13 Jul 2026 14:04
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
I just checked the NAS, i do not have the headers.
You can install a new RT kernel and headers, or older one, but do not use 6.1 as it had some nasty latency issues (no idea what exact version it was).
Should be 6.17 by now so give that a try.
  • spumco
  • spumco
13 Jul 2026 13:36
Replied by spumco on topic C axis milling cycles. Anyone written any?
An alternative to consider would be using polar interpolation combined with a 'standard' set of macros for XY-type milling.
As I mentioned earlier, polar interpolation is not in main-line LCNC but there is a working configuration available on the forums:
forum.linuxcnc.org/10-advanced-configura...oling?start=0#225787
Nojo's implementation works, but I think the hurdle for anyone else to use it is that Nojo hard-coded the live tool offsets to match his particular machine.  I'd think some editing of the comp would be required to make it a universal component/scheme.  (i.e. use the currently loaded tool offset, not a fixed offset)
If you found an existing 'conversational' configuration/GUI you liked, polar interpolation should permit programming using that conversational system.
However, it's understandable if you're not interested in falling down the comp file development rabbit-hole and just want some working macros.
  • Sascha H.
  • Sascha H.'s Avatar
13 Jul 2026 12:28
  • rodw
  • rodw's Avatar
13 Jul 2026 11:14
Replied by rodw on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
I might be wrong as I have only used Debian for years because Mint let me down a few years ago when Python 3 became mandatory for Linuxcnc and have not researched this for you.
I have a feeling that 6.13 is not a standard kernel used by Debian and therefore its derivatives. I believe that 6.12 was a release version.
So if it was not released, there won't be a readymade set of headers so you would need to compile the kernel to a Deb file which will output the headers as a Deb to install.
Debian is a much easier path. Just install the Cinamon desktop on install and you'll hardly miss Mint.
  • rodw
  • rodw's Avatar
13 Jul 2026 10:58
Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
Category: Plasmac
So does that mean you are in business and have a PC for spare parts? Hope so!
If not, I might be able to work in another site visit but it would cost you some footage for a YouTube video...
There is an email that gets me on my @MrRodW YouTube channel
  • GeckoWorks
  • GeckoWorks
13 Jul 2026 10:51 - 13 Jul 2026 13:15
Replied by GeckoWorks on topic Control panel
Control panel
Category: Show Your Stuff
Oh, can't believe I hadn't even searched for Syntec here.
I have literally spent the last week looking for used SK panels and trying to figure out what's what with them.I would be very, very interested in hearing more about your exact board and what's underneath your Arduino and next to it.
Now, feel free to skip to the bottom as next I was asking questions that you have actually answered already - I just didn't know enough to realize:)
Skip From Here...
Newer SK panels have a small "matrix chip" surface mounted to the button side of the PCB (just inbetween button switches), older ones have a larger one on the backside (often a Holtek) and even older ones have a whole daughter board attached to the back side with a what Syntec calls a "decoder module". I always assumed the chip would spit out a proprietary serial link. I had no idea they were talking PS/2... Well, I thought perhaps the older ones were based on the Holtek model numbers.
But I have been trying to avoid newer boards because I wanted easy access to the matrix. I also had no idea the matrix is actually availble on the "HK Connector" - but that's how it looks from your picture. It looks like the Arduino is connecting to the HK. Or is the HK sending out PS/2 to your arduino? In which case your panel must indeed still have a "matrix chip somewhere" and your Arduino turns PS/2 into USB?
Also, how do you control the button LEDs?
If you could find time to share some more on how you made this work, I would be very grateful. I would mostly likely go this way as apart from ideally wanting more overide knobs, the SK4/6M panels have a really nice set of control buttons - plus the alphanumeric keys, too.
On a related note - as for turning the matrix into USB, when I asked AI about how to hack older SK panels it suggested this approach but to also make a combo USB protocol of HID plus a gamepad or joystick library. That way, supposedly, when doing the HAL connections you don't have to venture into weird combo USB presses to map the buttons that HID has no library for. So, you'd use HID for the regular stuff it already has and then gamepad library for everything "CNC" and it would just be passed through as button 1, button 2, etc.
Also, I did talk to a Chinese vendor had to check back with the factory on the protocols and how open they actually are but between the language barrier and me only wanting to buy one, he kinda lost interest, haha. But I think he said they could deliver bare matrix, USB-HID and more.
Skip To Here:)
[EDIT] I really should learn to read. You specifically explained the SK panel does both PS/2 and matrix. So, now I think the PS/2 signal may be coming into your arduino from that 5 pin connector in the corner of the board that says "to keyboard" and the matrix comes out of the HK Connector. Also, you even said the matrix is shared for both buttons and LEDs. So, there we have it:) What wonderful detective work you have done to make these panels work!
So... would you be inclined to share the code and pin mapping to help others along:)?
  • rodw
  • rodw's Avatar
13 Jul 2026 10:48
Replied by rodw on topic Adding EtherCAT to LCNC 2.9.2
Category: EtherCAT
The only time I've used SDO's is to configure the drive. Maybe your drive does not need any configuration.
SDO's are not required to use cia402 commands
does lcec_configgen create a XML file?
  • rodw
  • rodw's Avatar
13 Jul 2026 10:37
Every time I boot LinuxCNC, the Xg54 position reading increase 256
First the Linuxcnc version you quote is invalid. What is it really?
