?.
  • tiagounderground
  • tiagounderground
24 May 2025 15:27 - 24 May 2025 15:40
i was able to solve it removing
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf cia402.3.read-all servo-thread
now im running the machine but sometimes i have following errors that disable the motors, some arcs are beeng replaced for straigh lines and causing this, im trying to solve it now
i attach a printscreen from the gcode
  • DavidR8
  • DavidR8
24 May 2025 14:58 - 26 May 2025 02:10
Replied by DavidR8 on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
@lcvette I have LinucCNC 2.9 running on my computer now, installed using this:
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
If I'm understanding the documentation correctly, the above link installs the Debian Bookworm distribution.
To install Probe Basic, do I start at the very beginning of this which seems to install Debian Bookworm.
kcjengr.github.io/probe_basic/stable_quick_start_apt.html
Or start here?
kcjengr.github.io/probe_basic/quick_start.html
24 May 2025 14:52
Replied by tommylight on topic LinuxCNC S-Curve Accelerations
@tiagounderground,
Those are EtherCAT errors, probably better to ask in the EtherCAT section of the forum.
  • tiagounderground
  • tiagounderground
24 May 2025 14:37
I'm trying to run the last update on ethercat drivers but i have this error
HAL: ERROR: function 'cia402.0.read-all' not found
./cia402.hal:34: addf failed
HAL: ERROR: pin 'lcec.0.3.out-01' not found
shutdown.hal:2: unlink failed
24062
24076
am i missing something?
  • knipknap
  • knipknap
24 May 2025 14:34
Replied by knipknap on topic MESA 7i76E burning out issue
Alright, I found out that though the error looks identical, this time the MESA card is NOT the problem. The other good news is that the problem has become reproducible and the Joint Amplifier Failure now always happens immediately during the (attempted) homing procedure.
I can see during the homing attempt that the joint that has the amplifier error attempts to move - the other joint does not. In other words, I think that the servo with the alarm is the good one, and it goes into alarm because it fails to drag the other servo along.
It is still a puzzle though. By swapping port/cables/motors it seems that the common denominator is a port/cable:
The red path marks the one that has amplifier error in the different scenarios that I tested.
What puzzles me is that the common denominator in all failure scenarios are panel ports 2 and 3. However, I have measured the every wire several times with an ohm meter (as shown by the green lines in the image), and they are all fine. Since they are also not moving cables I cannot imagine it is a flapping connectivity issue.
So I am a little clueless as to what else I could do now. It seems every potential source of the problem was excluded.
Maybe EMI could have something to do with it, but... why would that suddenly become a reliably reproducible problem after running years with no issue?
Anyway, I also measured all the grounds on the shields of each cable, and they also seem fine/low impedance. (star configuration off of the panel, no loops)
Any ideas what else I can check?
  • CallumRD1
  • CallumRD1
24 May 2025 14:02
Keyboard shortcut rempaping was created by CallumRD1
Category: Qtvcp
I've been doing a bunch of machining on my freshly built mill running QTDragonHD and there's one thing that is absolutely throwing me off. I have a ton of experience running a Tormach on Path Pilot so I have established muscle memory for smacking the space bar to pause (feed hold) when proofing new code. QTDragonHD doesn't appear to have any shortcuts mapped to the space bar when a program is running.
Is it possible to remap the space bar to be pause (feed hold) when running programs?
Thanks!
24 May 2025 13:09
Best practice for installing custom Python packages in LinuxCNC?
Coding is not about speed, it's about the journey.
You can have both, try Assembly !
24 May 2025 13:07
Why does it seem like everyone here is Australian?
We have lost the ability to laugh at ourselves.
True.
Still, i am hell bent on retaining that ability. :)
Displaying 15511 - 15525 out of 16340 results.
Time to create page: 0.472 seconds
