  • phillc54
  • phillc54's Avatar
17 Oct 2024 22:16 - 17 Oct 2024 22:28
Replied by phillc54 on topic Update failure
Update failure
Category: Plasmac
You need to set the repository in Synaptic to
deb http://buildbot2.highlab.com/debian/ bookworm master-uspace
plus you need to copy the key as shown for the new style. This is all shown here:
  • ccc774
  • ccc774
17 Oct 2024 22:14
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
I can read all the IDs in /drv/disks...., but I don't know how to enter it to recognize it.
17 Oct 2024 21:58
Replied by tommylight on topic Can the OPI5 be Configured to Run LCNC?
... alternatively you could issue the blkid command to see the UUID.
I could not recall this to save my life when i was answering this! :)
Thank you for reminding me, now i will go on and forget it promptly! :)
17 Oct 2024 21:47
Replied by tommylight on topic Welche Tasten haben die Achsen?
Category: Deutsch
Menu>preferences>keyboard>Layouts tab, add
there add "English (US)" layout, a bit lower check if the "keyboard model" is "generic 105 key PC" and change if not, close.
Now there should be a little icon on the lower right side with US or DE in it, click on it and change to US, try jogging with []
@Tchefer,
No, and i can not find it now, will have ask google later and report back.
  • ccc774
  • ccc774
17 Oct 2024 21:44 - 21 Oct 2024 22:06
first of all, thank you for your prompt answers.I can boot with kernel 6.1.75-vendor-rk35xx, with the 6.1.75-rt23 .debs installed, but without making the link (sudo ln -sf vmlinuz-6.1.75-rt23 Image). If I reboot and then make the link, it doesn't boot anymore. In /proc/cmdline I don't see any value for ubootpart=.
  • footpetaljones
  • footpetaljones
17 Oct 2024 21:42
Replied by footpetaljones on topic linuxcnc trajectory planner
At least for Fanuc, smoothing should be applied to probing moves, it not being applied means that the MTB didn't set the 6200 parameters as they should have and trapezoidal acceleration/deceleration is applied to skip moves vs bell curve acceleration/deceleration.
17 Oct 2024 21:38
Replied by tommylight on topic Help with Denford Machine AXIS config
Several things might be off here:
-the gcode produced by Easel is set as "center 0,0", while almost all machines normally use "lower left 0,0"
-the machine is set as "home 0,0" to upper right, almost all use "lower left 0,0"
-Homing is not set properly
Is this an existing config that worked at any point in time or is this a new and untested config?
If the latter, open file explorer and in the EMC2 folder then configs folder, check if there is another existing config.
  • IronManDylan
  • IronManDylan
17 Oct 2024 21:32
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
It looks like I might be able to get my hands on a powercore from rackrobo. But if anyone has more thoughts on the powersupply please let me know.
Can anyone speak to wether linuxcnc can be configured to run edm? Can it handle reverse feedrate? Are there any linuxcnc resources on running EDM? Thank you.
  • IronManDylan
  • IronManDylan
17 Oct 2024 21:27
Timo - what is a holeflix and a spotdrillfy? Are those products? Also are you saying that a BAXEDM is 4k? That seems about right.  Which is out of my price range tommy...
  • robh
  • robh
17 Oct 2024 20:25
Replied by robh on topic Trajectory Planner using Ruckig Lib
superimposed control
there are alot of multi turret and multi spindle lathes about now, old controls etc so needing some love of a new control , but to get the best from them you need run multi programs at once, superimposed if machine layout allows etc.
more so when you want to use two turrets on the main and do "pinch turning"
with super imposed you can offset pinch turn also so one tool will be slighly infront of the 2nd tool doing the finish.
you can start to do machines like this
this is superimposed control, where other axis sets must follow a master
basicly you "offset" the slave X Y Z to the master X Y Z which gives you axis following each other as you see.
yes there are macros that you call todo all this, (citizen call these sync codes) but its only setting up the system to group axis for use in each program, defind what will follow what and who and how.
the macro will also postion the machine in place for you to a setup drive on point. so the operators never see anything complex and scary to program as its been done for them interms of axis selection
you just program as if it was a normal X Z lathe.
i only have back ground on citizen machiens which have a lot of macros todo this alot of this, but have a good back ground how its basicly working things in the back ground. i think star has a different way todo things in terms of sync codes but i dont know never seen a program for one etc.
here is a video of my M20 sliding head Citizen, quick part i had to make.
here is a video of the program running
here you have 3 programs that run together using sync codes and wait codes.
these are kept in 1 file on citizens they just define each program by a $ sign for each program start $1,$2,$3 , when loaded on machine its displayed as 3 programs as seen in the video
here main slid on main spindle is working at its own speed while bottom turret is working on back end of the part in the sub spindle
once done, it waits for the main to be ready for turret to work on the main (you can use turret and main slid at the same time also, also can use the turret to say drill/bore on main and sub can drill or bore on turret also)
  • royka
  • royka
17 Oct 2024 19:52
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Like tommylight said and I want to add that you should also check /boot/armbiEnv.txt for the same UUID. When you see a /boot mount in fstab you could remove that line too.
Here it didn't recognize the ID option by the way, in that case just leave that away, alternatively you could issue the blkid command to see the UUID.
  • robh
  • robh
17 Oct 2024 19:45
Replied by robh on topic linuxcnc trajectory planner
i have also noticed on my fanuc , mitsubishi machiens it seems when in a probe move there is no smoothing on any axis motion, its a much harder point to point move you can hear the differance on the machine axis when making prob moves onto a surface.
so dont think that the main stream controls use motion smoothing on probe moves as it seems they do not, when you are probiing it tends to not be that fast also, aprox 1000mm/min feed is common.
for the reasons mentioned before. as probining its key you always have a known probe detection trigger distance etc as this is what you calibrate a probe cycle for..
also
dont for get threading on lathes (G33 and g76) is another one you will skip for smoothing as it must follow the spindle encoder like tapping.
  • Tchefter
  • Tchefter's Avatar
17 Oct 2024 19:38
Replied by Tchefter on topic Welche Tasten haben die Achsen?
Category: Deutsch
@tommylight
Do you have a Ascii Code for the Signs to move the C-Axis?
So, i think, it must be possible to search for the Signs on DE Keyboard.
  • PCW
  • PCW's Avatar
17 Oct 2024 19:05
Machine moves when you stop program in the middle
What hardware are you using?
A system with a failing encoder might behave in this way.
  • Nixus
  • Nixus
17 Oct 2024 19:05 - 17 Oct 2024 19:06
Hello all!
I am using Linuxcnc, which came with the machine, and I am also using Easel as CAM/CAD software.
 I managed to get the G code to load, but it's showing me this inverted image.
I use Easel for my designs, but something is off unless it's just me doing the config wrong.
Additionally, i am trying to home axis but it's just telling me that switches are inactive with a grunt.
I can move the machine manually but I'm afraid config stuff feels like space magic x3 I am very new to this world and a lot of terms don't make much sense to me tbh. I am a Windows user primarily and Linux caught me off guard
Any help is greatly appreciated!!!
Surely a noob like me can figure this old cranky Elizabeth out.
Displaying 22546 - 22560 out of 22868 results.
Time to create page: 1.792 seconds
