  • Hakan
  • Hakan
22 Apr 2025 06:26 - 22 Apr 2025 06:27
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I have had long sync times, and there recently was a user that went from debian 10 and igh 1.5 to debian 12, igh 1.6.3 and latest linuxcnc that experienced long time sync times. I switched network adapter which helped a lot, but there was no solution for the other guy.
In the dmesg list, you can see that the client's time is converging, it's just that it's converging too slowly.
One thing you can try, that doesn't solve the root cause, is to restart linuxcnc after such a failed start.
The thinking being that the clients now have a much better starting time for the time sync.
  • Salrodri
  • Salrodri
22 Apr 2025 03:11
Tool changer was created by Salrodri
Tool changer
Category: O Codes (subroutines) and NGCGUI
Hello,
Could you please help me with my tool changer, my machine is cnc endmill  emco 55 pcmill. I am using Carousel Component with counts mode, since I have a stepper motor on the tool changer.I also have a sensor that connected to sens-0 (index)at this point I can move and home the car, I can also do the tool changes.the last thing that I need to do is move the carousel back home once the tool has been changed. How can I move the car back to home with a subroutine?My tool changer does not have an arm that I can control.
Thank you,
  • pgf
  • pgf
22 Apr 2025 02:13
After homing X and Y, can I auto move to a non 0,0 location?
Heh. I would have to say probably "yes", to both. LOL.
It's a DIY mill. In 1993, II got it as a kit, which included the stepper, a driver board (which did just raw coil driving -- not even step/dir!) along with plans for a chassis made of particle board, rails from high quality drawer slides, and all-thread rod as the transport. The s/w that came with it was written for DOS, polling loops and all.
There have obviously been a lot of upgrades over the years: EMC/LinuxCNC in 2004, acme rod for X and Y (Z still uses the all-thread) a lot of chassis strengthening, a real step/dir driver board maybe 10 years ago, and a Mesa card and Raspberry Pi this year. But it still has the same steppers, and the linkages and threaded shafts aren't all that well aligned. Frankly, I'm amazed it all kind of still works. But I have fun with it... when it's not driving me nuts!
Pictures here: projects.foxharp.net/cnc/
  • RushA
  • RushA
22 Apr 2025 01:25
A simple question: How to use EXPORT_SYMBOL()
hi,thanks!
It doesn't work too. However, I find something in rtapi.h file.
I think it is not like the linux kernel modules.
#if !defined(__KERNEL__)
#define MODULE_INFO1(t, a, c) __attribute__((section(".modinfo"))) \
    t rtapi_info_##a = c; EXPORT_SYMBOL(rtapi_info_##a);
#define MODULE_INFO2x(t, a, b, c) MODULE_INFO2(t,a,b,c)
#define MODULE_INFO2(t, a, b, c) __attribute__((section(".modinfo"))) \
    t rtapi_info_##a##_##b = c; EXPORT_SYMBOL(rtapi_info_##a##_##b);
#define MODULE_PARM(v,t) MODULE_INFO2(const char*, type, v, t) MODULE_INFO2(void*, address, v, &v)
#define MODULE_PARM_DESC(v,t) MODULE_INFO2(const char*, description, v, t)
#define MODULE_LICENSE(s) MODULE_INFO1(const char*, license, s)
#define MODULE_AUTHOR(s) MODULE_INFO1(const char*, author, s)
#define MODULE_DESCRIPTION(s) MODULE_INFO1(const char*, description, s)
#define MODULE_SUPPORTED_DEVICE(s) MODULE_INFO1(const char*, supported_device, s)
#define MODULE_DEVICE_TABLE(x,y) MODULE_INFO2(struct rtapi_pci_device_id*, device_table, x, y)
#define MODULE_INFO(x,y) MODULE_INFO2x(char*, x, __LINE__, y)
#define EXPORT_SYMBOL(x) __attribute__((section(".rtapi_export"))) \
    char rtapi_exported_##x = #x;
#define EXPORT_SYMBOL_GPL(x) __attribute__((section(".rtapi_export"))) \
  • spumco
  • spumco
22 Apr 2025 01:18
Ha!!! My motors stall if I go much over 40 inches / minute!
