  • Aciera
  • Aciera's Avatar
13 Mar 2025 06:54
Incorporating HAL script recommendation (2.7.14 to 2.9.4 conversion of XZC
./Lxzc3-12-25rev4.hal:201: Ini variable '[SPINDLE_9]P' not found.
1. Your ini is missing the spindle section while your hal references 'SPINDLE_9' ini entries. Looking at your hal file makes me think that you are not actually using a spindle setup. If that is the case then you might want to completely remove this section from your hal:
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable         => pid.s.enable
net spindle-vel-cmd-rpm    => pid.s.command
net spindle-vel-fb-rpm     => pid.s.feedback
net spindle-output        <=  pid.s.output
net spindle-vel-cmd-rps       <=   spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs   <=   spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm       <=   spindle.0.speed-out
net spindle-vel-cmd-rpm-abs   <=   spindle.0.speed-out-abs
net spindle-enable            <=   spindle.0.on
net spindle-cw                <=   spindle.0.forward
net spindle-ccw               <=   spindle.0.reverse
net spindle-brake             <=   spindle.0.brake
net spindle-revs               =>  spindle.0.revs
net spindle-at-speed           =>  spindle.0.at-speed
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
sets spindle-at-speed true
  • rodw
  • rodw's Avatar
13 Mar 2025 06:36
Replied by rodw on topic QTPlasmaC post processor - SheetCam?
Category: Plasmac
Yeh, that's the one! I made some enhancements for it and Les added it to Sheetcam. There are some settings at the top of the post to check and turn off. I made it so Sheetcam was the master seeing it was for his system
  • Darium
  • Darium
13 Mar 2025 06:14
Replied by Darium on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
@ihavenofish
Wow that's nice. Having 3 ton machine moving like that also with the current jerkness is too scary definitely not good for my heart.
@LCR
I have similar issue with non-ethercat drivers. you can check it out this thread. It may help
forum.linuxcnc.org/38-general-linuxcnc-q...s-creeping-up#309973
  • stkvit
  • stkvit
13 Mar 2025 05:52
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
I converted the bcl-amp output to a differential signal (max485), at a long length it works much more stably and reliably. You should do the same (I understand that your frequency is linear and depends only on the height). A couple more questions, your sensor have temperature stabilization?
  • F❨+❩gl
  • F❨+❩gl's Avatar
13 Mar 2025 05:30 - 13 Mar 2025 05:32
6040 CNC retrofit was created by F❨+❩gl
6040 CNC retrofit
Category: Milling Machines
So, I dug out my 14-year-old 6040 CNC again.
I already retrofitted that thing once, tossed almost all the original electronics and went with G540 and some old industrial PC. Still, I was strapped for money, and it was a hack. I only used it occasionally for a couple of years, then it just collected dust.
A few months back, I found myself in a situation where I had a lot of time, and I'm no longer that strapped for cash either.
I got myself a new set of closed loop steppers and CL57T drivers from SteppersOnline, MESA 7i96S board, proper PSUs, a new mini PC and nice steel enclosure, and I'm trying to push hard to do it properly this time. I have a physical layout somewhat complete but still grinding the schematics.
Would somebody be so nice as to look it over?
I have the following questions:
1) Is it ok to use 5V to enable stepper drivers (OUT0)? Stepper drivers will be configured to use 5V, but I'm assuming that DIP switch is only for STEP/DIR pins.
2) Since I'm feeding 24V to IN COM, I have to use 24V to detect alarms from stepper drivers. Is it ok to mix 24V and 5V on the same driver for different functions (5V for enable, 24V for alarm)?
3) Can I detect driver alarms with just one input? Any practical benefit have them wired individually?
4) Right now, I have all limit switches wired independently, but I really need that? Current setup has them all in series on a single wire. Is there any practical benefit of having the wired separately?
5) Not sure about E-Stop. In the schematics, it kills the VFD power and sends a signal to the controller. But I'm not sure about that at all.
6) I have two input pins left, but I still need a probe at least. Am I missing anything else?
Thanks a lot for any suggestion.
