  • ihavenofish
  • ihavenofish
23 Jun 2024 03:14
Replied by ihavenofish on topic MiniMonster V1.0 machine | planning the control
Thanks!
Servos will be delta adsa-b3. I need to read all the specs now.
The spindle itself has no encoder, and no easy facility to add one. Will need to see what it possible to cook up. Its really only for a safety shut down. (program 60k, see the spindle has bogged to 50k, you know something is wrong, shut down). Spindle load is not always a precise indicator on these high speed spindles it seems (see my steel cutting video where it is varying between about 18000rpm and 14000rpm)
Good point on the IO. I have an ek100 here somewhere. that plus one 16 in and one 8 out might be all that's needed and only $300 or so and open to easy expansion. also beckhoff has a local rep that's visited me before, so easy support.
  • ThyerHazard
  • ThyerHazard's Avatar
23 Jun 2024 03:03
Replied by ThyerHazard on topic AC spindle servo on a Chinese BOB set up
Category: Driver Boards
It doesn't have to be really 'good' the machine is a Seig X2 I have heavily modified it, but still I don't think a super nice spindle package would be worth it on this mill maybe my next project.
I was just looking for something better than the stock Brushed DC motor they ship with. at the moment the stock motor still works so I'll run that to begin with but I know the control boards for them are known to blow and its cheaper to get a Chinese servo set up than a new brushed control board (That will most likely break again)
Thanks again for the help guys this forum is amazing!
  • jimmyrig
  • jimmyrig
23 Jun 2024 02:45
4. That one would be easy enough, either mcu that reads values and hits a pause button, a python script that does the same. Sure you could make a half component do that as well.
3. Figure a simple induction or ultrasonic sensor could read if the tool is occupied. Don't think this one would be easier with an mcu.
5. Should work fine. Don't think probing cares what the tool setter is. But don't have much experience here
2. Might be able to get rpm with a simple 1 point sensor,. If not find a vfd that has closed loop control such as SV (Sensorless vector) which monitors the rpm with extra circuitry (gs20)
1. If everything is ethercat then go that route. I bet you could figure out a wauly to use the IO of the servo drives. Most have 3-4 of em.
If not then mesa and step dir is hard to beat from a simplicity and reliability side.
6. Not sure on this one
  • rodw
  • rodw's Avatar
23 Jun 2024 02:33
I can't answer all your questions but:
1. Ethercat has always just worked. It just how much work there is between just and works has reduced :) . If your drives are CIA402 compatible, its easy as there is now a generic driver here at the official driver repo github.com/linuxcnc-ethercat/linuxcnc-ethercat/tree/master
1.a Some people have used absolute encoders. Homing might be a work in progress. I am waiting for a bit of hardware to test my repo github.com/rodw-au/cia402_homecomp home_offsets and gantries are not supported at this stage.
2. My modbus spindle shows accurate RPM and also load. Finding an affordable encoder input is problematic outside of beckhoff.
This one www.icp-australia.com.au/product/ecat-2074a/
And this Chinese one is interesting  and would cover your IO too.But you would need to build a generic driver for it. www.icp-australia.com.au/product/ecat-2074a/
For cheap I/O, Rtelligent has one I use that includes some PWM outputs (16 in, 16 out). There is also one by Deiwu. I have built generic drivers for both. XML are in here github.com/rodw-au/linuxcnc-cia402
Limits and home switches (if needed) can be attached to the drives and then you home internally so IO will be limited don't discount Beckhoff.
23 Jun 2024 02:32 - 23 Jun 2024 02:35
Replied by Cant do this anymore bye all on topic Complete clueless idiot: please help me install linuxcnc v2.6.11
Category: Installing LinuxCNC
I'd try an install of Wheezy, it'll have 2.7 but should be able to be made to work.
I'd be wary of AI and the like, you know with "d1v3r5ty is strength" mumbo jumbo. If it finds enough information saying the sky is Cheddar Cheese that's what it'll tell ya.
On a side note, has anyone seen "AI sign language", think about it, how often does AI get hands right ?
23 Jun 2024 02:21
23 Jun 2024 02:19
Replied by Cant do this anymore bye all on topic AC spindle servo on a Chinese BOB set up
Yeah I'd be spending money on on an upgrade to some Mesa motion hardware control before a spindle, and a good spindle package isn't going to be cheap.
  • jimmyrig
  • jimmyrig
23 Jun 2024 02:02
Replied by jimmyrig on topic AC spindle servo on a Chinese BOB set up
Would try pwm and two output pins. One with run stop and another for fwd/rev
  • cmorley
  • cmorley
23 Jun 2024 01:44
Replied by cmorley on topic qtdragon_hd touchoff and probing issue-
Category: Qtvcp
Are you using a RIP or a installed version of linuxcnc?
  • Dave2024
  • Dave2024's Avatar
23 Jun 2024 01:38
  • electrosteam
  • electrosteam
23 Jun 2024 01:16 - 23 Jun 2024 02:06
Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
Tried a third cable this morning with similar results.
cornholio,
Thanks for the kind offer, I will send a PM.
John.
edit:
Well, PMs don't work.
How can we get in touch ?
John.
  • PCW
  • PCW's Avatar
23 Jun 2024 01:02
  • Thayloreing
  • Thayloreing
23 Jun 2024 00:53
How to make Linuxcnc open with the feed and override 0?
Thank you for being willing to try to help me, I also looked in the pins and didn't find anything, I also looked in the documentation to see if there was anything that could be added to the ini for this, but to no avail.
  • PCW
  • PCW's Avatar
23 Jun 2024 00:40
Replied by PCW on topic unable to adjust servo spindle speed
Take a look at the ini file spindle section,
MAX_OUTPUT and OUTPUT_SCALE parameters
Displaying 25156 - 25170 out of 26044 results.
Time to create page: 0.875 seconds
