  • Todd Zuercher
  • Todd Zuercher's Avatar
26 Jun 2026 10:52 - 26 Jun 2026 11:13
Replied by Todd Zuercher on topic Joint speed tracking - motion in danger
If your concern is about the notchyness of the 2nd set of sign waves. I think your G64 settings are eating your lunch and your high tolerance setting is causing the naive cam detction (Q tolerance which defaults equal the P tolerance) to screw up your motion. Changing from G64P0.01 to G64P0.001 makes a big difference in the smoothness of 2nd set of sign waves and the motion ends up much closer to what your g-code was programmed to be.
  • Todd Zuercher
26 Jun 2026 10:32 - 26 Jun 2026 10:34
I have been of the opinion that the current default motion planner has never been completely bug free since the circular arc blending/multi line look ahead was added back in version 2.7. I have often observed quirky behavior for series of moves similar to those you have posted. But the "new" planner offers such a significant improvement in milling speed for most cad/cam generated code as to justify tolerating it's issues.
​​​​​​​But I'm not noticing any differences between runs on my machine simulation
  • deltafox24
  • deltafox24
26 Jun 2026 10:13
Replied by deltafox24 on topic EtherCat - CATIO module Help
Category: EtherCAT
Have you tried running RS485 through this module? I just can't seem to get it to work.
  • deltafox24
  • deltafox24
26 Jun 2026 10:05
Replied by deltafox24 on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
Has this issue been resolved yet? Or has no one looked into it?
  • wroughtiron
  • wroughtiron
26 Jun 2026 04:06
Mesa suppliers located in UK was created by wroughtiron
Hi, I am new to the forum, I built a 4 x 4 cnc plasma table 6 years or so ago, I used Mach 3 with cheap Chinese BOB's. I have not used the machine for a number of years, but now wanting to get it up and running again using Linux CNC.
My question is where can I purchase a Mesa 7i96 or 7i96s board? preferably from a UK supplier.
  • Ismacr63
  • Ismacr63
25 Jun 2026 23:05
Replied by Ismacr63 on topic I can't reverse the spindle rotation.
Category: Basic Configuration
The servomotor uses the ECAC XP200 driver, and according to the manual, the digital inputs can only be controlled with 24V.
I also have the ground for the 7i92 tied to the common ground.
25 Jun 2026 22:49
Replied by tommylight on topic I can't reverse the spindle rotation.
Now the question becomes:
will the servo drive work with 5V on the inputs?
Did you check the manual?
Older drives do not, but all new-ish ones do.
Now i wonder if i missed how old is your drive! :)
25 Jun 2026 22:46
Sorry, i missed 5V/24V thing above.
I edited the above posts.
  • PCW
  • PCW's Avatar
25 Jun 2026 22:41 - 25 Jun 2026 22:42
Replied by PCW on topic I can't reverse the spindle rotation.
The Isolator is doing 5V to 24V translation so unless the BOB has a relay/24V output
it cannot go directly to the VFD
Sounds like maybe  grounding issue (or damaged OPTO)
Note that a parallel port ground is nearly always frame ground
but the 7I92 ground may be floating
25 Jun 2026 22:36 - 25 Jun 2026 22:44
Deleted as i missed the part about level shifting.
Sorry.
  • Ismacr63
  • Ismacr63
25 Jun 2026 22:30
I would check the output of the direction control PC817 with a voltmeter/ohmmeter
I checked for continuity between the V output and GND using a multimeter, and even though the LED is lit, there is no continuity.
Tomorrow I’ll check the resistance at the output. It’s all very strange because I have two brand-new modules, and they behave the same way.
They always worked perfectly on a parallel port, but I no longer have the PC with a parallel port to test them again...
  • PCW
  • PCW's Avatar
25 Jun 2026 22:10
  • Ismacr63
  • Ismacr63
25 Jun 2026 22:07
What do you recommend I use instead?
25 Jun 2026 22:04 - 25 Jun 2026 22:47
Deleted as i missed the 5V to 24V level shifting mentioned above.
  • Ismacr63
  • Ismacr63
25 Jun 2026 21:28
ok this is driving me crazy. today i fired up the machine, turned on the spindle, hit reverse... and it worked. first time since swapping to the 7i92.
i thought maybe the gremlins had left, so i shut down the machine, powered it back up again, tried reverse — nothing. spindle just keeps going forward. led on the module still lights up, wiring is solid and untouched. literally didn't touch a single wire between the time it worked and the time it stopped.
any clue what could cause this?
Displaying 2866 - 2880 out of 12539 results.
Time to create page: 0.510 seconds
