  • tuxcnc
  • tuxcnc
07 Aug 2026 17:34
Replied by tuxcnc on topic Ver 10 NEW install
Ver 10 NEW install
cant get past name and password screen yet.
If you see GRUB but after only blank screen, this may be graphic card issue. In this case try apply nomodeset kernel parameter at grub screen (there are many tutorials on internet).
  • 5280
  • 5280
07 Aug 2026 17:09
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
Thanks 4 the info
but I have not been able to get to the terminal yet
have done 4-5 fresh install of the OS. they all hang up at the same place name and password screen
  • hitchhiker
  • hitchhiker
07 Aug 2026 17:01
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
Yes i use free ai to generate the single moduls of the vismach model. Then i bring all together. Thats why the model is in 90 angles..
Do you find wrong stuff in the ini or hal???
  • MaHa
  • MaHa
07 Aug 2026 16:52
Replied by MaHa on topic Ver 10 NEW install
Ver 10 NEW install
For autologin you can do this, just after completing installation:
For auto login to Debian open a terminal:
sudo nano /etc/lightdm/lightdm.conf
Uncomment the following and add your user name, be sure to scroll far enough down to get past the comments sections.:
autologin-user=yourusername
autologin-user-timeout=0
  • 5280
  • 5280
07 Aug 2026 16:29
Ver 10 NEW install
Good Day: Adam
"I don't Like it" I just want it to work as prescribed which it does not seem to do when I can not even get past the login screen when i entered the password and user name in the OS install. oh ya I am a old man as U say and still building computers and doing installs from scratch.
have a good day
  • 5280
  • 5280
07 Aug 2026 16:14
Ver 10 NEW install
Cool
07 Aug 2026 15:46
Remora on NVEM board - unable to upload new configs
@CNC_Manni
No double and triple posting, stick to one topic, it makes a mess following what was already answered.
  • tuxcnc
  • tuxcnc
07 Aug 2026 14:46
Ver 10 NEW install
why cant they just have a check box do you need a password yes / no and leave it at that
1 frustrated old man
As an old man, you should remember mainframe computers occupying several large racks that were operated by many people from many terminals. Linux is derived from Unix, Unix was developed in 1969... This is why in Linux you have to use passwords (and also a complicated permission system). You can't escape it, you have to like it...
07 Aug 2026 14:40
Replied by tommylight on topic Ver 10 NEW install
Ver 10 NEW install
ZX81, ZX Spectrum, Commodore 16, Atari 520STFM, XT PC, Toshiba Laptop with EL orange screen, and the first i have built Pentium 1 200MHz.
Many more there, some i still have in working condition, see my channel on youtube:
www.youtube.com/@TomaPC
  • tuxcnc
  • tuxcnc
07 Aug 2026 14:30
Ncam and Lathemacros conflict was created by tuxcnc
Category: CAD CAM
You can install ncam and lathemacros together, but only lathemacros will works properly.
The cause is use the same names for different subroutines:
root@HP-15:~/linuxcnc/configs/sim-lathe# ls -ln *.ngc
-rw-r--r-- 1 0 0 1182 2026-01-07  boring.ngc
-rw-r--r-- 1 0 0  595 2026-01-07  facing.ngc
-rw-r--r-- 1 0 0 1151 2026-01-07  radius.ngc
-rw-r--r-- 1 0 0 1037 2026-01-07  threading.ngc
-rw-r--r-- 1 0 0 1184 2026-01-07  turning.ngc
root@HP-15:~/linuxcnc/configs/sim-lathe/ncam/lib/lathe# ls -ln *.ngc
-rw-r--r-- 1 0 0 1891 04-20 18:51 boring.ngc
-rw-r--r-- 1 0 0 1491 04-20 18:51 facing.ngc
-rw-r--r-- 1 0 0 3781 04-20 18:51 radius_od.ngc
-rw-r--r-- 1 0 0 3334 04-20 18:51 threading.ngc
-rw-r--r-- 1 0 0 4678 04-20 18:51 turning.ngc
(I removed results not matter.)
You can recognize ncam's files by "(author : Fernand Veilleux)" comment, thats lack in lathemacro's.
