  • Dennie
  • Dennie
06 Jul 2026 20:43
7iA0 outputs was created by Dennie
7iA0 outputs
Category: Driver Boards
Hey folks, I'm a german guy who lives in Paraguay. At first I want to say thank you for LinuxCNC and all the projects around
it. Wow, my head is exploding because of learning all the stuff.
I am currently retrofitting an Edel Micromat 205HS CNC nibbler.
I want to buy a 7i97t because of the analog Perma Drive drivers and servos (A,A/,B,B/,0,0/, +-10V).
For all the sensors, switches and contactors I'd like to buy a 7iA0.
My question to you would be:
The machine has originally I/O cards from Labod and the 24V power supply for the output mosfets can be switched off with E-
Stop.
I want to do the same with the 7iA0 but I do not understand the outputs in the manual.
There it says
PIN 1 OUT -00-
PIN 2 OUT -00+
PIN 3 OUT -01-
PIN 4 OUT -01+
and so on.
Can I connect 24V+ to PIN 2, 4,... and so on so the card connects this PINs to PIN 1, 3,... and so on? Or is it the
other way round? As to speak, does the card connect the -PIN with the +PIN next to it when an output is switched on? If that's
the case, do I connect 24V+ to 2, 4,... or to 1, 3,...?
Thank you in advance for your help.
Greetings
Dennis
  • Etced
  • Etced
06 Jul 2026 18:55
Replied by Etced on topic can not jog axis in Gmoccapy
Category: Gmoccapy
Step config files, where xyz jog does not work.
  • Etced
  • Etced
06 Jul 2026 18:50
Category: Gmoccapy
I just noticed that in the PNC config wizard "test this axis" that I can jog xyz. However in the Step config wizard "test this axis" I can not jog xyz.
  • Rykagon
  • Rykagon
06 Jul 2026 18:03
Newbie asking for resources and advice
Hello All,
  I'm attempting to retrofit a 90's vintage Intelitek Prolight 3000 lathe.  This is a small slant bed CNC lathe marketed to high school and technical college programs, and originally controlled by proprietary electronics and a desktop PC.
The plan is to use LinuxCNC on a Raspberry Pi 4, mated with a Mesa 7i76EU board, along with TB6600 stepper drivers to control and X- and Z-axes as well as a stepper driven 8 position tool changer.  The spindle motor speed is analog controlled 0 - 10 volt signal input.
I have zero experience with most of this and would appreciate any coaching on:
- which Linux distro to load on the Pi 4.
- any resources for configurations, etc.
- any other stuff I don't even know that I don't know.
Thanks in advance!
  • Odiug
  • Odiug
06 Jul 2026 15:39
Replied by Odiug on topic G38.2 Weird behaviour
I see you have withdrawn 2.9.9.
I tried an "apt-get clean; apt-get update; apt-get upgrade", but still get:
E: Failed to fetch www.linuxcnc.org/dists/bookworm/2.9-uspa...pace_2.9.9_amd64.deb 404 Not Found [IP: 69.163.143.134 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is this related or an issue on my side?
  • Aciera
  • Aciera's Avatar
  • degger
  • degger
06 Jul 2026 12:08
fresh install 2.9.9 iso was created by degger
Category: Installing LinuxCNC
hello all
i installed 2.9.8 iso on virtualbox without any issue, but with same machine i got errors mirror failed... when i click ignore and contionue grub boot also failed . what couse the issue?
  • NWE
  • NWE's Avatar
06 Jul 2026 11:31
Introducing halflow, an interactive graphical hal editor
Category: Configuration Tools
There is now partial support for creating a LinuxCNC configuration. At a jobsite recently I jump-started my hand editing of a heavily customized LinuxCNC config by creating small parts of it with halflow and stitching things together in a text editor.
There is some initial support for modbus networks point-and-click setup. More on that later. After my earlier complaints against modbus, recently I'm finding it useful.
It seems there is only so much ai can do with vibe-coding. Till recently I was treating halflow as a black box and commanding the chatgpt robot make it do this, do that... Things were getting to the point it seemed to be taking more and more effort for less results, in spite of starting fresh with new chats, etc. Now I opened the pandora's box and am digging through the code, switched to claude, and am telling it how I want things done under the hood.
  • NWE
  • NWE's Avatar
06 Jul 2026 11:00
Mesa Ethernet / QtPlasmaC retrofit experience — lessons from a marginal mini PC
I originally planned to use a small MeLe mini PC that I already had. It booted fine, LinuxCNC installed, QtPlasmaC launched, Mesa connected, and the machine homed and jogged. At first glance it seemed usable.
The problem was intermittent realtime/Mesa communication errors. I saw errors such as:
- Unexpected realtime delay
- hm2 error finishing read
- Watchdog has bit
- Smart Serial communication error / timeout
- Smart Serial Port 0 stopped
Adding to the list, I have a really cheap Uxx and MinisForum mini-pc here with the same shortcomings. I suspect most NUC type mini-pc's are built with laptop type of hardware.
On the other hand, I have used at least 4 different "fanless industrial mini-pc" from Aliexpress, several of them are running 24-7. None of these have disappointed me yet, but I am still somewhat cautious of them. I like their compact size, multiple network ports, and fanless means I'm not plugging them with dust in dusty environments (hopefully).
