  • andypugh
  • andypugh's Avatar
04 Mar 2025 15:55
  • hans48
  • hans48
04 Mar 2025 15:36
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
HalloDa ich keine Antwort zurück bekommen habe versuche es nochmal.Die Frage war was muss man alles Einstellen in der HAL und INI.Habe den Vorschlag von Talla83 in der HAL und INI eingetragen, aber da steht ja schon jede menge darinnen.Muss das Deaktiviert werden?Hänge die beiden File an, vielleicht kann es einer ansehen.
File Name: CNC_2025-03-04.hal
File Size:13 KB
Gruß Hans
  • COFHAL
  • COFHAL
04 Mar 2025 15:34
TAMAGAWA encoders model TS5661N132 was created by COFHAL
I have some TAMAGAWA encoders model TS5661N132. It is an encoder with RS-485 serial communication. The question is: can this type of encoder be decoded with Mesa cards that support SSI or BiSS? If I'm not mistaken, this encoder is a Biss encoder.
  • hakinen2255
  • hakinen2255
04 Mar 2025 14:45
Replied by hakinen2255 on topic How to open QT ui file in LinuxCNC
Category: Qtvcp
Hi Chris,
yes that worked and it loaded the screen, thanks.
  • Hastrh2o
  • Hastrh2o
04 Mar 2025 14:41
Replied by Hastrh2o on topic (not really) New machine geometry for plasma
Category: Plasmac
It help a lot to know the right name !
The most interesting thread I found is forum.linuxcnc.org/10-advanced-configura...-kinematics?start=10
One of the video we can find on the web
So, scara robot are definitely just another kind of config already implemented.
  • Aciera
  • Aciera's Avatar
04 Mar 2025 13:41
Replied by Aciera on topic Mitsubishi Meldas Control and Motors
Category: Milling Machines
You might also want to have a look at dmitry's interface cards.
yurtaev.com/
  • Ismacr63
  • Ismacr63
04 Mar 2025 11:34
Replied by Ismacr63 on topic irregular machining
irregular machining
The piece is perfectly squared, I don't think it's the loss of steps, I have hybrid motors with encoders and I use very slow speeds.
I'm going to check that the clamp hasn't moved.
  • Grotius
  • Grotius's Avatar
04 Mar 2025 11:27
Replied by Grotius on topic scurve trajectory planner
I had some real problems related to the clothoid fit.
It turned out eq.45 in the abstract is partially wrong.
In the abstract page.7 there is stated : DeltaTheta = Thetai4 - Thetai0.
Now this is most off time ok. But not alway's ok. The problem lies in the way DeltaTheta is calculated.
The input theta's are in range [0,2*pi], [0,-2*pi], derived from atan2(x,y). This are results of decomposed 3d vectors,
as the clothoid uses inputs for xy and z seperatly.
eq.45 Delta Theta [dt] uses - or + for direction. This is ok, so we know we must use - and +.
Simply substracting the theta's may lead's to incorrect values, wich results in a self intersecting clothoid for example,
caused by a extra + or - pi rotations.
I had to think a while how to solve this problem. To solve it, i calculated the theta's back into xy vectors and then
calculated the signed angle between these two xy vectors. Here is the solution in code.
So far above problem seems to be solved now.
I send a email to the abstract creator's and informed them about the problem.
Furthermore, the exact path deviation is used to fit the clothoid.
In total for one clothoid fit, ceres non-linear solver is used 3 times.
1. Ceres finds the clothoid xyz endpoint, given the 3 unknowns y11, y21, s1.
2. Ceres finds the closest point in space to the clothoid curve. (helper function to calculate path deviation).
3. Ceres finds the inperpolated points on curveA & curveB given the max path deviation.
The performance is about ~25ms to fit the clothoid.
Some fit clothoid curve fitting example's i used for validation :
// Line line fit.
// Arc line fit.
// Arc arc fit.
// No deviation is used here.
  • besriworld
  • besriworld
04 Mar 2025 11:26
Replied by besriworld on topic Mitsubishi Meldas Control and Motors
If you have absolute encoders, I think the best solution is to buy new servo drives and motors. Some good brands are Yaskawa, Delta, and CTB. I personally chose Adtech
  • timo
  • timo
04 Mar 2025 11:09
Category: Plasmac
It is a scara robot. Hard to believe no one has ever done one in linux cnc :-) I guess a 2nd hand one without controller is very affordable.
