12 Jul 2026 14:07
Replied by tommylight on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
sudo apt update && sudo apt install linux-headers-$(uname -r)
  • BlownCorona
  • BlownCorona
12 Jul 2026 11:06
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Good evening
I've been using this iso successfully for a while now, i picked up a nice touch screen that works, but would work a lot better if i installed the displaylink drivers. Problem is that when installing this, i get an error that the linux headers are missing.
Ive tried many of the usual commands to load the headers and nothing seems to be able to find the matching file. Have you got any insight or suggestions?
If you would like specific error messages i can go through the motions and record these for you.
Cheers!
  • dm17ry
  • dm17ry's Avatar
12 Jul 2026 10:59
STM32 ST-LINK Utility will not connect to the target.
i'm not into this stuff, but why would an ST programming utility connect to an NXP chip?
  • RoberCNC
  • RoberCNC
12 Jul 2026 10:46
Replied by RoberCNC on topic Problem with PROBE tab after running a program
Category: Qtvcp
Hi Chris.
I tried creating a Probe routine in MDI mode, just in case I was doing it manually and it was my mistake. I'm getting the same problem in both MDI and MAN modes. I've attached screenshots from both modes.
Thanks a lot.
  • Aciera
  • Aciera's Avatar
12 Jul 2026 06:07
Replied by Aciera on topic linking U axis to X
linking U axis to X
Same post here:
forum.linuxcnc.org/38-general-linuxcnc-q...n-4-axis-mode#347523
No double posting, please continue in the thread linked above.
  • Onkelmat
  • Onkelmat's Avatar
12 Jul 2026 05:01
Replied by Onkelmat on topic I hate the 7i97T
I hate the 7i97T
Category: Configuration Tools
the whole connection thing was already working on mesaflash and mesact, i could confirm with mesact, every test was a success. But Linuxcnc would fail, In the end I had to click on the network button top right and then it worked.
As for now i´m okay. Sorry for the rant, but I was used to it being easy setup with Pncconfigwizardo
  • PCW
  • PCW's Avatar
12 Jul 2026 04:55 - 12 Jul 2026 05:05
Replied by PCW on topic I hate the 7i97T
I hate the 7i97T
You need to configure the network on the host for the Mesa card.
Also 192.168.1.121 is not suggested for LinuxCNC use as it's  in
a commonly used NAT range.
Suggested setup is to use the 10.10.10.10 address on the Mesa card
(via the IP address setup jumpers) and set  a static host address of
say 10.10.10.100/24.
At this point you should be able to ping the Mesa card:
ping 10.10.10.10
  • Onkelmat
  • Onkelmat's Avatar
12 Jul 2026 04:17 - 12 Jul 2026 04:57
I hate the 7i97T
I mean i love the Mesa cards and Linuxcnc, but this card really made me reconsider using Mesa and Linuxcnc. The point where i broke was, after getting it to be recognized by mesaflash and mesact Linuxcnc would tell me network unreachable. This problem followed me through the whole process, either "network unreachable" or "no such device at 192.168.1.121"
EDIT: So far i got it running, but the whole process to get there is tiresome.
  • cmorley
  • cmorley
12 Jul 2026 00:59
Category: Qtvcp
It would be normal to select MDI mode to use the probe after running a program.
You probably can't select tools, offsets or file in auto mode too.
let me know if I've misunderstood the problem.
Chris
  • cmorley
  • cmorley
12 Jul 2026 00:37
Replied by cmorley on topic I hate the 7i97T
I hate the 7i97T
Done!
Thanks.
11 Jul 2026 23:22 - 13 Jul 2026 00:29
Very small 4 axis mill for cutting plastic materials
Category: Show Your Stuff
Spindle mounted at the right side of the X axis, and all that mounted to the Z axis (see HiWin HGH25 left)
How the tool should be positioned during cutting, only the see-thru thin sheet over the brown (orange?) part must be cut, so about 0.5-1mm deep
C axis (3D printed round part with teeth for belt) is mounted above the Y axis and moves with it.
