  • NotAllThere
  • NotAllThere's Avatar
07 Jan 2025 22:58 - 07 Jan 2025 23:26
Simple Z touch off generating empty error [SOLVED]
Category: Basic Configuration
I'm adding a touch probe to a ChinaZone 6040 with a Mesa 7i76e card following what seems to be pretty simple instructions from forum.linuxcnc.org/49-basic-configuratio...obe-with-a-mesa-7i96.  It's really close, but generating an error.
When I click on "Tool Touch Off Z" in the side panel, I get a blank error (see attached pic):
<l> (?) [x]
Where should I look to find the problem?  I've gone through the example a few times and am just missing it somehow.  I've checked the Linux logs, but haven't found anything yet.
  • Axis 2.8.4 (I can upgrade if that would help)
  • Hal Meter signal probe-in turns to true when the touch probe is triggered, so the wiring & HAL seem correct
  • I've run each of the commands in the ngc file using the MDI tab and they all function as expected
  • The 5 updated files are attached and each has it's full path in the comments at the top of the file
    Thanks,
    Ted
  • Tntmold
  • Tntmold
07 Jan 2025 22:17
Replied by Tntmold on topic Ethercat auto configurator.
Category: EtherCAT
as a new linux user, can someone give tips on how to install/try this twincat utility?
  • gbsd86
  • gbsd86
07 Jan 2025 22:00
Replied by gbsd86 on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
Python3-distro installed. Installed Mesact 2 from terminal.
Now connected to Mesa board.
Thanks for the help.
  • slowpoke
  • slowpoke
07 Jan 2025 21:58
Where are the stepper direction pins hiding in 7196S HAL?
Lathe using axis X & Z drives and 7196s
I connected up X-axis to step and direction #1 pins, joint 0 and then calibrated, all working.
Now I'm trying Z-axis, looks like it's supposed to be step and direction #0, joint 1 but it's not working (yet), I'm trying to see the direction pin in HAL show, but can't seem to find it, where can I find the direction pin TB1-4 in HalShow?
File Name: CX706-R0.hal
File Size:10 KB
File Name: CX706-R0.ini
File Size:3 KB
I can see joint.0&1.motor-pos-cmd changing
I can see stepgen.00&01.counts changing
Much appreiated
  • JT
  • JT's Avatar
07 Jan 2025 21:28
Replied by JT on topic Mesact 2 Setup
Mesact 2 Setup
This is the normal debian.org settings
JT
  • gbsd86
  • gbsd86
07 Jan 2025 21:04
Mesact 2 Setup
I tried adding Debian repositories, haven't found the settings Synaptic is happy with security wise.
  • JT
  • JT's Avatar
07 Jan 2025 20:57
Mesact 2 Setup
Synaptic repositories
OK your using Rod's OS and he prob deleted it the scoundrel LOL
JT
  • gbsd86
  • gbsd86
07 Jan 2025 20:53
Mesact 2 Setup
  • JT
  • JT's Avatar
07 Jan 2025 20:47 - 07 Jan 2025 20:56
Mesact 2 Setup
hmm AI says to install distro with pip and that I don't want.
I removed the code that used distro.
JT
  • JT
  • JT's Avatar
07 Jan 2025 20:45
Mesact 2 Setup
This is on my dev PC
john@cave:~$ uname -a
Linux cave 6.1.0-27-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.115-1 (2024-11-01) x86_64 GNU/Linux
john@cave:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 12 (bookworm)
Release:	12
Codename:	bookworm
JT
  • Lcvette
  • Lcvette's Avatar
07 Jan 2025 20:40
Specified probe tool not in spindle error after upgrade
Category: QtPyVCP
would certainly be pretty sweet, PB does change fairly frequently since it isn't in the main linuxcnc repo. and i certainly struggle with good ways to a successful method to ensure users can easily update any required changes.
does this seem like something you might want to run with?if so let me know, you are welcome to join us in the qtpyvcp chat:
matrix.to/#/#qtpyvcp:matrix.org
it is hugely helpful when we get folks who can help propel the project forward! A great group of folks and an awesome supportive culture! feel free to pop in!
  • jst
  • jst
07 Jan 2025 20:37
Replied by jst on topic Building and configuring a stmbl v5
Category: Driver Boards
Then just send me an mail (adress is in my profile)
  • lukin1156
  • lukin1156
07 Jan 2025 20:32
Replied by lukin1156 on topic PC for Mesa 5i25T
PC for Mesa 5i25T
In the end, the problem was in the switched analog signal and the GND of the analog signal. After swapping it works without a problem.
  • gbsd86
  • gbsd86
07 Jan 2025 20:28
Mesact 2 Setup
I checked OS version (see below). Is Debian 12 Bookworm.
Using Gdebi, installation fails because of python3-distro.
Synaptic search doesn't show python3-distro. Also not in the list of python3 files.
Have the zip file of python3-distro. Haven't been able to figure out how to install it.
g@debianNC:~/Downloads/python3distro/distro-master$ uname -a
Linux debianNC 6.1.0-13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.55-1 (2023-09-29) x86_64 GNU/Linux
g@debianNC:~/Downloads/python3distro/distro-master$ lsb_release -a
Release: 12
Codename: bookworm
  • Unlogic
  • Unlogic
07 Jan 2025 20:26
Category: QtPyVCP
For most of the Java applications I've written over the years I included sanity checks of the configuration that executed as early as possible during the startup process before something else had the possibility of crashing due to missing invalid or configuration.
Below is a snippet of code from the Java based DNS server I wrote long ago (unlogic.se/projects/eagledns).
Now given how good LinuxCNC and Probe Basic is working I haven't really had to roll up my sleeves and get to familiar with how the bootstrap/initialization of the user interfaces works. But I guess in the case of Probe Basic maybe a hook or method for checking the configuration could be added in QtPyVCP that each derived user interface could then implement and check the configurations before QtPyVCP  proceeds to load the actual GUI.
Displaying 20401 - 20415 out of 21739 results.
Time to create page: 0.338 seconds