Ncam (Python 3.0)) works properly and generates good g-code, but LinuxCNC uses subroutines that found first...
This causes horrible and confusing errors, like :
G-code error in ncam.ngc
Near line 101 of
~/linuxcnc/nc_files/ncam.ngc
Negative word used
But actually there is no error in ncam.ngc, but only wrong subroutine file is used...
The solution is very simple (rename subroutines and change some lines in python sources), but this must be done by the authors, not by users...
  • 5280
  • 5280
07 Aug 2026 13:40
Ver 10 NEW install
Good day to you Tom
Just curious what was your very first computer and year you got it, and did you build it from scratch.?
Ken
  • 5280
  • 5280
07 Aug 2026 13:33
Ver 10 NEW install
Thank's Todd
I have double and triple checked all of that. very aware of the upper/lower case thing in Linux. installed 3 different keyboards thinking of that first off. I still think Linux may be the path for me if I can just make all the paths come to gather for what i have in mind to end up with.
thanks
Ken
  • Lcvette
  • Lcvette's Avatar
07 Aug 2026 13:33
Replied by Lcvette on topic Probe Basic Cutaway
Probe Basic Cutaway
Category: QtPyVCP
Probe Basic does not show the part at all it only shows the toolpath so im not exactly sure what your post is requesting/stating etc can you be more clear of what part of probe basic you are referring too?
  • CNC_Manni
  • CNC_Manni
07 Aug 2026 12:58
Replied by CNC_Manni on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'm running into an issue and hoping you might have found a solution since posting this.
I'm using an NVEM V5 board (RT1052 chip). I successfully flashed the firmware via pyOCD
(tried multiple firmware versions: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin,
remora-rt1052.bin - all flashed without errors). Ping to 10.10.10.10 works perfectly and consistently.
However, unlike your case, I'm getting a timeout on my very first config upload attempt -
not after a successful first upload.
I've tried:
- My own custom config file
- The unmodified official example configs (both nvem-rt1052.txt and remora-rt1052-basic/ec500-rt1052.txt)
- Uploading with the SWD/ST-Link connection both attached and disconnected during the upload
- Confirmed via tcpdump that the WRQ packet is sent correctly on port 69, but no response ever comes back from the board
- No firewall involved (iptables set to ACCEPT), direct point-to-point Ethernet connection, no router
The script always confirms "Valid JSON config file" and calculates the CRC correctly,
so it gets stuck at exactly the same point you describe - after everything on the PC side looks fine.
Did you ever find out what caused the board to stop responding to TFTP?
Was it possibly related to the eStop/enable state getting stuck, as you mentioned the LED stayed
permanently lit? Any insight into how you (or anyone else) resolved this would be hugely appreciated -
trying to avoid unnecessary re-flashing if there's a known cause.
Additional update: I ran a UDP port scan to check the TFTP service status directly:
sudo nmap -sU -p 69 10.10.10.10
Result:
PORT STATE SERVICE
69/udp closed tftp
This is significant - "closed" (not "open|filtered", which is the typical ambiguous UDP result)
means the board actively responds with an ICMP port-unreachable message. This confirms the
TFTP service itself is never bound/listening on port 69 at all - it's not just that requests go
unanswered on an otherwise-open port.
I also looked through remora-rt1052.cpp and noticed the TFTP server is initialized via:
IAP_tftpd_init(dmaThread->DMAptr->EDMA_Handle);
in the ST_SETUP state, right after loadModules(). This suggests the TFTP server initialization
may never complete successfully during startup - which would explain why port 69 shows as actively
closed rather than just non-responsive.
I've now tested every available NVEM-specific firmware (only remora-rt1052-NVEM-0.2.1.bin exists
in the Remora-RT1052 repo) as well as the generic 3.1.x versions from Remora-RT1052-cpp
(which don't even respond to ping on this NVEM V5 board, matching what "disneysw" reported earlier
in this thread). I'm at the limit of what I can diagnose from the outside - any insight into the
TFTP server startup sequence would be much appreciated.
Thanks in advance!
Displaying 1741 - 1755 out of 12537 results.
Time to create page: 0.304 seconds
