  • Martin.L
  • Martin.L
05 Feb 2025 05:55
Replied by Martin.L on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
Are these a good starting point and still viable or are obsolete? the racktoolchange sample readme is pointing to an old EMC patch..
github.com/LinuxCNC/linuxcnc/tree/master...emap/rack-toolchange
github.com/LinuxCNC/linuxcnc/tree/master...h-tool-length-switch
  • amanker
  • amanker
05 Feb 2025 05:03
Replied by amanker on topic How to use Rcservos as axis motor.
Category: Basic Configuration
Thanks for explaining. I will ask help from remora developers.
  • ihavenofish
  • ihavenofish
05 Feb 2025 04:52
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
but i don't need those modules. surplus beckhoff encoder modules are in around $60-$80us
  • rodw
  • rodw's Avatar
05 Feb 2025 04:36
Replied by rodw on topic good day to all (in some gtp languages)
Probably a bit hotter up Rods way, but to be fair Queensland is 20 years and 1 hour behind the rest of Australia.
Thats a bit harsh! Nobody understands that half of Queensland already has half the state with 20 minutes daylight saving built in just by the longitude. Eventually, the rest of the world will come to realise the health benefits of normal time. I think Trumpy is on to it!
  • rodw
  • rodw's Avatar
05 Feb 2025 04:29
That board is rather expensive. Can get beckhoff kit for less.
I laid out the terminal block rail, seems like everything will be fairly simple so far.
Just check the currency. My link was probably in AUD which is the pacific peso these days about 0.60 to the USD.
Dont forget it includes several equivalent modules to beckhoff. Input, Output, Encoder, MPG counter, Analog 0-10v. Beckhoff encoder and I/O was over AUD $800 in 2021
  • rodw
  • rodw's Avatar
05 Feb 2025 04:22 - 05 Feb 2025 04:23
The dumification of humanity through internet
I think from memory very early in the piece, the US weights and measures or congress legislated that one inch was exactly 25.4mm
Its not really about a simple tape measure. SI units come into their own when doing any engineering calculations. eg power in HP (a page long calc) vs kW (a couple of lines). Now most engineering in the US is done in SI  I am told. I think to avoid loosing another space ship.
  • Martin.L
  • Martin.L
05 Feb 2025 04:13
Rack Tool Changer
Category: QtPyVCP
Yes, it will be really helpful if you can share this sample and how it's implemented step by step, even if the topic is about probe basic rack implementation it should merge on it somehow
  • rodw
  • rodw's Avatar
05 Feb 2025 04:12
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
You could also try installing Debian Trixie from the debian image now its available
raspi.debian.net/daily-images/
Note that this will not install a desktop, just a console but it will have a preempt_rt kernel available. I did do up a doc on doing this for Debian Bullseye which will basically be the same.
docs.google.com/document/d/1S0K-UBlXnsYC...b_0/edit?usp=sharing
The name for xfce package might have changed search the debian packages for XFCE to get the right name today.
  • ihavenofish
  • ihavenofish
05 Feb 2025 04:08
  • rodw
  • rodw's Avatar
05 Feb 2025 04:05
Once again thanks mate.
I'm going to play around with making an RPi5 image based on Trixie\Testing so I'll give it a whirl.
You might as well use the provided image becasue you basically end up with Trixie (with 6.1.2 kernel) and 2.9.4 already installed.
  • gwond
  • gwond
05 Feb 2025 03:08 - 05 Feb 2025 03:10
looking for a post processor to be used with Fusion 360
I'm using the one linked in this post successfully so far.  forum.linuxcnc.org/plasmac/38438-plasmac...t-processors?start=0
I haven't tested the center-punch functionality, but did test the small hole functionality on 3/8" holes and they turned out pretty well.
A couple things I learned along the way:
  make sure merge circles if unchecked when posting
  if you have multiple setups, you have to go to the operations tab in the post window and select them all.  They aren't all selected by default.
  • unknown
  • unknown
05 Feb 2025 02:36
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
  • unknown
  • unknown
05 Feb 2025 02:34
Replied by unknown on topic The dumification of humanity through internet
From memory there was some disparity between the English definition of billion and the US.
English was 12 zeros whilst the US was 9.
Look if NASA can have stuff ups with one team using imperial measurements and the other using metric any kind of stuff up and confusion is possible. Mars Climate Orbiter it was.
One thing I didn't know is that the definition of inch,foot,yard,chain,blah,blah is actually based on the inch being 25.4 mm. Tho once again different countries early in the 20th century had different ideas. From the doco I saw it was implied that the invention of slip gauges or "joe blocks" kind of pushed it to the front.
Carl Edvard Johansson the guy accredited with the invention of them modified his Wife's sewing machine to make the first set.
en.wikipedia.org/wiki/Gauge_block
Look under the bit titled history.
  • unknown
  • unknown
05 Feb 2025 02:20
Ethercat installation from repositories - how to step by step
Category: EtherCAT
No you'll need to use the RPi with a 6.1.x kernel, which should work. Rod has raised the issue regarding Ethercat not supporting 6.12 (anything higher than 6.1 I'd guess).
That's the trap when releasing a new image, some will want the latest kernel and then some, like yourself will require an earlier version. Can't keep everyone happy.
Sorry for any confusion and such, Ethercat is too rich for me, but once it's all sorted I'll be sure to test the Ethercat install works, wont be able to test any actual hardware but the actual install and building of modules I'll test.
And a final thanks for actually supplying the messages and such, much much better than "doesn't work".
Cheers
Rob
05 Feb 2025 02:16
Replied by tommylight on topic The dumification of humanity through internet
Dang it, i forgot the metric-imperial war! Shame on me! :)
We have the same silicium-silicon thing going on here with the milliard-billion nomenclature, and the strange thing is very few people actually remember that, despite being fully grown at the time that was used (milliard instead of billion, billion here had 12 zeros, milliard had 9), and it was a standard taught in schools from the first grade, now i have people older than me insisting that was never the case, while some luckily do clearly remember that as at one point in time we had a bank note with 9 zeros during the recession that never ended and the money was worth less than the paper it was printed on (yes i know it is not paper)!
It is astonishing how selective a human mind can be, probably coping system with bad-good memories and depending on what part the things in question got showed into.
Displaying 19441 - 19455 out of 19548 results.
Time to create page: 0.663 seconds