That seems exceptionally slow.
Is there a problem with your machine - perhaps axis binding - or do you have really undersized motors?
  • cakeslob
  • cakeslob
22 Apr 2025 01:04
Replied by cakeslob on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
I suggest trying to work with this file. I still need to clean it up a little, but this is a far better starting point than the ai file
github.com/cakeslob/RRW_LAB/blob/inc/Lin...theng/remora-xyz.hal
github.com/cakeslob/RRW_LAB/blob/inc/Lin.../remora-xyzRE_ts.ini
I mean....big red flags from ai file
[EMC]
VERSION = 2.9.4
TASK = lathe_task
COORDINATES = XZC
KINEMATICS = trivkins coordinates=XZC
  • Soccer Kid
  • Soccer Kid's Avatar
22 Apr 2025 00:48
Category: EtherCAT
Perhaps it is related to the EOE mode of the drive. Generally, it is recommended to adopt the drive in COE mode...
  • unknown
  • unknown
22 Apr 2025 00:39
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
Mainly for my own records and thinking aloud.......
Switched from the i5 & Realtek NIC to a RPi5. Seems somewhat more solid, can get Mesaflash to write reliably with a 8us usleep instruction around the "sync" instruction. Still thinking the issue is my side, have ordered some "sample" interface chips from Microchip, I'll assemble another board, this time using a reflow oven for the SMD parts. If that doesn't fix it I have a board designed for the OMDAZZ dev board I've used before, SPI just needs upgrading to 16Mb part as it only comes with a 4Mb part.
  • unknown
  • unknown
22 Apr 2025 00:30
Replied by unknown on topic ChatGPT LinuxCNC Assistent
I think about 6 months ago a user tried to use ChatGPT to write a component for Linuxcnc...what a mess that was and the user was quite upset, not so much with the code supplied but with the fact that the replies suggesting the code made no sense.
  • unknown
  • unknown
22 Apr 2025 00:26
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Thanks for your input. Keyboard input is USB, so meh, not a lot that can be done about that.
  • unknown
  • unknown
22 Apr 2025 00:23
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Use the official fan & heatsink, it works well and you'll have no issues. I've left mine on for days at a time during the summer in Australia and nothing has gone wrong.
I prefer a wired pendant, connected via a Mesa 7i73. It's solid and you don't need to worry about disconnections. Just axis & step selectors with a hand wheel. Tho Rod does us a fancy wireless one.
  • pgf
  • pgf
22 Apr 2025 00:18
22 Apr 2025 00:15
Replied by tommylight on topic 7i95T & 7i77
7i95T & 7i77
Category: Basic Configuration
Rod, all my 3D printers run Klipper on laptops or NUC's, nothing runs on RPI's on my shops, although i have 2 somewhere, the 3B version.
Use KIAUH from github, it will install and setup everything on a PC, including camera, telegram bot, etc
  • ErwinCNC
  • ErwinCNC
21 Apr 2025 23:42 - 22 Apr 2025 00:23
First of all, thank you very much for your work with the images.
According to everything I found on the net, a pi 5 8GB with SanDisk extreme pro 64gb, official power supply and a Mesa 7i96s should work without any problems? Is that correct?
Are there any restrictions regarding
- user interface (probe basic, gmoccapy)
- the wireless 6 axis handwheel
One last question about the cooling / housing.Is a passive cooled case like the Flirc Raspberry Pi 5 case sufficient or should active cooling be provided? My thoughts on this are mainly dust protection.
Perhaps useful for others
Unfortunately, the standard office monitors all have large ventilation slots on the back. I have been looking for alternatives for a time and would now like to use a mobile external monitor (sold as a supplement to the laptop). These seem to be much better protected against dust.
Erwin
  • vre
  • vre
21 Apr 2025 23:11
Replied by vre on topic Digital Input
Digital Input
So this code does the same thing?
(pwmgen.00 is the spindle pwmgen)
	o307 if [#<_hal[[pwmgen.00.enable]> GT 0]
		(abort, spindle not stopped)
	o307 endif
Displaying 16936 - 16950 out of 17105 results.
Time to create page: 4.408 seconds
