  • PCW
  • PCW's Avatar
06 Mar 2025 15:15
Replied by PCW on topic Inputs as outputs 7i95t
Category: Driver Boards
Yes, a sserial card can add real time 24V I/O I would suggest a 7I84U which
adds 16x 5 to 28V 500 mA sinking or sourcing outputs and 32x 5-28V inputs.
The sserial devices are RS-422 so do not allow more than one device
per interface. This so the remote interface is real time.
The 7I95T also supports Modbus devices (mainly for VFD use).
Modbus I/O devices are common and inexpensive but do suffer
from a couple issues:
1. They are not real time
2. The inexpensive I/O devices I have tested do not have watchdogs
so leave outputs stuck on after LinuxCNC exits or there is a fault.
  • Hakan
  • Hakan
06 Mar 2025 14:37
Replied by Hakan on topic Fusion 360 post processor file for Plamac
Category: Plasmac
Good find there. That should fix merging, but not when there is an incomplete circle and there comes a line.
More on the philosophy around this - I don't know enough of the background to this - but when in center punch mode, would it be ok to center punch the center of any circle segment? Doesn't have to be full circle, like the center of a fillet. I mean, you go into center punch mode deliberately and mark circles. The intention is to make a center punch for all marked circles/segments. So only that should be done, no straight lines or half circles or anything. It is only making spots while in center punch mode. If so, one should rearrange the code so separate out this action, mark the center of the circle segments and ignore everything else.
I wonder if this with Smoothing off should be in the description, the PDF where center punch is described.
  • Iron-Man
  • Iron-Man's Avatar
06 Mar 2025 13:45
Trouble tuning axis for first time, ferror doesn't go to zero after move
Hello Jpevner
What AMC drives do you have?
First, you may need to re-tune your AMC drives. Software may still be available at AMC. I would set the drives to torque mode if possible.
After this is done then adjust the PID etc in Linuxcnc.
I converted a Denford Novaturn. My set up is Pathpilot, IBOB2, MESA 7i77, 6i25, Yaskawa SGDA 01AS servos in torque mode.  I first tuned the servos for my machine's inertia. After this was done then the PID settings.
Some of the work is located here:
DENFORD:  NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
Hope this helps,
Iron-Man
  • timo
  • timo
06 Mar 2025 13:38 - 06 Mar 2025 13:56
Replied by timo on topic Inputs as outputs 7i95t
So that is connected with one of those network cables on the 7i84 and then clamped to the screw terminals of the 9i95?
Is it possible to connect more than one of the cards to the same serial bus?
I must admit that I mixed up smart serial with modbus, because the RS485 tricked me into believing it is similar. But I do not have a clue about all this (who can guess?). I wonder if the 9i95t still could be used with the modbus RTU, similar to the video and omiting the USB adapter. I would probably not try to research it and just spend some extra money.
Seems there are many option to add I/Os to that LinuxCNC :-)
  • jpg
  • jpg
06 Mar 2025 12:59 - 06 Mar 2025 13:04
  • unknown
  • unknown
06 Mar 2025 12:52
hahaha Kam
It's intriguing how people will try to point the finger at the hardware or software rather than themselves......Yes I've been guilty of that myself, but I'm less likely to do that now, at least I hope.
  • gwond
  • gwond
06 Mar 2025 12:49
Replied by gwond on topic Fusion 360 post processor file for Plamac
Category: Plasmac
I did some additional testing yesterday and found that I could never get the last hole to be a full circle unless I turned smoothing off. MergeCircles or changing tolerances did not seem to influence the end result. The sketched geometry was identical for all 4 holes. I did find a thread over on the Autodesk forum that seemed to be related to the development of this post processor.
forums.autodesk.com/t5/fusion-manufactur...le-arcs/td-p/9326368
I may reach out there if this keeps happening on other parts, but for now, I think I'll just use as is and test with other parts. If anyone else would like to use the post processor, I could remove the debug statements I added and repost it here.
