  • my1987toyota
  • my1987toyota's Avatar
29 Jul 2024 17:40
Was the SPAM topic a test was created by my1987toyota
  So for maybe a week or so there was a section called Spam for Spammers. I don't know if it
was set up as a joke or not . I was certainly having some fun with it myself. Then someone
posted a legitimate question in it and a day or so later the section has disappeared.
What happened?.
  • Becksvill
  • Becksvill
29 Jul 2024 17:33
  • Becksvill
  • Becksvill
29 Jul 2024 17:29
Replied by Becksvill on topic big 5axis mazak horizontal cnc mill
Category: Show Your Stuff
Only reason to make this thread was too sure people how good Linuxcnc is especially on a big CNC.
And how we deal with potential issues like no jerk control.
And 1 line look ahead for 4axis
Plus any other issues.
I have 80 tools in magazine is that a issue still?
  • Becksvill
  • Becksvill
29 Jul 2024 17:26
Feel free to discuss here
  • thomaseg
  • thomaseg
29 Jul 2024 17:25
Replied by thomaseg on topic Tuning of servo-drive
Category: EtherCAT
Hi again,
For "posterity" on google i thought i'd show what i did on my CTB-servodrives. I managed to figure out that if i turned up for the gain(register Cn.29) from the factory setting of 100 to 350 i got quite a lot better results. Now a "step" looks something like this:
Greatly reduced the follow error and made it hit the required position a lot faster/better. I tried higher values, but then it will overshoot. This enabled me to turn "ferror" down to 10 and "min_ferror" down to 1 in the settings without getting "follow error" when jogging....this is better, but not sure if it is good/low enough?
However, i still have a question: There is a delay between "pos-cmd" and "sta-ActualPosition", obvious this can never be 0, but it seems like there is something like 50ms between the two according to the graph...this seems "long" to me...is that normal? I'm guessing that EtherCAT has something to do with this, even though i think it should be an order of magnitude lower if it stems from EtherCat. Anyways, i'm unsure if this will affect the performance of the machine significantly...?
Question: What is this delay on your machine? I'm trying to either comfort myself and accept that this is a normal delay, or determin if i have to keep digging in the drives registers to try to make the drive follow LinuxCNC in a tighter way...somehow...
/Thomas
29 Jul 2024 17:08
Replied by tommylight on topic Mesa 7i96s + DM556T -> Motors not moving
Category: Driver Boards
If your getting over current alarm, most probably the motor wires are miss wired.
Stepper motor wiring is very strict, no mixing of coils, that is something most drives will not survive.
To check wiring, connect any two motor wires together (disconnected from the drive) and turn the motor by hand, if you feel resistance = that is one winding and those two wires MUST go to A+ and A- <<<OR>>> B+ and B-, never ever between any A and any B.
29 Jul 2024 16:55
Replied by tommylight on topic Interesting Youtube Video
I suggest having a huge banner on every web page on planet earth to remind people that the server they are getting pages from runs Linux, open source software.
The whole world runs on Linux, everything from microwave to NASA "Mission Critical" stuff, to stuff that keeps humans alive in hospitals.
All still Open Source or was Open Source at a given point in time.
Talking bad about developers is really uncalled for:
- they are humans, and as such they might get p.o. seeing their software used in huge projects that are making someone somewhere insanely rich, but they are still in their parents basement pushing 40-50 years old with no wife and kids....
-or someone else jumping into their project and trying to change how he/she did things while intentionally trying to make them look dumb/stupid/incapable
And no matter how bad the first example was, this second one is much worse.
It is Open Source, if you do not like how it is, fork it and do things your way, do not demean the original developer/s
To ALL DEVELOPERS everywhere:
THANK YOU.
  • ffffrf
  • ffffrf
29 Jul 2024 16:05
Replied by ffffrf on topic Help with pncconf Z-X-A custom machine
But can you elaborate how you "removed" the Y axis from within linuxcnc / pncconf?
  • MartynT
  • MartynT
29 Jul 2024 16:05
Replied by MartynT on topic Inch display on Metric machine?
Well - (to put it politely) blow me down . It had to be something simple of course. I will check it out shortly. Many thanks.
  • my1987toyota
29 Jul 2024 15:47 - 29 Jul 2024 16:22
Replied by my1987toyota on topic Mesa 7i96s + DM556T -> Motors not moving
I am not familiar with those exact motors. That said, I just want to make sure that none of the motors will move at all?
Do they make any kind of noise when a move is commanded? Like when a stepper is stalled? Do they get hot?
If none move at all and they all trip with the exact same problem check your drives amp setting.
It may also be possible that the motors need to be wired in bipolar series for those drives to work
with them.
  • manfrel
  • manfrel
29 Jul 2024 15:36
Replied by manfrel on topic Mesa 7i96s + DM556T -> Motors not moving
For X-axis and Y-axis it's Nanotec 4H5618 C0408
www.nanotec.com/fileadmin/files/Datenbla...toren/4H5618_L_C.pdf (it's in german)
For Z-axis it's ISEL MS110 (473030)
www.isel.com/hu/mwdownloads/download/link/id/4186/
  • my1987toyota
29 Jul 2024 15:28
What size motors are you driving with them?
  • scotth
  • scotth
29 Jul 2024 15:22
Replied by scotth on topic Inch display on Metric machine?
In AXIS use the VIEW tab and select Inch or Metric display, or use the "!" key.
  • Aciera
  • Aciera's Avatar
29 Jul 2024 15:14 - 29 Jul 2024 15:16
  • manfrel
  • manfrel
29 Jul 2024 15:07
I found it. Unfortunately switching it to 5V didn't change anything.
However I realised that the red LED of the drivers are blinking one time every three seconds, in the manual it says "Over-current protection activated when peak current exceeds the limit."
Displaying 24691 - 24705 out of 24912 results.
Time to create page: 0.615 seconds