Projects where I want solid performance, I sometimes use servers or workstations with ECC RAM. Probably overkill in every dimension. They seem to run LinuxCNC just fine.
  • NWE
  • NWE's Avatar
06 Jul 2026 10:00
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Anybody need ?
Thanks, that looks like a screenshot of some kind of Lichuan servo drive configuration software. Can you give more details?
  • Fr3nzy
  • Fr3nzy
06 Jul 2026 09:35
Replied by Fr3nzy on topic Installing ethercat repositories
Category: EtherCAT
Would you help me with the ISO image files? My email is This email address is being protected from spambots. You need JavaScript enabled to view it. . The system is Dell Optiplex 7050 with Intel i219 LAN. Core i5 with 4 cores, 8gb ddr4 ram, UEFI and Secure boot with option for disabling. 256GB ssd nVme. I will be controlling 5 axis CNC mill Gantry type. The spindle head will rotate and have 2 axis.
Kind regards
  • usmandeveloper
  • usmandeveloper's Avatar
06 Jul 2026 08:57
Replacing RichAuto A11 handle with PC control (LinuxCNC/Mach/UCCNC) on AC servo
Hi everyone,
I'm working on a KEGEMA-branded CNC router (1300x2500mm working area) that currently runs on a RichAuto DSP A11 handheld controller. I'd like to bypass the handle and control the machine directly from a PC (jog, home, run G-code, start/pause) — similar to what was done in this thread:
forum.linuxcnc.org/30-cnc-machines/35371...troller-richauto-a11
I've read that thread carefully and it's been very helpful, but my setup differs in one important way: my machine uses AC servo motors, not steppers.
Machine specs
Working size: 1300x2500x200mm
Spindle: 6kw HQD air-cooled
Spindle inverter/VFD: 7.5kw Fuling (brand: Folinn on the unit itself)
Axis motors: Leadshine 750W AC servo motors + matching Leadshine AC servo drivers (model marking "L7", 750W, one per axis: X, Y1, Y2, Z — Y1/Y2 appear to be a dual-motor gantry setup)
Reducer: Shimpo (Japan)
Control: RichAuto DSP A11 handheld controller
What I've already confirmed
Inside the control cabinet, the A11's interface board has clearly labeled screw terminals (not just a blind 50-pin harness like in the thread above):
INPUT SIGNAL row: X1 (XH/X-home), X2 (YH/Y-home), X3 (ZH/Z-home), X4 (TS/tool setter), X5-X8 spare, 24V/GND/SHIELD
OUTPUT row: Y5-Y8 + GND (relay outputs — dust collector, water pump, etc.)
Separate 4-pin terminal blocks per axis labeled X_AXIS, Y_AXIS, Z_AXIS, C_AXIS, each with 5V / PULSE / DIR / SHIELD
Each axis terminal block has its own cable running directly to its Leadshine servo driver's CN1 connector
Since these are screw terminals (not a sealed connector), my plan is to add a second wire in parallel at each terminal (tap-off) rather than disturb the existing A11 wiring, so the A11 handle stays functional as a fallback.
What I'm unsure about / looking for help on
Pulse/Dir signal type from Leadshine 750W AC servo drivers (L7 series) — are these standard 5V single-ended step/dir inputs, or differential (like the RS422 signals in the referenced thread)? Trying to confirm from the datasheet before wiring anything.
Recommended motion controller for a 4-axis (X, Y1, Y2 as dual Y, Z) AC servo setup — Mesa 7i96 vs 7i76e vs something else? Do I need differential drivers (like the AM26L31CN used in the referenced thread) between the A11 board and the controller card?
Dual Y-axis (gantry) handling — should Y1 and Y2 be wired as one LinuxCNC axis with a single driver output, or does anyone have experience keeping them as two synced axes?
Spindle speed control — my board also has S0-S3 speed-select terminals (7-speed selection, not analog 0-10V). Anyone dealt with converting this to continuous VFD speed control from LinuxCNC/Mach, or is it easier to just leave spindle speed control on the VFD's own panel?
Any gotchas specific to RichAuto A11 + AC servo (vs. stepper) retrofits that I should know before starting?
Happy to share more photos of the interface board and servo drivers if useful. Any pointers, schematics, or "here's what worked/didn't work for me" experiences would be hugely appreciated.
Thanks in advance!
  • rodw
  • rodw's Avatar
06 Jul 2026 08:17
Replied by rodw on topic Installing ethercat repositories
Category: EtherCAT
Hello Mr. Rod,
Do you have iso image of working Linuxcnc with EtherCAT for direct installation?
I have some ISO's I'm not sure anything is working right now at the ethercat and LinuxCNC end. Working on that.
  • Fr3nzy
  • Fr3nzy
06 Jul 2026 04:38
Category: EtherCAT
Hello Mr. Rod,
  • MaHa
  • MaHa
05 Jul 2026 23:59
Replied by MaHa on topic python API - detect shutdown
I have a component that uses atexit. On my system this works fine to do something when i close linuxcnc. All other attemps failed.
import atexit
def exit():
    some code...
atexit.register(exit)
Displaying 2656 - 2670 out of 12539 results.
Time to create page: 0.318 seconds