Full view of the important parts:
So far i have tried and tested over 10 configs, and over 40 scripts generated by Gemini, so this has become a late evening sport and an exercise in futility, although there were some moments when it seemed it is working, just to fail miserably.
None of those had TCP, just variations of axis/joints and different planes of works space.
Last two configs have TCP, and the subsequent failure to obey the joint/axis velocities and accelerations, the parallel port one a lot, the Mesa one less often so at least i can test a bit with TCP on and feed/speed lowered beyond useful.
And that brings us to:
Aciera, thank you for helping with this, i did not reply last night as i did not have much time to test, so gave it another go tonight (well yesterday, i see now it is 2:04AM here), so here are some of the results, probably in a non-coherent manner:
-in sim, it starts sine but after a short while it rolls/winds the C axis a lot as can be seen on the preview by the tool making a full rotation around the cut line, but in the same spot on the cut line, then continues nicely for most of the cut.
-on a machine, after fixing the limits and G53 0, it does the same thing, but here LinuxCNC errors out and stops the machine, even at very, very low feed rate and low max velocity, usually C axis at the beginning and Y axis a bit later. I am sure i read somewhere here about TCP causing this but could not find it, so i will try again today/tomorrow.
-the thing with C axis going from approx. 110 to -280 in about 10 lines of gcode does not seem OK, and i could not find what is causing that, it happens on several converted/filtered files, not just one, always after several lines of OK code.
Again, thank you, will report back whenever i can.
  • PCW
  • PCW's Avatar
11 Jul 2026 22:11
I hate the 7i97T
That's great!
It does need:
setp   hm2_7i97.0.pwmgen.00.offset-mode 1
and not required but an added feature would be:
setp   hm2_7i97.0.pwmgen.00.dither 1
for all 7I97/7I97T PWMgens
Also a better default PWM frequency would be 48 KHz
11 Jul 2026 20:51
Replied by tommylight on topic linking U axis to X
linking U axis to X
Was this same question asked before on this forum?
P.S.
Still did not finish my build of a 4 axis foam cutter, so not yet at this point.
  • foam man
  • foam man
11 Jul 2026 20:27
linking U axis to X was created by foam man
linking U axis to X
hi I have a 4 axis hot wire foam cutter. i move each axis separate, but I'm wondering if the text below makes sense for, essentially moving U and V with X and Y commands. Thanks
The Fix:
How to make UV emulate XY while keeping their own step calibrations.
To force U and V to mirror X and Y while preserving their independent step calibrations, you must link the signals before the math calculates the motor steps.
In LinuxCNC, you do this by linking the motion controller outputs to both sets of joints, rather than linking the step generators directly.
Open your machine's main .hal file and look for the lines connecting motion.coordinate-system to your joints. Change them to route like this
:hal# Force Joint 2 (U) to listen to the X-axis motion command
net x-output motion.coordinate-system.0.pos-cmd => joint.0.motor-pos-cmd joint.2.motor-pos-cmd
# Force Joint 3 (V) to listen to the Y-axis motion command
net y-output motion.coordinate-system.1.pos-cmd => joint.1.motor-pos-cmd joint.3.motor-pos-cmd
Use code with caution.Why this fixes the calibration issue:
The Signal: LinuxCNC outputs a raw request in millimeters (e.g., "Move X to 50.0mm").The Split: The HAL lines above take that 50.0mm request and send it to both Joint 0 (X) and Joint 2 (U) simultaneously.The Calibration: Joint 0 looks at its own SCALE setting in the .ini file to convert 50.0mm into steps for the X motor. Joint 2 looks at its own independent SCALE setting in the .ini file to convert 50.0mm into steps for the U motor.
  • Jens23
  • Jens23
11 Jul 2026 20:12
Replied by Jens23 on topic Trixy Install problems
I am currently trying to install this and it doesn't validate. When making a bootmedium RUFUS even said, that 1.5GB of the image are missing. Could you please check?
It looks like the 2.9.10 image is half the size of the previous.
Displaying 2521 - 2535 out of 12540 results.
Time to create page: 0.917 seconds