Maybe all you need to check is scara kinematics, scara robot, 4 axis robot.
forum.linuxcnc.org/38-general-linuxcnc-q...32013-scara-tutorial
  • Hastrh2o
  • Hastrh2o
04 Mar 2025 10:32 - 04 Mar 2025 10:34
Category: Plasmac
Hi all,
I just saw a ##### ad on #####  facebook for this : arcdroidcnc.com . A bi rotation arm that hold a plama torch. Simple and compact.
I already saw this kind of machine for pcb engraver (from elektor journal, in europe), and although for metrology devices.
I think it could be interesting, for people like me who don't have enough space to build a classic gantry plasma table. I need to stop filling my garage with machines.
I don't have the time yet, but I may be interesting in trying to make one with linuxcnc. At least trying to use this kind of geometry.
Any advices ? Does it already exist with linuxcnc ?
  • Aciera
  • Aciera's Avatar
04 Mar 2025 09:40
Replied by Aciera on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
Category: Installing LinuxCNC
The warnings in Problem 1 can be ignored but I'm not sure about Problem 2. There is ongoing work in master (2.10) to address the many compiler warnings that have been present for a long time. At the same time code checking standards are being made more stringent but I doubt that these would actually cause your compile errors. To test you could checkout the '2.9' branch instead of 'master' and try to compile that.
  • shaying526
  • shaying526
04 Mar 2025 09:39
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
Dear forum members,Hello!I am currently setting up and running two systems based on LinuxCNC and EtherCAT, and I have encountered an issue regarding system startup performance. I hope to receive assistance and advice from you all.Overview of System Configurations:
  1. First System:
    • LinuxCNC Version: 2.8.4
    • EtherCAT Version: 1.5.2
    • I compiled the Linux kernel, Xenomai, LinuxCNC, and EtherCAT myself, and used a real-time network card driver.
    • This system's EtherCAT drives quickly enter the OP state within 1 second after startup.
  2. Second System:
    • LinuxCNC Version: 2.9.3
    • EtherCAT Version: 1.6.1
    • Installed according to the stickied post on the forum. "Ethercat installation from repositories - how to step by step"
    • This system takes a long time (over 10 seconds) for the EtherCAT drives to enter the OP state after starting LinuxCNC, and sometimes it fails. At this point, I have to close and reopen LinuxCNC, which may sometimes result in success, but it is not consistent.
Commonalities and Differences Eliminated:
  • Both systems are deployed on the same hardware platform, eliminating hardware differences.
  • The configuration files are almost identical.
Request for Assistance:Given that the first system performs normally, how can I resolve the startup delay issue on the second LinuxCNC system?
  • Is it worthwhile to try using different versions of EtherCAT?
  • If so, what are the specific steps I should follow to do so?
Thank you very much for your valuable time and assistance! I look forward to your replies.Best regards
  • meister
  • meister
04 Mar 2025 09:32
never trired OpenOCD, but you can send me the error mesage of the openfpgaloader.
with openocd you should make sure that it is written to the flash and not just to the ram, otherwise everything will be gone again after a restart
You can see whether it has worked by the flashing LED
btw, the default ip is '192.168.10.194'
the w5500 module has a little power led on the bottom, there is no jumper to power on/off this module.
not realy shure what you mean with the mapping,
the bob pins are mapped 1:1, if you need P17 (relais) on the BOB, you can use 'LEFT:P17' in your config.
if your BOB is connected to the other connector on the right, then you need to use 'RIGHT:P17'
  • gmr
  • gmr
04 Mar 2025 08:58
Hi All,
I have an old VMC that is based on the Mitsubishi Meldas controller and Mitsubishi motors. The machine is in good mechanical condition but the control has given up the ghost, so I plan to replace all the servo drives and do a new controller based on LinuxCNC.
A few questions that I'd like some input on:
  • The machine has 3 phase 1kW, 3000 RPM motors on it for the X and Y axes and 2kW, 2000 RPM for the Z axis - they are Mitsubishi HA83  and Mitsubishi HA103 and have rotary encoders on them that means the original servo drives keep track of the absolute position. Does anyone have any thoughts on sticking with this motors or replacing them?  If replacing them, any suggestions for a good brand/family?
  • If I just replace the drives, then it seems that the Nidec/Control Techniques Unidrive M700 series might be a good choice? Any thoughts. Ideally I would power the drives directly from the 3 phase 415V supply (the machine currently has a transformer which delivers 200V to the drives).
  • On the control side, any suggestions as to which Mesa cards are well suited? Previously I have converted machines using the 7C81 and a Raspberry Pi and 5i25 and PC - I think this will need quite a lot of I/O so I'm thinking a PC based card this time.
Thanks,
Greg
Displaying 18376 - 18390 out of 18527 results.
Time to create page: 1.463 seconds