  • unknown
  • unknown
06 Mar 2025 12:35 - 06 Mar 2025 12:48
Replied by unknown on topic Byte2Bot Homing Question
I'm basing the following on the 2.9.4 image. either Rpi4 or Rpi5
If you read the man page for hal_gpio you will notice there is an issue with the way the module is loaded.
loadrt hal_gpio inputs=GPIO5,GPIO6,GPIO12,GPIO13,GPIO16,GPIO17,GPIO18,GPIO19 \
outputs=GPIO20,GPIO21,GPIO22,GPIO23,GPIO24,GPIO25,GPIO26,GPIO27 \
invert=GPIO20,GPIO27 \
reset=GPIO21,GPIO22
Other info:
forum.linuxcnc.org/9-installing-linuxcnc...sberry-pi-4-5#320852
In the config below you will have to change the GPIO assignments to match the Byte2Bot board.
forum.linuxcnc.org/9-installing-linuxcnc...-4-5?start=10#321296
Finally it also helps if you stated the type of Pi you are using and the image.
A word of warning if you are using a RPi5 I would pay very close attention to the temperatures, as the Byte2Bot board would inhibit the cooling. I've never run my RPi5 without the cooler.
If you are using an RPi4 you may not get the stepper speeds you want.In either case it looks like they have used a very slow base period of 100000ns. Most parallel port setups on a PC aim for around 25000ns.
  • unknown
  • unknown
06 Mar 2025 12:29 - 06 Mar 2025 12:54
For a read & write to occur the hal_gpio read & write functions need to be connected to a thread.
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html#_functions
What I would do is run a basic config for your machine, then use halshow from axis or whatever you are using to monitor the input you need to.
  • unknown
  • unknown
06 Mar 2025 12:21
Replied by unknown on topic Inputs as outputs 7i95t
Those Serial connectors are for Mesa's SmartSerial cards, which is different to ModBus.
There are some remote smart serial I\O cards that will be just plug and play, ie all the messy voltage translation stuff is on the board. Depends on how much you want to pay ;) eg 7i84 which will give an extra 32 inputs & 16 outputs. Maybe over kill.
store.mesanet.com/index.php?route=produc...69_70&product_id=123
As mentioned before a chinese bob will work but then you'll have to deal with 5v > 24v stuff.
  • timo
  • timo
06 Mar 2025 11:34
As far as I understand you can hook up one of those DB25 daughter cards to the P1 expansion connector.
Just look if something is suitable? I guess the bitfile needs to be changed. I was not able to figure that out. (so far pre-configured ones that were provided by Mesa worked for me)
store.mesanet.com/index.php?route=product/category&path=69_71
Some people used Modbus I/O expansion, I think that goes on the RS485 pins of the card. No idea how it works. :-)
  • Sternfox
  • Sternfox
06 Mar 2025 11:03
Inputs as outputs 7i95t was created by Sternfox
Hey chaps,
So I'm running out of outputs on my mesa 7i95t I have loads of inputs free.
So my question is can the input pins be used as outputs?  If so how.
I have 6 ssr outputs on the card all are used for loads such as solenoids and relays.
I now need outputs (24v) for my drivers enable/alarm clearing functions.
I have ordered a 5 axis bob but it seems they are all inputs not outputs.
Any suggestions on how to get more 24v outputs?
  • aikiaviator
  • aikiaviator
06 Mar 2025 09:28
Move Machine to inside soft limits when Probe Basic on
Category: QtPyVCP
Thanks. Yes. This is what I have. Thank you. :-)
  • aikiaviator
  • aikiaviator
06 Mar 2025 09:24
Best approach to upgrade Probe Basic to latest version
Category: QtPyVCP
Version Linux:
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="www.debian.org/"
SUPPORT_URL="www.debian.org/support"
BUG_REPORT_URL="bugs.debian.org/"
Probe_Basic Version:
Stable Install: 1.1
2024-12-24 13:27:40,363 - qtpyvcp - INFO - QtPyVCP Version: 0+unknown
2024-12-24 13:27:40,390 - qtpyvcp - DEBUG - Qt Version: 5.15.8
2024-12-24 13:27:40,391 - qtpyvcp - DEBUG - Qt API: QT_API
2024-12-24 13:27:40,391 - qtpyvcp - DEBUG - QtPy Version: 2.3.0
Is this enough?
  • Clive S
  • Clive S
06 Mar 2025 08:26
Replied by Clive S on topic Byte2Bot Homing Question
For that board to work with the inputs you will have to connect a 12-24V supply to the terminals on the relay side of the board.
Displaying 18196 - 18210 out of 18525 results.
Time to create page: 1.689 seconds
