  • xenon-alien
  • xenon-alien's Avatar
30 Dec 2024 11:20 - 30 Dec 2024 11:54
Replied by xenon-alien on topic MESA 7i96S STEP DIR I/O compatibility
Category: Driver Boards
Found something.
Left to figure out how to set it correctly. It looks like the step dir is also supported in this drive.
30 Dec 2024 10:59
Replied by tommylight on topic MESA 7i96S STEP DIR I/O compatibility
If you mean CV and CCV quadrature steps, then most probably yes, and the only thing required should be to change the stepgen type in hal to type 1 or 2 (i forgot what exactly).
  • xenon-alien
30 Dec 2024 10:41
Hello!
Can the 7i96s card handle CW +/- and CCW +/- instead of step/dir?
I need to control a Mitsubishi mr-je-40a servo drive I
The drive smarter then me, so, I'm not sure... Maybe the servo can the step/dir too, but not figured it out yet how.
30 Dec 2024 10:34
  • Murphy
  • Murphy
30 Dec 2024 10:21
I'm finally getting somewhere with the encoder. Used this diagram from the site below. Ordered the board from jcbway, the iso7740 and components from AliExpress. I finally get the PV counting in both directions. Next just figure out the spindle setup with it.
www.electronics-lab.com/project/4-channe...d-digital-isolators/
  • thomaseg
  • thomaseg
30 Dec 2024 10:16
Replied by thomaseg on topic EL5112: Change PDO assignments via LinuxCNC?
Category: EtherCAT
...or maybe there is a way of configuring devices that i don't know of? The manual does not seem to mention ANY configuration apart from this PDO assignment...
  • Toyota1zz
  • Toyota1zz
30 Dec 2024 10:13
Chasing Threads and Re-Threading was created by Toyota1zz
Greetings. I've been looking online but havent figured out what size tap i need for a thread in my engine block where a 17mm metric sized bot goes in to botl on the tensioner. I appreciate any help!
I think I will have to rethread it. It would be my first time.
  • fully_defined
  • fully_defined's Avatar
30 Dec 2024 08:19
Replied by fully_defined on topic Rotary Selector Switches & Resistors
For absolutely no reason at all, I decided to make it fancy. Now I can choose the orientation of the center of the switch sweep, like noon, 3, 6 or 9 o'clock.
If I were to do this again, I would probably start measurements like a unit circle, with all angular measurements a positive value from the x-axis, CCW. Live and learn.
  • timo
  • timo
30 Dec 2024 07:37
Replied by timo on topic mill 4th axis
mill 4th axis
Category: Milling Machines
In addition to info from spumco.
Commercial suppliers of 4th axis usualyl differenciate between positioner (brake opens, thing rotates, brake closes)
Movable axis which allow light milling up to heavy milling. (workpiece weigth torqure)
Movable axis that are even fast enough to do turning operations. (sometimes even with direct drive)
If a positioner is "good enough" it makes things a lot easier.
  • cmorley
  • cmorley
30 Dec 2024 07:31
Replied by cmorley on topic qtvismach, a axis toolpath
Category: Qtvcp
Ok I pushed some work on this.
vismach_mill_xyz should show case it.
in your vismach script you need to add:
on top:
from qtvcp.core import Status
STATUS = Status()
and in the Window class:
        STATUS.connect('motion-type-changed', lambda w, data: v.choosePlotColor(data))
        # uncomment to change feed color and to see all colors
        #v.setColorsAttribute('FEED',(0,1,0))
        #print(v.colors)
  • onceloved
  • onceloved's Avatar
30 Dec 2024 07:11
Replied by onceloved on topic Probe Basic - How does tool setter calculate ?
Category: QtPyVCP
You can watch this video
  • fully_defined
30 Dec 2024 04:07
Replied by fully_defined on topic xfce panels are hidden
I want my desktop to look like this:https://www.tecmint.com/wp-content/uploads/2013/07/xfce-11.jpg
I like the mouse background! Is that still available as an option in LinuxCNC?
It reminds me of the startup screen on Heidenhain TNC640, since it's no secret that it's just an application running in Linux on XFCE desktop. In fact, my job programming for and running a Hermle 5-axis mill is part of why I decided to finally start using LinuxCNC at home.
I am otherwise totally new to Linux, and I haven't even bothered to figure out how to change the desktop background yet. I am one of those weird people that usually keep the default desktop background.
  • Lcvette
  • Lcvette's Avatar
30 Dec 2024 02:44
Replied by Lcvette on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
Excellent news!
  • PCW
  • PCW's Avatar
30 Dec 2024 02:35 - 30 Dec 2024 15:08
Replied by PCW on topic Fast Hole EDM from Hacked Parts
Yes, duty cycle is the correct pin.
Is the frequency reasonable and the valid bit set?
It sounds like the EDM output is single ended which means:
1. The EDM duty cycle output should connect to TB2 pin 13 (IDX+)
2. The EDM signal ground should connect to TB2 pin 15 (7I96S ground)
3. The 7I96S IDX input should be jumpered for TTL mode (W1 left)
4. 7I96S IDX- (TB2 pin 14) must be left unconnected
Note the if you connected the inputs to TB2 pins 13 and 14 without a ground
and ran the EDM system you may have damaged the EDM output or
7I96S input.
  • cmorley
  • cmorley
30 Dec 2024 01:08
Category: Qtvcp
I should have explained more.
point = [wx, wy, wz]
if not self.plotdata or point != self.plotdata[-1]:
self.plotdata.append(point)
This adds a plot point. We would need to change it to also add color.
point = [wx, wy, wz,color]
or maybe better:
self.plotdata.append([point, color])
then later in the file:
#GL.glColor3f(1.0, 0.5, 0.5)
GL.glBegin(GL.GL_LINE_STRIP)
for p,c in self.plotdata:
GL.glColor3f(*c)
GL.glVertex3f(*p)
GL.glEnd()
a few other initialization and clearing details to follow up. but that might work.
Displaying 20911 - 20925 out of 21848 results.
Time to create page: 0.530 seconds
