  • NCPatrol
  • NCPatrol
02 Dec 2024 16:51
Replied by NCPatrol on topic WTB: 7i92 or 7i92h
WTB: 7i92 or 7i92h
Category: User Exchange
Looking at Mesa's site, I can't tell the difference between the 7i92 and the 7i92m. The specs look identical so i would assume the M would work.
I'm looking at options to "trick" pathpilot in to using the T card, but it's a bit over my head so I'd much rather get something that just works.
  • Muecke
  • Muecke's Avatar
02 Dec 2024 16:20
[OT] Frage zu Spannzangen und Eigenbau-Werkzeug
Category: Deutsch
@Timo, ja da hast du recht.
Am liebsten würde ich mir die Teile in echt anschauen und dann sehen was wie funktioniert und ob das was ich machen möchte machbar ist und wenn ja wie.
Das mit dem selber machen, was du meinst, das habe ich noch nicht so ganz verstanden.
  • royka
  • royka
02 Dec 2024 16:07 - 02 Dec 2024 16:57
  • Stefavita77
  • Stefavita77
02 Dec 2024 15:51
Error when compiling and installing custom kinematics
Category: HAL
Thanks for sugget, i try it
  • Aciera
  • Aciera's Avatar
02 Dec 2024 15:30
Category: HAL
While the 'halcompile' tool usually works for most things it is sometimes necessary to compile from source with all build dependencies installed.
So I would suggest to clone the git repo and do a run-in-place (rip) install by building linuxcnc on your local machine.
linuxcnc.org/docs/stable/html/code/building-linuxcnc.html
  • PCW
  • PCW's Avatar
02 Dec 2024 15:29
Replied by PCW on topic N/O Probe issue
N/O Probe issue
Category: HAL
You may have more than one issue.
First the polarity needs to be correct
( set it so the Halshow dot goes yellow when the probe is activated)
In addition, it's possible you have a noise issue. This may be fixable
by de-bouncing the pin, either in hal of by installing firmware with input
filtering (7i96_inmd.bit) and using the inm pin instead of the GPIO pin.
  • spumco
  • spumco
02 Dec 2024 15:23
Replied by spumco on topic Retrofitting a 1986 Maho 400E
Category: Milling Machines
Drawbar springs?
I can't tell from the diagram you had in the vid, but it looks (and sounds) like the hydraulic DB is a spring return system - I thought I only heard the pump loading up during release.
And DB springs are consumables...
Easy enough to pull the DB and have a look at the springs (if I'm right) before fully digging in to bearings.
  • PCW
  • PCW's Avatar
02 Dec 2024 15:17
Replied by PCW on topic 7i77D availability
7i77D availability
How many outputs do you need?
A 7I97T may work (and if more outputs were needed a 7I84U could be added)
Should have a 7I77U (Universal outputs) available but about middle next year
  • Stefavita77
  • Stefavita77
02 Dec 2024 15:14
Category: HAL
Hello all,
I am trying to compile with the command "halcompile -- install <5axiskins.c>" a custom kinematics modifying a function of the original 5axiskins.c
but i get this error
emc@emc:~/Desktop/5axiskins$ sudo halcompile --install 5axiskins.c
Compiling realtime 5axiskins.c
Linking 5axiskins.so
/usr/bin/ld:5axiskins.ver:2: syntax error in VERSION script
collect2: error: ld returned 1 exit status
make: *** [/usr/share/linuxcnc/Makefile.modinc:125: 5axiskins.so] Error 1
I need it to modify the PmCartesian s2r function to calculate the axis compensation.
Someone can help me to do it?
  • Grotius
  • Grotius's Avatar
02 Dec 2024 15:06
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Did some work on the super imposed interpreter code again.
It's now able to do more things like : stop, restart at line, set variable at runtime.
The video show's basic functionality. And show how sub interpreters may run their own program.
There is a machine-consume button, wich simulates the motion planner takes lines of gcode from the interpreter output buffer.
The delay input's slow's down the simulation wich enables us to view the step's the interpreter does.
Have to make the qt layout more fancy.
02 Dec 2024 14:37
Replied by tommylight on topic 7i77D availability
7i77D availability
Germany
www.welectron.com/Motion-Controller_1
no 7i77 at all
Portugal
eusurplus.com/index.php?route=product/pr..._61_60&product_id=51
Has in stock normal 7i77 without the D.
USA
mesaus.com/product/7i77/
has 2 of 7i77 without D in stock
store.mesanet.com/index.php?route=produc...69_71&product_id=120
20 of 7i77 in stock, again no D
  • natholego11
  • natholego11's Avatar
02 Dec 2024 14:33
Replied by natholego11 on topic N/O Probe issue
N/O Probe issue
Category: HAL
ive tried with both _not and without the not, and I still get the same message.
  • JT
  • JT's Avatar
02 Dec 2024 14:15
  • JT
  • JT's Avatar
02 Dec 2024 14:15
Replied by JT on topic Touchy error
Touchy error
Category: Other User Interfaces
Is this linuxcnc 2.9?
Yes
JT
  • cmorley
  • cmorley
02 Dec 2024 14:07
Replied by cmorley on topic Touchy error
Touchy error
Displaying 22216 - 22230 out of 22287 results.
Time to create page: 0.428 seconds
