  • besriworld
  • besriworld
23 May 2025 15:39
Replied by besriworld on topic Index homing Heidenhain ls 403/exe602
Category: Basic Configuration
I believe there's no way to avoid using a home sensor. Because if the machine is left at the last index on the encoder line, when searching for the next index marker, it might hit the limit switch. But when you have a home sensor, it's much easier—you only need to check the first, closest index marker.
  • npostma
  • npostma's Avatar
23 May 2025 15:34
Protecting My Mesa 7i76EU: Wiring Questions for Home Sensors and Touch Probe
Thanks. Yes mine are of the PNP type. And same goes then for the input of the Touch sensor? This is not a PNP. This acts more like a mechanical switch.
  • PCW
  • PCW's Avatar
23 May 2025 15:28
That looks basically OK
If you have PNP type sensors, you do not need any additional interface components
that is the sensor output goes directly to the 7I76EU input.
7I76XX inputs are quite rugged, they need no additional protection.
  • npostma
  • npostma's Avatar
23 May 2025 15:13
Hi All,I’d like your input on my planned setup.
As I mentioned in my previous post, the latency on my new machine was so high that I had to switch from the parallel port to a Mesa card. Earlier this week, I received a Mesa 7i76EU board. It looks awesome—if a bit overwhelming at first glance!My plan:
  • Motors:
    I’m using 3x Longs DM542A stepper drivers, which I plan to connect to Stepper 0/1/2 outputs on the Mesa board, using what I believe is called a “single-ended” wiring configuration. My plan is to connect +5V to the ENA+, DIR+, and STEP+ on each driver, and wire the ENA (5V), DIR-, and STEP- of each driver directly to the corresponding outputs on the Mesa card.
  • Spindle:
    I have a Huanyang VFD 1.5KW for spindle control. For now, I’ll keep my Modbus-over-USB setup, which seems to work well enough. I’ve read that getting Modbus running directly on the Mesa board requires a bit more advanced configuration, so I’ll save that for later.
  • Homing Sensors (Capacitive, 3x):
    My plan is to connect the +24V supply to the positive (brown) wire, and field ground to the negative (blue) wire of each sensor. I intend to connect the sensor output (black) wires to Input 1, 2, and 3 on the Mesa card.
Questions:
  1. Current-limiting resistor for home sensors:
    For the capacitive homing sensors, do I need to add a resistor between the output pin of the sensor and the Mesa input to protect against overcurrent? In the past, I’ve blown a few sensors and started using resistors to protect them, but those were cheap sensors—the Mesa card isn’t!
  2. 2-wire touch probe:
    For my two-wire touch-off probe, I plan to connect one side to +24V field power and the signal wire to Input 4. Here too, should I add a resistor to avoid potential shorts or overcurrent situations?
Bonus questions:
  • Any recommendations for best practices when wiring sensors and stepper drivers to the Mesa 7i76EU?
  • Are there things I should definitely avoid to protect my Mesa card or improve reliability?
  • For those who have set up Modbus on the Mesa board, how steep is the learning curve compared to using Modbus over USB?
Thanks for your advice and experiences!
  • snowgoer540
  • snowgoer540's Avatar
23 May 2025 14:57 - 23 May 2025 15:35
Replied by snowgoer540 on topic M62-M68 codes not working
Category: Plasmac
The code (at least the code in your first post), works fine on 2.10.008.064.  I realize you are on some version of 2.9, just was easy for me to test on that.
Can you state the specific version of 2.9 you are on (like above, as taken from the window title with QtPlasmaC open)?
Back when, there was a commit that temporarily broke feed reductions, but it was fixed. I honestly can’t remember if it was in 2.9 or master or both, but perhaps you have an older version that has the bug.