  • unknown
  • unknown
13 Mar 2025 04:36
Replied by unknown on topic 7i95 randomly throws error with raspi b
Category: Driver Boards
To the OP just for reference next time could you specify if you are using a RPi4 or RPi5 so if we need to look at the images it makes life easier. As both the 4 & 5 come in B variants.
Cheers
Rob
  • Lcvette
  • Lcvette's Avatar
13 Mar 2025 03:18
Setting up Probe Basic on my machine questions and issues
Category: QtPyVCP
Your ini start up line has ag20 in it, change to g21.
Homing sequence is set in the ini, read the lcnc docs for how to configure homing settings correctly. All homing is stock linuxcnc motion. Go to home is for the go to home button. You can edit it to suit your needs, but has nothing to do with homing. All homing settings are in the ini under each of the axis sections.
  • pmchetan
  • pmchetan
13 Mar 2025 03:05
Replied by pmchetan on topic Hal configuration for BISS encoder
Category: HAL
I finally got good results of making a servo out of inexpensive bldc motor and drive using 6i25_7i76_7i74 and 1 micron resolution linear encoder. I consistently get repeatable positioning of the axis within 4 micro meters measured from an external device. Now I'm wondering if there's a way to offload the PID calculations from running on servo thread to the FPGA? I'm guessing this will open up options for adaptive control algorithms to run on the fpga down the line. How much processing can we push on the fpga and the daughterboards? Does the daughterboards also have some hardware for processing?
  • ihavenofish
  • ihavenofish
13 Mar 2025 02:30
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
weiiird. is that mm for f error?
what axis?
Mine are omron, so no help there but when they stop, they are within 2 encoder counts (20 bit). I wonder if there is a feed forward thing where its just not bothering to catch up after stopping. I think i had that on my brother analogue servos when i chose some bad settings.
(also , side note, i need some help with ethercat setup, haha)
  • ihavenofish
  • ihavenofish
13 Mar 2025 02:25 - 13 Mar 2025 02:36
Category: EtherCAT
that's still very decent. my machine is "faster than most". yours is more in line with what most people will be doing with these servos i expect.
omron 200w servo. 1G, 3000rpm. (cant wait to get it to 5000rpm muhahhaha!
jmc motors in use. 0.3G, 12m/m (pulse limitation). The real issue with these is they are soft. like even though they track with feed forward, stiffness is so low that cutting forces push the axis off track by a thou or 2. Need to take a spring pass ore 2 for a precise cut.
My hope is that these lichuans will be a step well above the JMC but still "cheap and cheerful" for my production machines. Cause those omrons cost more than the machine frame :P
  • unknown
  • unknown
13 Mar 2025 02:24
Replied by unknown on topic Trouble getting a new configuration running.
In your ini file check this line
Line 277 for joint 4
STEP_SCALE = 3.9307 # 1414.752 steps / 360° for 10-tool carousel
AI isn't worth the effort.
  • unknown
  • unknown
13 Mar 2025 02:12
Can you post the error reports as well, so we get the full picture.
  • JTknives
  • JTknives's Avatar
13 Mar 2025 02:10
QTPlasmaC post processor - SheetCam? was created by JTknives
Category: Plasmac
I have been searching around and can’t seam to find a dedicated QTPlasmaC sheetcam PP. I looked in sheetcam and found LinuxCNC-PlasmaC but not sure if that’s for the QT. Any help would be greatly appreciated. Thanks guys.
  • Lik2waterski
  • Lik2waterski
13 Mar 2025 01:45
Replied by Lik2waterski on topic Trouble getting a new configuration running.
thank you. Now I keep getting an error hal:132 setp requires 2 arguments,10 given. Ive been using AI to help me but I cant get past this error. I will attach my hal files incase anymone wants to check them out. Thank you.
  • Masa
  • Masa
13 Mar 2025 01:02
Replied by Masa on topic Homing trouble
Homing trouble
It took a while, but I managed to solve the problem.
Thank you to tommylight and Aciera for your advice.
I've posted more details at
forum.linuxcnc.org/ethercat/55535-question-of-homing#323788
Thank you very much.
Displaying 17806 - 17820 out of 18512 results.
Time to create page: 0.604 seconds
