16 Jan 2025 13:10
Replied by Cant do this anymore bye all on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
Category: Installing LinuxCNC
Looks a lot better.
One thing that was strange when running a basic config I got a real time error. hmmmmm
ATM the best image I've come across is Joco's rpi5 image rod has on his googledrive, that has a 6.6.54 kernel. It's my choice of the pre-built images.
I installed mate desktop, with 2 cores isolated, watching youtube latency is about 17-18us on my pi.
  • spumco
  • spumco
16 Jan 2025 13:09
Help Needed: Z-Axis Linear Guide Vibrations at Specific Speeds
I'll second rod's conclusion.  At that RPM steppers can vibrate like mad.
Change the screw pitch and you'll get the rpm out of the vibration range, as well as gaining some resolution and thrust.
  • gene_weber
  • gene_weber's Avatar
16 Jan 2025 12:38
Replied by gene_weber on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
The good news is switching to X11 is trivial.
You can check the session type:
echo $XDG_SESSION_TYPE
    wayland
Launch Rasp-config command line tool in a terminal:
sudo raspi-config
Arrow down to "Advanced Options", and enter.
Arrow down to "Wayland                 Switch between X and Wayland backends", and enter.
If not on the line that says "W1 X11     Openbox window manager with X11 backend", arrow to it and enter.
The popup should say "Openbox on X11 is active" and have "Ok" highlighted. Enter.
It will return to the main screen. Use left-righ arrows to select "Finish". Enter.
Popup asks if you would like to reboot now, with "Yes" highlighted. Enter.
After reboot:
    x11
Now here's the interesting apples to apples comparison. The only difference between these two pre-jitter-optimization baseline latency runs is Wayland vs X11.
Wayland:
X11:
  • timo
  • timo
16 Jan 2025 12:26 - 16 Jan 2025 12:30
Replied by timo on topic Rotating Axis Controlled by a Ballscrew
Category: Basic Configuration
Based on the given information about the requirements and constraints I cannot advise anything and cannot tell wether it will be successful, clever or foolish. :-)
My search terms would be: (without deeper knowlede)
lookup table
kinematics
Digging through the hal component list and look if I could convert the linear movement to an angle in the hal.
linuxcnc.org/docs/stable/html/hal/components.html
Greetings.
high resolution rotary encoders tend to be more expensive than a linear scale, so for a sine bar like arrangement I was thinking if a linear to angle system would benefit from. High torque, and high accuracy. At the cost of a very limited angular range.
  • hellvetica
  • hellvetica
16 Jan 2025 12:18
Replied by hellvetica on topic Using G64 with M66 for smooth robot control
Using MDI with python there's a 20ms delay between sending the command and the robot starting the move. There is also a 20ms delay between each MDI command i can send. So if i want to send 10 points to the robot it'll take 200ms to just send the commands.
This is far from ideal for a realtime application. Is there a parameter I can tune to speed up MDI?
  • snowgoer540
  • snowgoer540's Avatar
16 Jan 2025 12:18 - 16 Jan 2025 12:22
QtPlasmaC v2.9 - Time between turning off and back on the arc on a Powermax 105
Category: Plasma & Laser
Rod has a point about making sure you are using the right Mode. Assuming you are using Mode 1, it’s really odd to me that the power source is sending an arc ok signal when there is not even an attempt at a pilot arc. I know my powermax 65 (xp) will stop the post cool down flow and fire up the pilot arc. But also it won’t provide an arc ok signal until the arc is actually … OK.
It’s odd that it requires two torch on pulses to fire up after the cool down phase.
Are you sure it’s not in some other mode, like gouging or cutting expanded metal?
Also, I feel like this is vaguely familiar from an issue someone else had here. You might do some searching (if you haven’t already) of the forum, even though the search mechanism can be …limited…
  • programador
  • programador's Avatar
16 Jan 2025 12:11
Replied by programador on topic Keyboard shortcuts
Keyboard shortcuts
Category: QtPyVCP
Good morning friend, I know some shortcut keys for LinuxCNC, one day I will see if there is the possibility of creating a custom shortcut key and then I will post it here.