  • Lcvette
  • Lcvette's Avatar
23 May 2025 14:30
Replied by Lcvette on topic Setting started modification Probe Basic
Category: QtPyVCP
the best way to do this is to use the provided usertab, this way your edits remain with your config folder and do not get overwritten during updates (which a couple big ones are getting ready to drop). what you definitely do not want to do is edit the main probe basic because then you become the developer for any and all future updates which is not ideal for an end user.
to edit a user tab, open a terminal, type in:
editvcp
a dialog will pop up, in the dialog, find your machine config directory, typically it will be
/home/(your_pc_name)/linuxcnc/configs/(whatever_you_named_your_machine)/user_tabs/template_main/template_main.ui
in the file type drop down at the bottom of the dialog, make sure the type is set to VCP UI Files (*.ui)
this will show you the file :
template_main.ui
select it and click the open button.
Here you can add and edit it as you desire. when done, click save.
check your ini file and make sure that user tabs path is active under the display section:
[DISPLAY]
USER_TABS_PATH = user_tabs/
this activates the user tab and loads on probe basic start up.
enjoy!
  • PCW
  • PCW's Avatar
23 May 2025 14:25
Interpolation accuracy with Delta ASD-B3 EtherCAT servo drives
Category: EtherCAT
If it was working and then changed I would expect that's more likely
to be a mechanical issue (loose coupling etc).
  • MARTCENT
  • MARTCENT
23 May 2025 13:48
Replied by MARTCENT on topic Retrofit SODICK A320D
Two PCs were used in those machines.
NEC 9801UF / NEC 9801UV11
Thank you
  • Aciera
  • Aciera's Avatar
23 May 2025 13:01
Replied by Aciera on topic comp confusion
comp confusion
Category: LinuxCNC Documents
'comp' is listed twice. The first entry is correct:
The second is the wrong one.
  • PCW
  • PCW's Avatar
23 May 2025 12:47
Replied by PCW on topic comp confusion
comp confusion
Since that's a list of hal components, the link is correct
but the description is not.
  • PCW
  • PCW's Avatar
23 May 2025 12:45
Replied by PCW on topic Index homing Heidenhain ls 403/exe602
OK, That's entertaining...
It should be possible to home by using a component that
measures the distance between index's and only arms
the actual index logic by simulating home switch detection
when the correct inter-index distance is measured.
  • HalaszAttila
  • HalaszAttila
23 May 2025 12:06
Replied by HalaszAttila on topic scurve trajectory planner
Hello,
I tested the S-curve feature on the following system:
PC: HP with Intel i3 3rd Gen, 2x4GB RAM (latency < 20k)
OS: Debian 12
LinuxCNC: 2.10 pre-release
I created an XYZ mill configuration using StepConf and ran the same G-code with and without tpmod_scurve.
The results can be seen in the attached videos.
Observations:
Without the S-curve, the feed rate remains continuous.
With the S-curve enabled, the feed fluctuates significantly—at times dropping to 1/10 of the programmed feed rate.
It also noticeably increases the overall program execution time (2,5x slower with scurve in this situation).
I tried increasing VECTOR_BUFFER_SIZE to 100, but it didn’t help much. (Just for testing, I also set VECTOR_BUFFER_SIZE = 2, which made the behavior even worse.)
Maximum velocity and acceleration settings are visible in the video (they’re not particularly high, and are the same in both cases).
Question:
Do you think it's possible to achieve a continuous feed rate using the S-curve?
Files:
drive.google.com/drive/folders/1uR1LfCv_...4-w6Daf8?usp=sharing
  • Z3rni3
  • Z3rni3
23 May 2025 11:07
Replied by Z3rni3 on topic unknown type name ‘bit’
Category: Configuration Tools
I was able to install it now, thank you!
Will update if it works as planed.
  • cmorley
  • cmorley
23 May 2025 10:58
Replied by cmorley on topic unknown type name ‘bit’
try:
variable int last_Tin = 0;
  • Z3rni3
  • Z3rni3
23 May 2025 10:45 - 23 May 2025 10:51
I acctually name it pos_latch.comp when creating the document.
I've created working functions before but those only used floats.
Follwing File installs no problem...:
component Test;
license "GPL";
pin in float in;
pin out float out1;
pin out bit out2;
function _ nofp;
FUNCTION(_) {
out1 = in * 3;
if (out1 == 3.0)
   { out2 = true; }
else
   { out2 = false; }
Displaying 15571 - 15585 out of 16341 results.
Time to create page: 0.325 seconds