Second, 256  is a very signiicant number for computers because an 8 bit number (1 byte) counts from 0-255 which a computer's way of counting from 1-256.
The  G54 values are stored in the var file. I could not see exactly what us the varibale number on a quick look. I would check this after you close to make sure its not being incremented on close,
My guess is that Linuxcnc will be OK but somehow outside of LinuxCNC, your encoder value is incremented by 1 X  8 bit byte.
  • RoberCNC
  • RoberCNC
13 Jul 2026 10:15
Replied by RoberCNC on topic Problem with PROBE tab after running a program
Category: Qtvcp
Hi there.
When choosing the PROBE tab with the file in the indicated directory, a pop-up window comes with this error:
"Traceback (most recent call last):
File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 626, in main_tab_changed
self.adjust_stacked_widgets(index)
File "/home/izan/linuxcnc/configs/QtDragon/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 126, in adjust_stacked_widgets
self.w.setCurrentIndex(num)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 493, in __getitem__
return getattr(self, item)
AttributeError: 'VCPWindow' object has no attribute 'dro_button_stack_4' "
(Attached the report)
In the other hand, I´ve set 99 tool number to probe, and after running a program if I go to TOOL tab, select it and push the M61 button to choose, it runs pretty good despite the down yellow line appears with the "cannot switch pages while in AUTO mode"
  • BlownCorona
  • BlownCorona
13 Jul 2026 08:14
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
that is essentially the commands Ive been trying.
below shows the error that keeps cropping up
Ign:1 http://packages.linuxmint.com xia InRelease
Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease
Hit:3 https://www.synaptics.com/sites/default/files/Ubuntu stable InRelease
Hit:4 http://packages.linuxmint.com xia Release
Get:5 http://security.ubuntu.com/ubuntu noble-security InRelease [126 kB]
Get:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease [126 kB]
Hit:8 https://ppa.launchpadcontent.net/freecad-maintainers/freecad-stable/ubuntu noble InRelease
Get:9 http://archive.ubuntu.com/ubuntu noble-backports InRelease [126 kB]
Get:10 http://security.ubuntu.com/ubuntu noble-security/main amd64 Components [44.8 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble-updates/main i386 Packages [517 kB]
Get:12 http://security.ubuntu.com/ubuntu noble-security/universe amd64 Components [76.3 kB]
Get:13 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 Packages [1,092 kB]
Get:14 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 Components [181 kB]
Get:15 http://archive.ubuntu.com/ubuntu noble-updates/universe i386 Packages [1,130 kB]
Get:16 http://archive.ubuntu.com/ubuntu noble-updates/universe amd64 Packages [1,660 kB]
Get:17 http://archive.ubuntu.com/ubuntu noble-updates/universe amd64 Components [388 kB]
Get:18 http://archive.ubuntu.com/ubuntu noble-updates/multiverse amd64 Components [940 B]
Get:19 http://archive.ubuntu.com/ubuntu noble-backports/main amd64 Components [5,744 B]
Get:20 http://archive.ubuntu.com/ubuntu noble-backports/universe amd64 Components [10.5 kB]
Fetched 5,484 kB in 5s (1,023 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
E: Unable to locate package linux-headers-6.13-rt-amd64
E: Couldn't find any package by glob 'linux-headers-6.13-rt-amd64'
i havn't been able to manually find a matching header either,  only some very close but older revisions and i dont know enough about linux to go about building it up to suit the above revision, or if thats even something that could be done.
  • RoberCNC
  • RoberCNC
13 Jul 2026 06:42
Category: Qtvcp
It is Qtdragon_hd, that's right.
I will try along the day and feedback.
  • Aciera
  • Aciera's Avatar
13 Jul 2026 06:33 - 13 Jul 2026 06:33
Very small 4 axis mill for cutting plastic materials
-the thing with C axis going from approx. 110 to -280 in about 10 lines of gcode does not seem OK
sounds like you might have downloaded the first version of the filter script which I modified shortly after posting to fix exactly this issue. So make sure you use the current one with the transition handling:
if dt < -180: # handle 180 -> -180 transition
current_c += (dt+360)
elif dt > 180: # handle -180 -> 180 transition
current_c += (dt-360)
else:
current_c += dt
I have tested this with all three {1,2,3}.pts files and the result looks fine to me. (The C axis values never goes negative)
  • JohnnyCNC
  • JohnnyCNC's Avatar
13 Jul 2026 02:17
Replied by JohnnyCNC on topic manual tool change with tool length probe
Category: G&M Codes
Attached are the Python files that I modified for my M6 remap with auto-tool measurement.  My changes are tagged with "JHK".
Enjoy
13 Jul 2026 00:33
Almost forgot, also swapped in hal the X and Z axis, so now if you turn the machine on the left side it is exactly as in the Vismach preview, and set the ini for A axis to home at 90, so i do not have to do that at every start.
  • M4MazakUser
  • M4MazakUser
13 Jul 2026 00:13 - 13 Jul 2026 01:10
Replied by M4MazakUser on topic C axis milling cycles. Anyone written any?
Yeah, not really that easy though, I'm really going to have to write one so it's more like an easy to write cycle on the machine. Like a conversational control.
Displaying 2491 - 2505 out of 12540 results.
Time to create page: 0.463 seconds