Keystroke Action Mode
F1
Toggle Emergency Stop
Any
F2
Power On/Off Machine
Any
`, 1..9, 0
Set Feed Override from 0% to 100%
Varies
X, `
Enable First Axis
Manual
S, 1
Enable Second Axis
Manual
Z, 2
Enable Third Axis
Manual
A, 3
Enable Fourth Axis
Manual
L
Select Jog Increment
Manual
C
Continuous Jog
Manual
Control-Home
Execute Home Sequence
Manual
End
Touch Off: Set G5x Offset for Active Axis
Manual
Left Right
Jog First Axis
Manual
Up Down
Jog Second axis
Manual
Pg Up, Pg Dn
Jog third axis
Manual
Jog fourth axis
Manual
O
Open file
Manual
Control-R
Reload file
Manual
R
Play file
Manual
P
Pause execution
Auto
S
Resume execution
Auto
ESC
Stop execution
Auto
Control-K
Clear background graph
Auto/Manual
V
Switch between preset views
Auto/Manual
Shift-Left, Right
Fast X axis
Manual
Shift up, down
Fast Y axis
Manual
Shift-PgUp, PgDn
Fast Z axis
Manual
Toggle real/commanded
Any
Toggle relative/machine
Any
  • Sternfox
  • Sternfox
16 Jan 2025 12:06
Keyboard shortcuts was created by Sternfox
Keyboard shortcuts
Category: QtPyVCP
Hi all,  im nearing the end of my retrofit build. I am wanting to use some keyboard shortcuts. Not for jogging!
I want to be able to select individual axis for mpg jogging using a keyboard shortcut. Also select things like mpg reaolution. Is this possible?
Thanks in advance
  • programador
16 Jan 2025 11:59
Replied by programador on topic home axis problem
home axis problem
Category: AXIS
LinuxCNC has two forms of safety. The first is to limit the maximum distance that the axis can travel, but this option only works if the home is started in the initial position, otherwise it will collide. The second form of safety is to have sensors for the start and end of the stroke and the initial position, with these three sensors it is ideal to guarantee safety. A third option is to configure the drives, some equipment has parameters to limit the current and thus not exceed the mechanical limits of the machine.
  • spumco
  • spumco
16 Jan 2025 11:42
Replied by spumco on topic Rotating Axis Controlled by a Ballscrew
A simple (simplistic?) way would be to use the lincurve component to compensate for the non-linear rotational distance.  Your model also needs to incorporate a pivot at the ballscrew mount since the screw will swing as the B-axis travels.
I would also install a high resolution encoder directly on the B-axis so LCNC can use a PID to adjust for screw mapping and lincurve errors.
But yea, I'd also abandon this idea and use a direct drive motor or a roller cam gear - or even a harmonic with a brake.  Even more simple - a big gear with two pinions and two servos.  One of the servos is in position mode and the other is programmed in torque mode to oppose the position servo to take up backlash.
  • rodw
  • rodw's Avatar
16 Jan 2025 11:10
Replied by rodw on topic 7i96s Arc Voltage + Encoder Fault
Now you have a THCAD 2 you can do more tests.
But normally, you would set the THCAD to use 1/32 frequency. This would alter your offsets etc accordingly. Make that change
Assuming a 10 volt range, apply a 9 volt battery to the THCAD  HV input. The flashing light should change frequency. Does it?
the voltage should be about  90% of your full volt range. Is it?
What are the calibration frequencies for your THCAD on the sticker?
Read the encoder velocity at 0 volt at rest and at 9 volts.
What are these readings?
  • timo
  • timo
16 Jan 2025 11:04 - 16 Jan 2025 11:09
Replied by timo on topic Kappa goniostat
Kappa goniostat
Just a question ? Do you have those softwares at hand?
You might end up with five axis requirements and then looking at a hefty monthly suscription :-)
Just get a new detector and use it, for what it was for :-). But... did it come with some sort of x-ray light source?
mmmh. Any lead west in the box?
How about a 3d scanner? Woud at least be more close to original function.
  • KrisR
  • KrisR
16 Jan 2025 10:22
Replied by KrisR on topic Kappa goniostat
Kappa goniostat
I see your point. I thought to use Autodesk CAM (Inventor or Fusion).
  • Gautham
  • Gautham
16 Jan 2025 09:39
Replied by Gautham on topic Rotating Axis Controlled by a Ballscrew
Also something like this was used by Centroid for their cylinder head porting and polishing machines. Except they used to turn the work piece rather than the spindle. In their newer design they claim that the b-axis is controlled by a ballscrew but it is not visible
  • hellvetica
  • hellvetica
16 Jan 2025 09:38
I'll make some more tests with MDI and see how feasible it is.
Motion blending is a must have for us.
Displaying 19726 - 19740 out of 21715 results.
Time to create page: 0.530 seconds
